Enigma2 NightlyBuild 1.1.1 for all versions
ENIGMA 2 for all Cuberevo-digital (old DGStation named) products:
- cuberevo-100hd
- cuberevo-mini-fta (cuberevo-200hd)
- cuberevo-250hd (ipbox-91hd)
- cuberevo-mini (ipbox-900hd)
- cuberevo-mini2 (ipbox-910hd, cuberevo-3000hd, madtek-3000hd)
- cuberevo-2000hd
- cuberevo-9500hd (cuberevo-7000hd)
- cuberevo (ipbox-9000hd rel1 and rel2)
Coder: Tideglo
First boot take a little bit much more than a normal boot, so wait until you can see the bandeau bar (the one with infos on current channel) on the tv screen.
HISTORY:
release 1.1.1
- fixed the bug that causes crashing on enigma2 during pixellation/freeze (call it as you like)
- fixed network setup crashes with standard skin
- fixed green button-aspect ration function
- updated to 02/01/2011 enigma2 cvs
- fixed no audio on channel switch on few cases (i can't fully test this, so report if it happens again)
- fixed audio crop on some televisions (when you hear crop-crop-crop on channel switching)
- added support for AVS file codec
- many other fixes for better code and stability and to prevent crashes
I made a full reset of the buglist (because of the new structure), so start thinking like the needs to report also old bugs if you find them again
Enjoy it! Tideglo
Informatii utile pentru cea mai stabila imagine
Ca sa mearga automat oscamul sau ce emu lasati pornit cand dati restart trebuie ca dupa ce ati instalat emu manager sa copiati linia :
/usr/lib/enigma2/python/Plugins/Extensions/EMUmanager/emustarter.sh
la sfarsitul fisierului /etc/default/rcS
linia e copiata din fisierul rcS care vine cu emu manager numai ca calea din emu manager era /etc/rcS nu etc/default/rcS .
Daca vreti sa folositi swap la imagine editati fstab incat sa fie:
/dev/sdaX none swap sw
incat X-ul sa reprezinte partitia care o aveti ca swap.
