Am un card Akta conax dream 500 Cccam 2.2.1 si nu-l deschide cum sa fac sa il vada?
Ma rog trebuie sa scrii si ce imagine intrebuintezi. Eu am gemini 4.2 pe soleron (clona lui dm500s) si merge cartela de focus sat care la fel e in conax cu cccam 2.1.4.
merge si cu cccam 2.0.11 si 2.1.3, pe care a mers la mine.
Folosesc gemini 4.7 originala
pune in CCcam.prio linia asta :
P: 0b00:000000 # Max TV
sa fie prima
Am pus nu functioneaza
pune aici CCcam.cfg si CCcam.prio ... inainte sterge din ele liniile si parolele , nu uita sa-ti faci un backup la ele .
SERVER LISTEN PORT : 12000
WEBINFO LISTEN PORT : 16001
#WEBINFO USERNAME : root
#WEBINFO PASSWORD : dreambox
AU = yes
SMARTCARD CLOCK FREQUENCY: /dev/ttyS3 8000000
DISABLE EMM : no
B: /dev/sci0 00
B: /dev/sci1 00
BOXKEY: /dev/sci0 00 00 00 00
#PHOENIX READER PATH : /dev/tts/0
CAMKEY: /dev/sci0 00 00 00 00 00 00 00 00
CAMKEY: /dev/sci1 00 00 00 00 00 00 00 00
#CAMKEY: /dev/tts/0 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CAMDATA: /dev/sci1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
#CAMDATA: /dev/tts/0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
#SMARTCARD CLOCK FREQUENCY: /dev/sci0 6000000
#SMARTCARD CLOCK FREQUENCY: /dev/sci1 6000000
TRY ALL CHIDS : /dev/sci0
#SMARTCARD CLOCK FREQUENCY: /dev/tts/0 8000000
#TRY ALL CHIDS : /dev/tts/0
TRY ALL CHIDS : /dev/sci1
cccam prio
# in this file you can configure what CAIDs CCcam should prefer or ignore
# defaults to /var/etc/CCcam.prio
# file content can have ignores (I) and prio lists (P)
# situation 1: ignore allways this caid, all idents, on all channels
# I: caid
# situation 2: ignore allways this caid/ident pair
# I: caid:ident
# situation 3: ignore this caid/ident pair, on channel 'sid'
# I: caid:ident:sid
# situation 4: when both caid1 and caid2 exist for a channel, prefer caid1 over caid2
# P: caid1, caid2
# situation 5: when caid1:ident1 till caidN:identN exist for a channel, use them in order of this list.
# P: caid1:ident1, caid2:ident2, .., caidN:identN
# situation 6: when caid1:ident1 till caidN:identN exist for channel 'sid', use them in order of this list.
# Sid on first caid/ident pair identifies sid for which list is used. All other sids ignore this list.
# P: caid1:ident1:sid, caid2:ident2, .., caidN:identN
#CAID PRIO FILE : /var/etc/CCcam.prio
CCcam.cfg
CCcam.prioCode:#################################################
###### CONFIGURARI CCcam ######
######************* C+F lines ###
C:
F:
###### LINII NewCamd & ######
N:
######************* General parameters ###
SECA HANDLER: 2
SERVER LISTEN PORT: 12000
WEBINFO LISTEN PORT: 16001
WEBINFO USERNAME : user (nu root)
WEBINFO PASSWORD : pass (nu dreambox)
DISABLE EMM: yes
DEBUG: yes
SHOW TIMING: yes
SHOW EXTENEDED CLIENT INFO : no
ALLOW WEBINFO: yes
#SMARTCARD SID ASSIGN : /dev/sci0 0 { }
#************* E N D ***********************#
Nu folosi in Cccam.cfg setari inutile, limiteaza aceste setari strict la cardul si slotul pe care il folosesti la citirea cardului.Code:P:0b00:000000 #Akta
Cardul merge in alt receptor, are update la zi ?
CCcam ruleaza, deschide canale din net?
Sal am pus config. trimise de tine si tot nu funct. cardul in rec original funct. cccam la mine lucreaza deschide in hop1 am imagine gemini 4.7 cccam 2.2.1
Nu deschide sau nu il vede ... in CCcam.info la Entitlements arata info despre card, vede cardul in slotul intern la DM ?
In CCcam.info la Entitlements vede info despre card cu cine am schimb de linii ma vede cu card dar nu deschide de pe el
card reader /dev/sci0
handled 15(0) ecms and 0(0) emms
Conax card
Caid b00
id name date
1010 DCS 01.01.11-31.01.11
21.01.11-26.01.
Apasa buonul " Reply to Thread" si nu "Reply With Quote
@remi mihai
Tu ai pus si card readerul ( slotul )de unde sa citeasca ?
Va rog cine are card akta conax pe dream sa i-mi trimita si mie configurarile din cccam config va multumesc
chiar daca cardul e platit.... ca sa mearga in dm ,incearca mai intii sal introduci intr-o conserva cu viacces incorporat dupa ce sa activat, tocmai atunci il poti pune in dm ....:)daca il pui in dm fara sa procedezi miscarile de mai sus ....dreamul va recunoaste cardul fara ca clientul sa poata vedea nimic ...... introdul mai intii in-tro conserva cu viacces incorporat si mai discutam ...in rest toate cele bune...:).succes...:)
S-ar putea sa aibe nevoie de Au. Oricum @soarece cardu e conax, scrie de citeva ori asta.
Daca cardul e vazut online si nu deschide cred ca a mai ramas sa rezolvi cu update-ul.....
Originally Posted by soarece [Only registered and activated users can see links. Click Here To Register...]
soarece daca nu te pricepi nu mai du lumea in eroare
poate se da omul peste cap sa faca rost de receptor care sa aiba viacces incorporat si cand colo lui ii trebuie conax :lol:
posibil sa fie de la update , dar poate si de la cccam prio , mai bine sterge prio si chanel info si vezi ce se intampla , posibil sa fie si de acolo
nu derutez pe nimeni ...akta are metoda de criptare ...viacces 2.5 si conax... un foarte bun prieten a cumparat o cartela akta fara receptor..a venit la mine si culmea camul t-rex nu mi-o deschidea..surpriza a fost mare in momentul in care i-am sunat si cei de la reprezentanta ne-au indicat sa-o introducem intr-un risaivar deal lor deci risivar cu viacces incorporat .....dupa ce am facut operatiunea camul deschidea din start programele akta ...cam t-rex predator 4.32 asa ca nu ma vorbiti aberatii... am peste 20 de ani experienta in domeniul sateliar:book::tv: iar a doua la mina eu unul nu am vazut ...risivar de la akta sa scrie pe el ...risivar conax incorporat ..viacces da dar conax nu:tv:
20 de ani?
Multumesc mult la toti care au incercat sa ma ajute am reusit doar schimband cardul pe viaccess nu am inteles dece cardul de conax nu a funct doar cardul alb ca cardul vechi cu portocaliu a functionat
Salut ,
Imi poti face un abonament cccam.cfg ?
merci
Originally Posted by remi mihai [Only registered and activated users can see links. Click Here To Register...]
