Telecomenzi Universale .... recomandari
Am cumparat cu 39 ron o telecomanda universala 4:1 programabila USB.
USB-7921 e modelul.
USB-7921 USB cable mode programmable remote is programmed by one USB cable. All remote codes are in PC software. IR library in PC software is updated frequently.
7921 has 4 device bank, which can replace the remote control of TV,VCR,DVD,CABLE,SAT,DTT,HIFI devices.
In software, there are edit mode and learning mode for user to edit IR library for programming usage.
User can search codes by hand or automatically. After finding corrected code, then program to remote.
Strong "My database" function, user can setup own IR database by learning, editting and importing from other IR codes, which is exported from other user, Philips IR code file and other format IR code files.
For wholesaler or distributor, there is a strong function called managing IR codes function, which can help to support retailer and end users. This VIP management function will let wholesaler or distributor to have own IR database and enhance own competitiveness.
Soft se poate descarca de [Only registered and activated users can see links. Click Here To Register...].
Acum "ma bat" cu ea.
Baza de date cu aparate deja cunoscute e impresionanta.
Se livreaza cu cablu USB.
---------- Post added at 19:04 ---------- Previous post was at 18:49 ----------
Baza de date cu coduri deja cunoscute e [Only registered and activated users can see links. Click Here To Register...].
Am primit de la amici un [Only registered and activated users can see links. Click Here To Register...] la care nu am telecomada.
Poate careva sa ma ajute cu o universala sau daca sta in tarile nordice sa ma ajute sa o clonam?
