Coduri De Deschidere Meniul
1111-1004 AZTECH
8175 ASTERIX/DIGIBOX
8175 BESAT
8503 DAEWOO
0851-1004-3472 DIGITAL TELECOM
1324-1424-1524-1624 DRUCK
8503 D -WAY
7604-3453-2441-3604 ECHOSTAR
1002-2228 FORTECSTAR
9949 GALAXIS
Menu- installation-ok-status-ok-STB status-ok then press on the following buttons-RED-GREEN-YELLOW-BLUE-WHITE- then press 0 now ur receiver is 0000 HUMAX 5400 & SOME OTHERS
Menu - status -STB Status - ok -press UP button at the front panel - i - press the button contain ( ? ) – press yellow button - exit now ur receiver return to 0000 HUMAX F1-C1
0325 HYUNDAI
1250 LORANS
1631-6805 NEOSAT
0600 and OTHER Standby with prog from remote now clear memory press now 0500 NEXTWAVE
147258 NOKIA 9200
press the two key on receiver front panel plus standby from the remote now the code will reset to default NOKIA 9600
menu system configuration type 1 on the 4th Digit press red button enter the following number 7258 - ok now the password go back to 1234 NOKIA 9800
3472-0937 OPENTEL
3472-2374-7176-2606-1470-2441-3724-1250-6893 SANYOSAT
0937 SAMSAT
1631-9911-7777 SAMSUNG
menu - system setup - system information - 0000
SAMSUNG DSR -9000&9500
1004 SKY
3472-6934 SMART
1361 – 1999 – and some other press menu installation
ok STB ok press 9876 STARSAT/STARCOM
1361 – 0735 – 0235 - 0325 STRONG
1250 PENGAMIN
3472 - 2374 -7176 – 2606 – 1470 -2441 - 3724 – 1250 TECHNOSAT
7176 - 1973 TELEMAN
2999 - 2606 TOPFIELD
1048 TOSHIBA
2002 - 7777 VORTEC
8888 ZINWELL
menu installation ok STB ok press 9876 EMTECH/JESSPEN
0103 SKY X
0867 OR 0786 DIGITAL MODEL 200-2003
1361-0735-0235-0325 STRONG
Hyundai 0325 / 6962(Information Code)
Telecom 0851 / 1004 / 3472
Aston Simba 6787
Sanyosat 3472 / 2374 / 7176 / 2606 /
Eurostar 9999
Benjamin 1250
Topfield 2606
Opentel 0937
Digital Telecom 3472/0786/0867/0851/1004
Starcom 9876
Besat 8175
Eurostar/Eurobox Menu+9999+OK--->0000
Signal777-->System information-->9876-->0000
Smart 3472 /6934
Vortec 2002
Galaxy 9949
Dy 8503
Echostar 3453 /3604/7604
Lawrance 1250
Digital 0325/ 0867 / 0786
Winnersat 0963
Fortecstar 1002 / 7777
Strong 0235/ 0735/0325
UnedinUST4800 3315 / 3578/ 8570
Toshiba 1048
Starport 8175 (?)
Drek 1324/ 1424 / 1524/ 1624
Chaprral 2345
Comunication DSZ200 6789
General 92121
Kenwood KSR-1000 9999
Panasonic CDR4500 3872
PS-700EX 5172 / 3872
EmTech 9876
Houston 7907878 / 9080112 /2226903 /9429
Technosat 3724
Nokia 1234 / 147258
Teleman 7176
Samsung 9911 /1631 /7777 / 0000
Strong4400 1631
Strong 0735
Free Star 0509
Galaxy 9949
EchoStar 4532, 3453
TopField 2606
Laurence 1250
UEC 9949 / 1234 / 1111 / 9999
TechoSat 6805
FujiSat 8761
Re: Coduri De Deschidere Meniul
foarte util.multumim frumos,nu cred ca e pus un general satelit 7001s ca e compatibil cu digi-1981
Daca lipseste ceva ce nu este scris,este bun venit scris aici.Asa se ma raresc din intrebari.Cum fac?Care este? sau Cum deschid?
Eu daca mai gasesc am sa mai adaug.
Digital Opticum/chess/GLOBO4xxx/Opticum7xxxA
4000A / 7000A / 7100A / 7010A / 7010APlus / Black Widow / Megasat2000 / IDTE2040/BAFF4000+
9339-menu key
receptor-winquest daca nu mai decodeaza nimic pui in meniu 7799 si apare o casuta (code edit)
cu meniul secret 7799 poti sa modifici providerii ( pt tipul de codare irdeto ,biss,pt nagra 1 si 2,viaccess si crypto ) si la DSR 5003 ,dar cred ca e soft de coship pe el
PS: merge si 1* W
Strong 6350
menu - system setup - system information - scri 88 si se deschide meniul de key
Strong 6350
Mersi de post,parca erau 4 de 8?
Este suficent de doua ori 8
stie cineva cum bag codul de deschidere meniu la Hyundai 2tv
2 Attachment(s)
sunt de pe la turci niste coduri poate va ajuta si in documentele atasate si mai jos
Next & NextStar Cihazların Emu Açma
Master Kodları
Next Super Plus Serisi Master Kod: 8503
Next Super Plus Serisi Emu Açma Kod:
Menu –Cihaz Bilgisi-Kırmızı-1234 İle Açılır
Next Plus Serisi Emu Açma Kod:
Next Plus Serisi Master Kod:8503
Next 9000 Serisi Master Kod :4132
Next 9000 Serisi Emu Açma Kod: Menu-Cihaz Bilgisi-1973-Bilgi Yazısı Yeşil Olur Emu Aktif Olur.
