Plugin Oscam versiune noua a aparut: [Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6574)
Am inceput testarea, deocamdata functioneaza perfect pe Spark.
Plugin Oscam versiune noua a aparut: [Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6576).
Plugin oscam nou aparut: [Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6579).
Cam se schimb repede lucrurile, verziuni oscam noi una dupa alta, aproape zilnic.
Va intereseaza, sa postez verziunile noi aparute, sau sa nu umpl forumul cu ele?
Plugin Oscam nou aparut: [Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6580).
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6581)
E foarte bine ca l-ai descoperit .
Trebuiea postat la sectiunea de emulatoare.
Vezi ca cel de [Only registered and activated users can see links. Click Here To Register...] e compilat de mine cat mai mic posibil. Daca te uiti la dimensiune ... e cam la 50%.
Noi am ajuns sa compilam oscamul initial pentru ca pe streamboard dupa ce le-a crapat un hdd, nu au refacut compilatorul sh40 un an, apoi am inceput sa optimizam modulele encluse.
Sunt aparate (cum e kathy) la care cei 300k economie la dimensiunea executabilului, si reducerea modulelor la minim, conteaza foare mult.
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6584)
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6586)
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6590)
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6592)
Mulţumiri pt tread, dacă tot faci munca asta nu pui tu acolo şi un changelog (il găseşti in arhivă) la ce se schimba. Nu de alta dar arată ca urat asa gol numa cu download.
Şi inca ceva dece ai ales versiunea qbox şi nu amino? Eu am folosit numai amino pană acuma, şi n-au fost probleme. Vezi ca is toate nightly build, aşa ca unele pot avea probleme.
Respecte!
Cand apare ceva remarcabil ... compilez au la sectiunea oscam 1.20 SH40.
Changelog for oscam SH4 v.6599
WebIf: small fix on showing multiple logins for one account
XMLApi: fix userstats
Folosesc qbox, pentru ca imi place cum functioneaza.
Dace iti place amino mai mult:
Changelogul este acelasi.
Nu prea aduc noutati aceste pluginuri aparute, schimbari minore, dar in functionarea lor este diferenta. Merita incercat sa-l vezi care iti convine cel mai mult. Ex. 6586 facea chiar si freezuri si avea timp de raspuns mai mare. Ultimul plugin functioneza bine.
Astea nu sunt plugin-uri !!!!
Sunt versiuni compilate ale unui emulator.
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6596)
Changelog:
r6596 | docman | 2012-04-11 19:45:05 +0200 (Mi, 11. Apr 2012) | 1 Zeile
Added some hints to cache exchange documentation.
r6595 | corsair | 2012-04-11 18:35:42 +0200 (Mi, 11. Apr 2012) | 2 Zeilen
emm: optimized emm checking, fixed skip counter bug
[Only registered and activated users can see links. Click Here To Register...](OSCAM 1.20-unstable_svn build #6598)
Changelog:
r6598 | corsair | 2012-04-12 00:30:55 +0200 (Do, 12. Apr 2012) | 3 Zeilen
dvbapi: added auto-lb
emm: fixed emm skipping+logging
r6597 | Deas | 2012-04-11 22:53:14 +0200 (Mi, 11. Apr 2012) | 1 Zeile
oscam.c - fix for #2481 when compiled with webif
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6599)
Changelog:
r6599 | corsair | 2012-04-12 13:13:55 +0200 (Do, 12. Apr 2012) | 2 Zeilen
dvbapi: another fix for betatunnel
Changelog:
r6600 | Deas | 2012-04-12 12:22:04 +0000 (Do, 12. Apr 2012) | 1 Zeile
oscam-config.c - small correction on inactivitytimeout so it is only saved when not default which is 0 and not 30 according to the documentation.
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6605)
Changelog:
r6605 | Deas | 2012-04-13 00:01:44 +0200 (Fr, 13. Apr 2012) | 1 Zeile
web-if: small cosmetics on user page
r6604 | Deas | 2012-04-12 21:48:05 +0200 (Do, 12. Apr 2012) | 1 Zeile
web-if: display units on inactivity and reconnect timeout for all readers and not just cccam
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6606)
Changelog:
r6606 | corsair | 2012-04-13 16:47:21 +0200 (Fr, 13. Apr 2012) | 3 Zeilen
oscam.whitelist: added mapping
m:caid: prov:srvid:chid:ecmlen caidto: provto
[Only registered and activated users can see links. Click Here To Register...] (OSCAM 1.20-unstable_svn build #6611)
Changelog:
r6611 | Deas | 2012-04-17 22:56:21 +0200 (Di, 17. Apr 2012) | 1 Zeile
ifd_sc8in1.h - fix missing cr/lf
r6610 | corsair | 2012-04-17 08:30:35 +0200 (Di, 17. Apr 2012) | 2 Zeilen
emm cache fixed
r6609 | corsair | 2012-04-16 08:42:52 +0200 (Mo, 16. Apr 2012) | 2 Zeilen
fixed some compiler warnings
r6608 | docman | 2012-04-14 12:08:22 +0200 (Sa, 14. Apr 2012) | 1 Zeile
Documentation for new whitelisting parameter 'mapping'.
