Ofensiva VU - noi receptoare pana la sfarsitul anului !
Sunt deja lansate informatii referitoare la noi produse VU:
- VU uno - single tuner
Broadcom CPU: 7405, 1 Tuner, Memoria RAM: 256 MB Avansat multi-format decodor, care acceptă următoarele:
• HD/SD H.264/AVC Main and High Profile to Level 4.1 (HD),Level 3.1 (SD) • HD / SD Profil H.264/AVC principale şi la nivel inalt 4.1 (HD), Nivel 3.1 (SD)
• HD/SD AVS Jizhun Profile Levels 2.0, 4.0, and 6.0 (720p and 1080i for HDTV) • HD / SD AVS Jizhun Niveluri Profil 2.0, 4.0, şi 6.0 (720p şi 1080i pentru HDTV)
• VC-1 Advanced Profile @ Level 3, Simple and Main Profile • VC-1 Advanced Profilul @ profile de nivel 3, simplă şi principalele
• HD/SD MPEG-2 Main Profile at Main and High levels • HD / SD MPEG-2 Main Profile la Main şi High nivelurile de
• MPEG still image decode • MPEG incă decoda imagini
• SD MPEG-4 P2 SP/ASP • SD MPEG-4 P2 SP / ASP
• HD DivX 3.11/4.11/5.x/6x/Home Theater • DivX HD 3.11/4.11/5.x/6x/Home Theater
• Advanced audio processor supporting the following: • avansat procesor audio, care acceptă următoarele:
• AAC LC, AAC LC+SBR Level 2, AAC+ Level 2, AAC-HE • LC AAC, AAC + SBR LC Level 2, AAC + Nivelul 2, AAC-HE
• Dolby® Digital, Dolby Digital Plus • Dolby ® Digital, Dolby Digital Plus
• MPEG I layers 1, 2, and 3 (MP3) • MPEG I straturi de 1, 2, şi 3 (MP3)
• Windows Media®and Windows Media Pro audio • Windows Media ® şi Windows Media Audio Pro
• One pair of on-chip stereo high-fidelity audio DACs • O pereche de on-chip DAC stereo audio de inaltă fidelitate
• 3D SRS audio support • SRS 3D suport audio
• One I2S input port and one I2S output port, plus S/PDIF output • Un I2S port de intrare şi unul I2S portul de ieşire, plus / S PDIF ieşire
• High-performance 2D-effects graphic engine • de inaltă performanţă grafică 2D efecte motor
• Studio-quality text and graphics at HD resolution • text Studio-calitate şi grafică la rezoluţie HD
• Supports multiple layers and windows • Suportă mai multe straturi şi ferestre
• Digital noise and contour reduction (DNR/DCR) • Digital de reducere a zgomotului şi contur (DNR / DCR)
• Reduces artifacts such as block/mosquito noise • Reduce artefacte examinate in bloc / zgomot ţanţar
• Picture-in-picture • Picture-in-picture
• Supports simultaneous HD+SD display • Suportă simultan ecran HD + SD
• Mosaic Mode • Mosaic Fashion
• Supports up to 16 video decode/display for video-rich navigation • Suportă pană la 16 decodarea video / display pentru navigare video-bogat
• Motion-adaptive deinterlacer with reverse 3:2/2:2 pulldown • deinterlacer Motion-adaptive cu reverse 03:2 / 2:2 pulldown
• OpenCable™ ready with on-chip MPOD support • OpenCable ™ gata cu suport MPOD on-chip
• 400-MHz Dual-Core CMT MIPS32®/16e class processor 400 MHz • Dual Core CMT MIPS32 ® / 16e procesor clasa
• 64-bit DDR2 DRAM controller • 64-bit DRAM controller DDR2
• Dual SATA-2 interfaces for DVR and DVD applications • Dual SATA-2 interfeţe pentru DVD-uri şi aplicaţii DVR
• HD analog video encoder with simultaneous SD outputs • HD video encoder cu ieşiri analogice simultană SD
• NTSC-M/J, PAL-BDGHIN/M/Nc, SECAM analog outputs • M-NTSC / J, PAL-BDGHIN/M/Nc, ieşiri analogice SECAM
• 480i/480p/576i/576p/720p/1080i output formats • Formate de ieşire 480i/480p/576i/576p/720p/1080i
• Component RGB/YPrPb HD/HD-DVO outputs • Componenta RGB / / YPbPr HD ieşiri HD-DVO
• Macrovision® 7.1/NICAM support • Macrovision ® 7.1/NICAM sprijin
• SCART 1 and 2 • SCART 1 şi 2
• Component, S-Video, and composite via six on-chip V-DACs • Component, S-Video, compozit şi prin intermediul a şase on-chip V-DAC
• VBI encoders for CC/TTX with NABTS/CGMSA/WSS/ Gemstar®, AMOL I/II standards and dedicated TTX sideband • codificatoare VBI pentru CC / TTX cu NABTS / CGMSA / WSS / Gemstar ®, AMOL laterală I / II şi standardele dedicat TTX
• RF modulator with BTSC encoder • modulator RF cu BTSC encoder
• ITU-R-656 input and output ports • ITU-R-656 porturi de intrare şi de ieşire
• HDMI 1.3/DVI 1.0 Mac and PHY with HDCP 1.1 • HDMI 1.0 1.3/DVI Mac şi PHY cu HDCP 1.1
• Broadcom security processor • Broadcom de securitate Procesor
• AES/1DES/3DES/CSS/CPRM/DTCP copy protection • AES/1DES/3DES/CSS/CPRM/DTCP copie de protecţie
• MPEG-2/DIRECTV/DVB/ARIB data transport demux with 1DES/3DES/DVB/Multi2/AES descramblers • MPEG-2/DIRECTV/DVB/ARIB date demux transport cu 1DES/3DES/DVB/Multi2/AES descrambler
• V.92-capable soft modem with integrated SiLab Si305x system side device • modem V.92-capabil, cu soft integrat SiLab Si305x dispozitiv de sistem pe partea
• Dual USB 2.0 host controller with host transceiver • Dual USB 2.0 controller gazdă cu transceiver gazdă
• Additional host/client USB 2.0 controller/transceiver • gazdă suplimentare / client USB 2.0 controller / transceiver
• Dual Ethernet MACs with integrated single PHY and MII • MACs Dual Ethernet PHY integrat cu o singură şi MII
• UHF remote control receiver • UHF telecomandă receptor
• Dual SmartCard support • Suport Dual smart card
- Vu + Ultimatium (Primo) - Triple-Tuner, cu unul plug and play.
specifcatii inca nu am vazut, decat basme legate de 4xcarde readere, enigma3, si altele la nivelu asta.