Key Menusune Giriş: Kanal Üzerinde Mute Exit Key Menusu Gelir …
Next 8000 Serisi Master Kod: 4132
Next 8000 Serisi Emu Açma Kod: Menu-Cihaz Bilgisi-1973-Bilgi Yazısı Yeşil Olur Emu Aktif Olur.
Next 5000 Serisi Master Kod: 1234 Yada 1004.
Next 7500 Serisi Master Kod : 1004
Next 7500 Sersi Emu Açma Kod : Lisan Ayarları Kırmızı 2528.
NextWave 6000 Serisi Master Kod : 8888
NextWave 6000 Sersi Emu Açma Kod : 7799
NextWave 10000 Serisi Master Kod : 1250
NextWave 10000 Sersi Emu Açma Kod : 7799
Stiu codul pentru NETA BLUE 110 dar poate cineva sa-mi spuna unde sa-l tastez. MS
de obicei este compus din combinatia de taste :
menu+ acel cod
sau poate e master cod , care defapt e un fel de parola de deblocare daca ai uitat parola sau cineva a pus o parola si tu nu stii cum sa il deblochezi
menu+ acel cod
Troya
Cod Fabricatie : 1234
Master Password : 1630
Intrare in Menu key : 0-Epg
TROYA II
Cod Fabricatie : 0000
Master Password :3333
Intrare in Menu key : 0-Sat
Alte Versiune Neta
Master Password : 5943
1 Attachment(s)
All Master CODE Prog
Password la program : love
se selectioneaza receptorul si iti va aparea Codul Master al receptorului ales pentru a intra in meniu
Alte coduri unele oate sau mai scris
ALL RECIVERS MASTER CODE:
starsat X5 New :...............:9876
hi-tech-------: 8175
Next NORMALL ….…………. 0000
titanum :------8191
Next 1000 * Star 1 ……………..5183
Next 1001 Plus * Kyoto Panel ….3453
Next 3000 A…….……………….0000
Next 3000 AP.…………………...0000
Next YE 5000 ..………... 1234 & 1004
Next 8000 X Cam.……………….4132
Next Black……..………………...0000
Next Plus....….…………………..8503
SUPER MAX.……………………8503
SUPER MAX + EMULATOR.…..5790
aGoldmaster SAT-90400.........: 3453
Goldmaster SAT-7200 FTA......: 2606
Goldmaster SAT-7300 CI.......: 2606
Goldmaster SAT-7400 CIM......: 2606
Goldmaster SAT-7800 PVR......: 2606
Goldmaster SAT-4150 FTA......: 2606
Goldmaster SAT-4100 FTA......: 2606
Goldmaster SAT-4800 PVR......: 2606
Goldmaster SAT-9200..........: 2606
Goldmaster SAT-9400 CI.......: 2606
Goldmaster SAT-9500 CIM......: 2606
Goldmaster SAT-9600 CIP......: 2606
Goldmaster SAT-9800 PVR......: 2606
Goldmaster SAT-9900 PVR......: 2606
Goldmaster SAT-8150 FTA......: 3141
Goldmaster SAT-8200 FTA......: 3141
Goldmaster SAT-8210..........: 3141
Goldmaster SAT-8300 CI.......: 3141
Goldmaster SAT-8350 CI.......: 3141
Goldmaster SAT-8400 CIM......: 3141
Goldmaster SAT-10200.........: 3141-9247
Goldmaster SAT-10210.........: 3141
Goldmaster SAT-11300 CI......: 9247
Goldmaster SAT-16000 ........: 1600
Goldmaster SAT-16300.........: 1600
Goldmaster SAT-16500.........: 1600
Goldmaster SAT-17000.........: 1700
Amstrad Silverline...........: 3472
Amstrad Cromline.............: 0000
Baftec 8008 Dragon...........: 1668
YuMaTu x-200.................: 8888
YuMaTu 9500..................: 8503
YuMaTu 5500-8000.............: 2441
Pace.........................: 9949
Nokia 9800-9860..............: 1234
Nokia 9200...................: 147258
Nokia 9600...................: 1234
Eurostar.....................: 9999
Urobox.......................: 9999
Kyoto........................: 3453
Next Wawe....................: 8503
TechnoSat....................: 3724
Botek........................: 5183
Botech 2000-2001 ci..........: 4200
Digitel......................: 0867 - 0786
Roadmaster...................: 7787
Taplin.......................: 3453
Strong.......................: 0235 - 0325
Strong FreeCam...............: 0235 - 0735
Benjamin.....................: 1004 - 1250
Echostar.....................: 7604
EchoStar.....................: 3453
EchoStar 2200-1200...........: 7604
EchoStar 2110................: 3453
Opentel......................: 0937
Sunny........................: 2580 - 7777
Radix........................: 9815
Hyundai......................: 0325 - 6962
Baff.........................: 2142
SanyoSat 5400-5700-7000......: 3472 - 2374
SanyoSat Viaccess............: 7176
SanyoSat (Plus) 5000-9000....: 2606
Galaxy.......................: 9949
Tokyo........................: 3472
Dizipia......................: 2142
Wisplus......................: 5030
Redliner 9500 CI.............: 1001
Harward HR-301DA.............: 3472
1 Attachment(s)
[QUOTE=Turku;56939]Alte coduri unele poate sau mai scris
