Evolutie HD Glass, merge inclusiv pe BH 1.4.4.
download: [Only registered and activated users can see links. Click Here To Register...]
ultima versiune 2.21.
Aduc aici un link pt download direct [Only registered and activated users can see links. Click Here To Register...]
in arhiva am pus si un fisier postat de un baiat pe acel forum @xBenny care imbunatateste meniul , trebuiesc urmate directiile date de catre creator Backup your original skin.xml from /usr/share/enigma2/hd_glass16/skin.xml and copy modified skin.xml from attachments and restart GUI.
update imagini :
cred ca am gasit un bug: daca apas pe ok si dau sageata in sus sa imi arata lista cu canale aceasta nu apare, dar daca ma uit pe diplayul vu imi rata ca daca apas sageata in sus se skimba canalul (pe displai)si tre sa dau ok si se duce pe canalul indicat pe display , acu nustiu daca e un bbug sau daca e o kestie noua , dar eu nus obisnuit cu ea.
daca dau pe sageata in sus fara sa fie anterior apasat ok, totu e normal , se deskide lista de canale.
dar in mare e ok.
am descoperit un nou panel in acest skin care ofera informatii care arata ceva asemanator cu cu modu de expunere in imaginele BH
- Update of sat description
- Changed the piconProv of CSlink (piconProv by ftryskac, thx)
Working on VIX 2.0
fix for VU+ (BH 1.4.6)
HD Glass16 ver 2.61
HD Glass16 ver. 2.80
- fix channel number(converter), when channels with equal name are used in more bouquets (sat positions)
Download :
HD Glass16 ver. 2.89
- added delayed refresh and autocheck if osd is on for caid/ecm info - if caid info is available after tuned in channel
- fix cpu, hdd temperature
HD Glass16 ver. 2.90
- updated VirtualKeyBoard (thx petrkl12)
- small code optimalization
E2 Skin HDGlass ver. 3.12
*fix ecran verde la encodare UTF-8 in anumite imagini.
Download page:
succesuri! :drinks:
- 2nd code optimalization, messages correction
un nou skin hd glass 16.
vad ca piconu pt focus sa skimbat dupa ceam skimbat skinu acum e free sat:)
download mai jos:
HD Glass16 ver. 3.61
- fix gbox ecm parsing
- added a new user screen: side bar consistent with enhanced bar, but is activated press 2xOK, enhanced infobar is automatically disabled (not blocked!!!)
- added bitrate limiter - set in the range 15000 to 40000 kb/s - after exceeding the limit bitrate will automatically stopped
- added help in the setup - downloadable from the server - 8 button - automatically activated for each item and value in the setup
- added support BH 1.6.6 lower unsupported
- in a special Screene: changed TP values from hex to hex/dec
- update piconProv (thx ftryskac)
Download :
a testat cumva cineva acest skin pe Dream 8000 ?? cu Nabilo images
ptr. ca am mai avut eu instal un HD Glas - si nu a mai pornit boxa - tot mi-a dat error
Daca ai imagine veche gen nabilo trebuie sa instalezi o versiune mai veche a acestui skin.
eu folosesc Black Hole 0.12 de cind a iesit -
pe mine m-ar intere acest Skin doar ptr. ca arata Sidurile :)
la ora actuala am Black Shadow - care imi satisface
am facut update la ultima varianta a accestui skin (3,63) folosind optiunea de check update.
totu a mers foarte bine si rapid. nu vad nici o mare diferenta dar poate o ssa vad in timp....
deci functioneaza, si e mai elegant asa...
HD Glass16 ver. 4.10
- added picon black to download menu (CZ/SK channels only)
- fix refresh of the piconProv - DVB-T and DVB-C tuner type
HD Glass16 ver. 6.31
added support of HBBtv detection(dynamic icon) - OE 2.0 images - min. from 11.7.2012
- added forced update emm icons if reading failed
- added screen 32
- previews and extrascreens graphics updated in download
Update is available online via setup
