PKT E2 Haarp Image
Pana cand proiectul Titan va fii disponibil pt. toti posesorii de kathy va aduc spre testare o noua imagine PKT , bazata pe OpenSource SH4 Duckbox Project :
Image is designed for installation only in USB device
Added by sh4 Duckbox Team:
- fix optimize for size in stm24 and add it to ufs910 config
- [stm24] OSS SND kernel configs not needed any more (e.g. CONFIG_SND_PCM_OSS)
- [stm24] added lzma patch for squashfs
- [stm24] ext4 can now be used for ext2/3
- [make/ffmpeg] - updated ffmpeg 0.6.1
- [multicom-3.2.4_rc3] add new multicom driver
- [eplayer3] playback aac-he streams with aac-lc
- adding opkg binary to default build
- fix timing problem in filepush
- [Player2 179/191] possible fix for chopped DTS sound on some files
- [e2 nightly-0]introduce 3D Mode for OSD ( paint OSD twice in Side by Side or Top and Bottom )
- [libeplayer3] support for OSD 3D modes for subtitles
- [libeplayer2, libeplayer3] Close directory file handles after looking for subtitle files
- [stm24] added squashfs-tools 4.0 lzma patch
- [ufs910 kernel] - activate jbd2
- [ufs910, stm24 205/207] fix cracking noise on cinch/scart
- add busybox 1.18.5 stable
- extend streamproxy to support linuxdvbapi5
- [player2_191/player2_179]resturucture dts fix. The fix now only applys to DTS streams and the playback time is only corrected on time differences up to 50ms this MAY fix some issues with async sound
- [USF912/UFS922] garbage displaying Polish UTF-8 letters on VFD fixed
Added by PKT:
- first build on stm24 kernel
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- update e2 to 2011-07-06-experimental
- faster switching channels
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- Enable autofs support
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- PKT Channel Control v1.03: store Aspect Ratio separate on each channel
- MPlayer fix GS of EOF
- new InstallManager 1.0.6: new visualisation of install process. After format there is ability to abort installation process (this option is limited to 1 minut after start installation ) and also possibilty to change volume level while installing new image
- upgrade formating device in Install Manager
- update API of MyTube based on last CVS source
- update EmuManager v1.0.6:
add sh4Cam support & gbox fix
Known issue:
- sata is temporarily not support
- CI not work
- [Only registered and activated users can see links. Click Here To Register...][COLOR="Gray"]
---------- Post added at 13:53 ---------- Previous post was at 13:05 ----------
Prima impresie negativa din pacate : nu am sunet pe iesirea scart
Sa fie oare ca pe un stick de 4gb impartit in 4 parti egale , pe partitia 3 folosesc/am instalat PKT Nuburu v3 si pe partia 4 aceasta imagine ( pe partitia 2 am o imagine AAF ) ?
Celelalte 2 imagini ( AAF + PKT Nuburu ) au sunet pe iesirea scart
Butoanele de volum functioneaza corect avand osd cu acel difuzor intr-un cerc in dreapta imagini sus
care naiba e parola la ftp si telnet? ca nu e kathrein ca pana acum.
rezolvasem, dar mersi oricum. slaba imaginea pana acu. nici n-am ajuns sa pun emu si vad ca freezeaza pe un FTA HD, mai exact DUNA HD.
A aparut v2 a acestei imaginii : [Only registered and activated users can see links. Click Here To Register...]
v2 mult mai stabila decat prima, pana acu :D
Insa
E stabila dar la un moment dat crapa si nu inteleg de ce naiba .Crapa si trebuie repornit boxul .Are cineva o solutie pt asta ??
In rest este FOARTE OK !Pacat ca nu merge si pe hard.La mine merge pe stick doar .Stie cineva o varianta pt hard.Sa nu spuneti sa schimb usb cu ide in boot.conf ca nu merge ...am incercat deja .
STM24 nu merge inca de pe hard :(.
Dar
Insa doar la mine face figura asta ...adica la un anumit moment crapa si trebuie sa ii dau restart ?
@zildan ...te rog sa incerci sa pui daca este posibil un tutorial pt maxiboot.
MULTUMESC SI RESPECT MAXIM PT MUNCA PE CARE O DEPUI !!!!
Constatare
Si in sfarsit trebuie sa recunosc ca era gresala mea imaginea crapa pentru ca oscamul nu era ok. Am pus oscam5540 si merge superb ...canalele le deschide de parca nu sunt codate...incepe sa imi placa receptorul asta ...
A aparut v3 a acestei imaginii :[Only registered and activated users can see links. Click Here To Register...]
Image is designed for installation in USB or SATA device
Support receiver: Kathrein UFS910
Kernel stm24-207
prima inpresie...dezamagire totala la boot de pe hdd sata a trebuit 3 decuplari de la retea a recului pana a pornit imaginea..pe hd se blocheza la 10-20 sec...la cele sd merge binisor..cred ca cei de PKT sant in teste cu SATA device..
nu am testat inca imaginea cu boot de pe Stick..
La mine vad ca sa remediat prb. cu lipsa sunet pe iesirea scart , insa observ ca nu imi deschide/citeste toate partitiile de pe hdd
Am conectat un hdd de 1,5Tb pe usb extern ( in enclosura de 3,5" + alimentator propiu extern ) si in Media Center vede cele 5 partitii , insa deschide doar 1 din cele 5
Imi apar de genul :
003-9VT16L
003-9VT16L ( Partition 2 )
003-9VT16L ( Partition 6 )
003-9VT16L ( Partition 7 )
003-9VT16L ( Partition 8 )
Doar 1-ma partitie ( fara Partition x ) o deschide si pot citi/vedea filmele/fisierele de pe ea , in rest toate celelalte 4 partitii cand le deschid nu apare nimic in ele ca fisiere sau ce am in ele
boot de pe usb stick...aici s-au schimbat total datele problemei...totul a decurs normal la instalare ..o imagine care se respecta!..ms.
la mine V3 merge bine pana il bag in standby. dupa ce il deschid din nou imaginea e aproape negra se vad mici nuante de rosu si albastru foarte inchis. is revined doar cu restart complet.
problema pare sa fie semnalat si pe forumul lor, insa ma mir de ce n-a mai observat nimeni pana acu.
La mine nu merge subtitrarea la MKV(ecran verde) iar la iesirea din standby imaginea se face rosie si ingheata.Asadar am trecut inapoi pe nibiruV3 care deocamdata este cea mai stabila si perfect functionala.
Eram curios de player pe stm24 DTS si subtitrare dar mai astept.:)
Se pare ca la imaginile bazate pe STM24 mai este de munca .
Promisiuni sunt ca pe stm24 Titan sa avem o imagine functionala de sarbatori.
Deocamdada am miniUboot si BA.
f11
O noua versiune[Only registered and activated users can see links. Click Here To Register...]
Super imagine ...foarte stabilaa , indica procentul de boot , incarca tot inclusiv localul fara probleme...fara freez...dar tebuie sters din oscam.conf fisierul [global] ....
