HOW TO UPGRADE DUO CARD
Update using a pendrive:
1) rename the DuoAPPv18.duo file to duoAPP.duo
2) copy the duoAPP.Duo file into a pendrive on root directory.
3) insert the pendrive in the receiver
4) on the receiver, select update DUO Card and wait
your card is already updated!
Update using a PC and a phoenix interface:
1- copy the DUOAPPv18 and the DuoAppLoader files in your PC.
2- Select the apropiate com port for you PHOENIX adapter.
3- Select the apropiate firmware
4- push "connect"
HOW TO UPGRADE FIRMWARE
To do the upgrade, turn off the STB and connect the STB to the PC using a null
modem cable (2-3 3-2 5-5), then start the program in the PC, select the new
firmware to load and start the upgrade procedure, then turn the STB on and the
upgrade process will begin. Follow the screen instructions.
EMU MODE
When Emumodule is active, you can access to special menus
- MENU - TOOLS - KEY EDITOR - to edit the keys that change periodically
- INFO - INFO (two times INFO key) - to display information about emulation
|********This information does not affect SRX series******** |
By default, the module is deactivated, to activate it do the following
process
1.- Go to main menu (press menu in RCU)
2.- Press 2 0 2 0 in the RCU
3.- A popup message will appear CAS SYSTEM ENABLED
4.- Emu module is now working
To disable the module repeat the above procedure, the popup will change
to 'CAS SYSTEM DISABLED'
AUTOUPDATE CONTROL
By default, autoupdate in D+ and TV Cabo is activated.
to deacativate it, go to Main Menu (press menu key in your RCU), and press
2121
[Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
