Plugins pentru Vu+ Solo 4k
Latest Version of OScam arm Vu+ Solo4K
The Solo4K uses an ARM CPU and not MIPS so for now the only working emu is Oscam.
This file has been configured with both internal readers working for UK Freesat card and Tivusat Card.
Thanks Dumnonia
enigma2-plugin-cams-oscam_11077_all.rar---------------[Only registered and activated users can see links. Click Here To Register...]
Here is OScam 11086 with emu and @Informed keys, the only config files are oscam.conf and oscam.usr
Thanks InformedĀ® and Dumnonia
enigma2-plugin-cams-solo4k-oscam-emu_11086_all.rar--------------------[Only registered and activated users can see links. Click Here To Register...]
OScam for VU+ Solo 4K
BlackHole
enigma2-plugin-cams-oscam-svn11086-solo4k_blackhole_all.ipk
openATV
enigma2-plugin-cams-oscam-svn11086-solo4k_openatv_all.ipk
openVIX
enigma2-plugin-cams-oscam-svn11086-solo4k_openvix_all.ipk
OScamEmu 11105 for VU+ Solo 4K
BlackHole
Solo4kOscam11105EmuBlackhole.rar
cine ma ajuta si pe mine sa instalez oscam-ul?
am imag vti
dau si 2-3-4 beri
cred ca e mai complicat,am impresia ca trebuie completate oscam.conf,server, etc.
daca ai timp si poti sa ma ajuti,cu teamviewer,cumva sa o scot si eu la capat.
mersi
Vu + Solo 4k E-Panel 5.7-r10
E-Panel for the image based on OpenPli / OA (system panel)
ipk enigma2-plugin-extensions-epanel-5.7-r10.ipk
openATV Softcam Feed
Update 12/07/2016
solo 4k/ultimo 4k/uno 4k, mutant hd51/52, AX 51/52, Xtrend ET11000/120000, Spycat 4K, Edision 4k, Octagon 4k usw
softcam-feed-arm-ahf_1.1_armv7ahf-vfp-neon.ipk.zip
MGCamd 1.35a for Openpli (Solo 4k)
MGCamd 1.35a for Openatv (Solo 4k)
Am Openpli 5, oscam nu e la panel aşa că am căutat pe net şi l-am pus manual şi l-am pornit tot manual. Am doua probleme: 1. După restart reciver nu porneşte oscam automat, trebuie mereu să-l pornesc manual. 2. Nu deschide din softcam.key nici Biss, nici altele, doar din linii. E vreo setare specială pentru aşa ceva? ...
LCD4Linux ipk all : [Only registered and activated users can see links. Click Here To Register...]
testat pe BH 3.0.2H , plugin-ul de la serverul de download oficial nu functioneaza .
Salut,
Are cineva cunostinta de un link, sau de un nume de ipk, ceva, ce mi-ar permite sa instalez key si sa functioneze pe cablu? Thx! Momentan folosesc un cam, dar vreau sa eliberez slotul.
oscam emu , cu soft.cam.key ai incercat ?
oscam: /usr/bin
oscam config files: /etc/tuxbox/config/oscam
softcam: /usr/keys
detalii mai gasesti aici : [Only registered and activated users can see links. Click Here To Register...]
Probabil trebuie sa setez inca ceva. Acel user anonymous imi spune probabil ca trebuie sa am un dvbapi. Nu imi mai amintesc cum trebuie sa fac asta, dar mai caut.
L.E. A luat-o! Erau k.e.y.le vechi.
Pentru a instala acest plugin il descarcati de pe server,prima data dati jos LCD4Linux V4 cum este in imagine:
Apoi descarcati LCD4Linux config solo 4K cum este in imagine:
Nu uitati sa aveti instalat picons si dupa restart veti avea mini-tv-ul LCD configurat asa:
bitrate viewer
Hi, i built for you this extension, it is for VU Solo4K and it was tested under OpenPLi 6.2.
I wonder why i am unable to attach files....
please download the ipk from here:[Only registered and activated users can see links. Click Here To Register...]
multumim: @serdeliuk
