Hello. I have Amiko Mini Combo. My question is, how firmwares for this receivers are writen? I mean which tools are used?
I'm familiar with programming in C and C++. I would appreciate any help.
Best regards!
Best regards!
What model of combo do you have?
Amiko Mini Combo or Amiko Mini Combo SE?
First one.
Solaris based for writing (makin' firmware),crypted with AES256.
For writing on flash(RS232 interface) use this [Only registered and activated users can see links. Click Here To Register...]
Thanks for help.
I'm familiar with writing on flash using cable.
Can you please explain what exactly "Solaris based" mean?
I'm sorry to bother you, but I'm still not sure I understand. I know that Solaris is operating system, but I'm not sure what this receiver has to do with it.
Do you have maybe some tutorial explaining this? Is it possible maybe to edit existing software, like one you posted in your message?
"Surface" editing is possible with some decompiling sw. made by platini(googleit).
At new softwares,with SDK4.0 , i don't know...
Written in C, C++, packed with lzma,unpack maincode,possibe to decompile with IDA ,mipsl.
(Java based ,SDK).Sorry for my bad english,hope you understand...
Developer envionment (SDK-ALi Ide) .
Full function developer kit(non-public)
Wow! You helped me a lot! Is that environment free?
Do you have some tutorial or some book maybe explaining how to use it etc?
Best regards!
"Full function developer kit(non-public) ".
Oh right, I didn't notice "non-public" :)
Is it absolutely neccessary to have that Environment to write firmware? Sorry for amateur questions, I only want to learn :)
Do you read, post [Only registered and activated users can see links. Click Here To Register...] ?
konstantin explained how to... for amateur.
As title says, which operating system uses Amiko Mini Combo?
Best regards
There is no Operating System on Amiko Mini Combo. Just firmware.
No ,shit...And a firmware what is it? A "smoke flow" ,or what?
Hi all, hope that someone can help me on this.
I'm having issue with Amiko Mini Combo HD.
After FW upgrade using Serial Connection, I'm not able to boot it.
The FW upgrade apparently was OK; at the end the POWER OFF appeared on the Amiko screen, but after PowerON the board cannot start anymore !!!
From Putty console I can see always same info. I suppose the bootlaoder stucks :
APP init ok
CH455 panel init OK!
g_boot_type = 0
flash init OK,flash size is:0!
boot_type = 0
boot_code = 0x9ef3fdf6
MG_Setup_CRC_Table finish.
@pointer[00030000] id[01FE0100] crc[0D61A886] != data_crc[AC889A4A]
check_program finish.
Also plugged out and plugged in the power the info are always the same...:oops:
I Tried also the following, as kindly suggested by Kosta, without luck:
unplug AC socket of receiver,load sw in to the loader,select upgrade allsw+bootloader,tick next.When appears
syncronising with target,quick plug AC.
Any other way to recover it ?
:pls:.. Help me!!!
brunodepi
Hello, I need jtag tutorial and tools for Amiko Mini Combo. Can you help me?
Thanks in advance
Not available for home users,only for service.
And is very expensive...
