OPENSPA 5.002 for VU+ Solo 4K
- First OpenSPA image for VU+ Solo 4K
- Improvements at spzPIPMenu
- Fix spzTimeShift
- Improvements at OpenSPA information screen
- Fix MyTube
- Fixes at spaqbutton (Keys Remap)
- Other minor fixes and improvements.
- New skin Full HD openSPA_JRLG1080 (by the moment, the only skin Full HD 100x100 compatible with OpenSPA). Not necessary OSD setting.
- Kernel 3.14.28
- Gstreamer 1.6.1
- Drivers 13-11-2015
parola FTP/Telnet openspa
OpenSPA 5.0.002 for VU+ Solo 4K 22-11-2015.-----------Update
Black Hole 3.0.1 OE 3 for VU+ Solo 4K Image
Dear Vuplus-Community users,
The Black Hole Team are proud to announce, the new Black Hole 3.0.1 image based on the new Vu+ OE3.0 for all Vu+ models.
This new Black Hole 3.x image includes all the features of the previous Black Hole 2.x series, but also adds the foundations for new features in the future.
Please be aware that there are currently issue's preventing the Vu+ Turbo usb tuner from working with the Vu+ Solo, Duo, Uno, Ultimo and Zero models, we hope to resolve this issue soon.
ATENTIE:
They removed the sw from board and this info is there
Thanks,
It is unclear whether all of them have a problem or just a number of boxes.
We have boxes that do not have a problem.
It is therefore important to write positive and negative tests.
However, no matter it is clear that a problem exists.
---------- Post added at 23:10 ---------- Previous post was at 23:04 ----------
Open Source 3.0 for VU+ Solo 4K Image
What's new:
Fix boot issue with some solo4k boxes
New drivers
OpenSPA 5.0.003 for VU+ Solo 4K 04-12-2015.-----------Update
---------- Post added at 10:53 ---------- Previous post was at 10:29 ----------
VTi "Vu+ Team Image Solo 4K" - V 9.0.0
Info
CI+ works in the VTi-Image
_________________
25.10.2015 - Software Update
- update dvbapp2 (ver. 2015-10-25)
fix loading MovieList in OpenWebIF
fix SSL init
- update base-files
create /media/hdd folder
_________________
26.10.2015 - Software Update I
- update drivers (ver. 2015-10-19-r1) (Solo 4K)
_________________
26.10.2015 - Software Update II
- update dvbapp2 (ver. 2015-10-26) (solo4k)
- update freetype
fix font rendering
-update tzdata
add missing time zones
_______________
27.10.2015 - Software Update
update dvbapp2 (ver. 2015-10-27)
allow also AC3/DTS audio tracks when hdmv descriptor is not seen
- update dvbmediasink
fix audio/video sink, this fixes possible crashes at some streams
_____________
28.10.2015 - Software Update
- update dvbmediasink</itemtext>
improve playback of H264 streams
_________________
29.10.2015 - Software Update</title>
- update dvbapp2 (2015-10-29)
fix crash at loading grayscale PNG files
- update plugin DLNAServer (2015-10-29)</itemtext>
adjust for MiniDLNA 1.1.4
- update plugin OpenVPN
fix file permissions
_________________
01.11.2015 - Software Update
fix crash at loading 2 Bit PNG files
_________________
03.11.2015 - Software Update (Solo 4K)
- update drivers (2015-11-03)
support HD PiP (no UHD)
fix loop-through in Dual DVB-S2 tuner
fix 2160p problem (existing at some TV's)
increase max recording to 24
- update plugin videomode (2015-11-03)
support HDMI colorspace setup
please set colorspace to RGB when there are problems in 2160p mode
_________________
04.11.2015 - Software Update (Solo 4K)
- update drivers (2015-11-04)
fix vtuner (USB DVB tuner)
- update dvbapp2 (2015-11-04)
fix PiP positioning and resizing for video mode 2160p
fix SplitScreen for video mode 2160p
- update Vu+ Turbo drivers (2015-11-04)
- update HMP USB DVB-C/T2 drivers
_________________
09.11.2015 - Software Update
- update dvbapp2 (2015-11-09)
fix audio tracks for some services (N24 HD, DMAX HD ...)
