In curand o noua imagine e2 RSP
Noutati:
- stm23_0123
- player2 179
- eplayer3
- rezolvat bug-ul "high bitrate"
Acum merge Media Player-ul din e2 cu filme MKV si AVI, cu codec H.264, divx, xvid si majoritatea codecurilor audio.
si altele !!!!
Noutati:
- stm23_0123
- player2 179
- eplayer3
si altele !!!!
multumiri maestre .... cu readerul intern vreo sansa ?
:clap: thanks!
:arrow1: thanks
I can't find the Link for E2.
Thx
Imaginea va fi publica in scurt timp.
I stripped version of mihaip and not working no picture on my tv??
e2 RSP Alien Beta 04
We would like to once again express our gratitude for all TDT and active "sh4_duckbox_project" mebers for their entire work that have open our way and guided us.
- stm23_0123
- player2 179
- eplayer3
- "high bitrate" bug resolved
- AC3 and DTS (when DTS downmix is OFF) forwarded to S/PDIF and HDMI
The new release main benefits are: the new media player playback smoothly all movie files and outstanding picture stability at all bitrates !
High fidelity sound fans are granted with AC3 and DTS (when AC3 downmix is OFF) forwarded to S/PDIF and HDMI.
The known unsolved bugs are :
- no output on the SCART
- no HD skins ...yet !
- some strange artefacts in video mode 1080i on Thor HD channels (use 720P or 1080P)
- the cardreader driver still in hold !
I can't find the Link for E2 beta 4
Thx
Just put your mouse over the name of the image [Only registered and activated users can see links. Click Here To Register...] and click the right mouse button. It is simple as ABC :)
Your download should start and you will get the rar file. The rest is simple and already in practice.
Good luck.
Only hdmi out on this version?
I now understand what you mean when you said scart:)
Will you be able to fix it in the next version?
Ty
I think there is no WebIF. I could't connect.
netstat -atn doesn't show port 80. Should I reflash?
Thx. Great Work!
Webif is accidentaly removed :(
stay tuned, beta4 v2 release with SCART and webIF will be available soon ....
Cum fac sa gaseasca conexiunea de net ? pentru ca wizardul imi spune ca "nu gaseste conexiune internet".
Daca se poate un pic mai detaliat la acest capitol atit cu DHCP pornit cit si oprit .
Ce punem la IP , Mask , Gateway si DNS lasam autoconfigurare sau facem ceva?
Cum downloadam emu sau facem upgrade?
Cu ce tools ne conectam la Enigma 2 ca pe spark am inteles Total commander dar aici?
THX anticipat din partea celor neinitiati inca.
In procedura de initializare ( Start Wizard ) alegeti oferta default ! cea cu
DHCP enabled ...si va fi bine ! la iesire veti gasi reteaua mergand si cu acces
la Internet !
Download de EMU din RSP Panel ..."ROSU" ...RSP Panel !
Client de FTP ...cel preferat !
Dar la nameserver 1 trebuie sa punem un IP anume ca la test spune ca not recognize.
La test network toate sunt pe verde iar ultimul nameserver 1 pe rosu , e ok asa?
Client FTP inseamna ca tot total commander da?
la nameserver pui dns-ul din router
Am facut asa cum spuneti voi dar cind incerc sa downloadez emu din RSP panel spune check network si ramine asa , de aia cred ca ceva nu e ok.
La test retea adaptor retea e verde , retea locala e verde , DHCP -verde , adresa IP verde si Nameserver rosu .
Nameserver e pus cu IP gateway .
Oricum thx pentru deranj@mihaip si@stargate