_________________
10.11.2015 - Software Update I
- update dvbapp2 (2015-11-10)
show also skip intervalls in PVR state dialog
change behavior of SmartSeek (reduce time intervall at every button press)
_________________
10.11.2015 - Software Update II
- update dvbapp2 (2015-11-10-r1)
fix hiding PVR state dialog when infobar is not shown
- add plugin minitv-skinner (ver. 0.4) THX @einfall (solo4k)
_________________
17.11.2015 - Software Update VTi 9.0.1
- increase image version: VTi 9.0.1
- update drivers (2015-11-17-r0) (duo2,solo2,solose,zero,bm750,ultimo,uno,solo)
Change demux allocation scheme
fix DVB-T VCC(solose)
Improve DVB-CI
- update drivers (2015-11-13-r0) (solo4k)
improve PiP
support remote control with keyboard
- update dvbapp2 (2015-11-17)
remove CI workaround
fix change of audio track when CI is in use
fix service change at streams when CI is in use
CI-assignment: see config under VTi/Setup-System
timer conflicts take care of CI assignments (provider or services)
available services take care of CI assignments (provider or services)
CI-assignment: allow to add all services of bouquet
CI-assignment: fix selecting providers
fix closing skin selector when skin is not changed
SmartSeek: use exit button to revert last skip
- update satipclient
enhance compatibility THX @blackicehack
- update plugin coverfind (ver. 20151114-r4)
- update plugin lcd4linux (ver. 4.6-r4)
- update plugin minitv-skinner (ver. 0.5) (solo4k)
- update plugin tmdb (ver. 20151114-r2)
- update skin atilehd
- update skin mutespectator
- update skin stylefhd
_________________
22.11.2015 - Software Update
- update dvbapp2 (2015-11-22-r0)
minor bug fixes
_________________
24.11.2015 - Software Update
- update drivers (2015-11-24-r0) (solose, solo2, duo2)
fix dvr problem
- update dvbapp2 (2015-11-24-r0)
update unicable.xml
minor bug fixes
- update default services
- update skin stylefhd (ver. 20151124)
_________________
25.11.2015 - Software Update
- update drivers (2015-11-25-r0) (solo4k)
support transcoding in server idle mode
- update dvbapp2 (2015-11-25-r0)
movielist: support numerical text input for selecting movies
skins: support variable names for size and position values
skins: support <constant-widget>
see skin mutespectator for examples of new skin functions
- update skin mutespectator (ver. 2.3)
_________________
26.11.2015 - Software Update
- update drivers (2015-11-26-r0) (solo4k)
fix DVB-C/T tuner problem
_________________
27.11.2015 - Software Update
- update drivers (2015-11-27-r0) (solo4k)
fix booting problem
fix FCC(Fast Channel Change) problem
fix misc bugs
ATTENTION
Since 2015-11-27 it is necessary to use an OScam revision greater or equal
than 11086 (Solo 4K)
_________________
- update dvbapp2 (2015-11-27-r0)
improve PiP in MoviePlayer mode
[servicemp3] disable ssl-strict for souphttpsrc to support HTTPS streaming on GST 1.0
_________________
28.11.2015 - Software Update
- update dvbapp2 (2015-11-28-r0)
SmartSeek: add static skip intervall (button left/right)
add option to remap static SmartSeek skip intervall permanently to (left/right)
MovieList: add new overview "All movies"
MovieList: add option to display folder information\n ( amount of new movies / amount of movies / amount of sub directories)
CommonInterface: add option to suppress CI messages
Change default time for HDD --> idle mode to 20 minutes
update CS translation --> THX @roxy
update FR translation --> THX @cpxo
_________________
01.12.2015 - Software Update
- update drivers (2015-12-01-r0) (solo4k,zero,solose,solo2,duo2)
improve vtuner
- update dvbapp2 (2015-12-01-r0)
MovieList: add option to show only new movies as folder information
MovieList: add option to sort folder by amout of new movies
MovieList: change default config values for folder information
- update plugin epgimport (ver. 1.0-r41)
fix parsing services
_________________
02.12.2015 - Software Update
- update dvbapp2 (2015-12-02-r0)
MovieList: fix sorting folders
Common: set stream services to playable by default
- update gstreamer-plugin-dvbmediasink
fix changing of audio tracks at media files
________________
03.12.2015 - Software Update
- update skin kravenvb (ver.3.0.0)
_________________
04.12.2015 - Software Update
- update drivers (2015-12-02-r0) (solo4k)
disable Fast Channel Change
- update usbtunerhelper
_________________
OpenViX 3.2 Release Image for Vu+Solo4K
VU+rudream-4-------Vu+Solo4K-----16.12.2015
OpenNFR 5.1 VU+ Solo 4K Image
Open Source Image 3.0 ----------------Update 23/12/2015
