Could anyone confirm the settings for using a Smartgo Smartreader plus for use with Oscam on RSP image.
FTDI driver is included in latest images.
Thanks Zildan, i'm using RSP V3.128, Smartreader version 1.3
Now getting the followingMy oscam.server isCode:-------------------------------------------------------------------------------
>> OSCam << cardserver started at Mon Sep 6 11:46:02 2010
2010/09/06 11:46:02 783 s version=0.99.4svn, build #2974, system=sh4-amino-linux, nice=-10
2010/09/06 11:46:02 783 s max. clients=29, client max. idle=120 sec
2010/09/06 11:46:02 783 s max. logsize=500 Kb
2010/09/06 11:46:02 783 s client timeout=5000 ms, fallback timeout=2000 ms, cache delay=120 ms
2010/09/06 11:46:02 783 s shared memory initialized (size=497258, fd=3)
2010/09/06 11:46:02 783 s auth size=4772
2010/09/06 11:46:02 783 s services reloaded: 0 services freed, 1 services loaded
2010/09/06 11:46:02 783 s userdb reloaded: 0 accounts freed, 1 accounts loaded, 0 expired, 0 disabled
2010/09/06 11:46:02 783 s signal handling initialized (type=sysv)
2010/09/06 11:46:02 783 s can't open file "/var/keys/oscam.srvid" (err=2), no service-id's loaded
2010/09/06 11:46:02 783 s can't open file "/var/keys/oscam.tiers" (err=2), no tier-id's loaded
2010/09/06 11:46:02 783 s can't open file "/var/keys/oscam.provid" (err=2), no provids's loaded
2010/09/06 11:46:02 783 s monitor: disabled
2010/09/06 11:46:02 783 s camd 3.3x: disabled
2010/09/06 11:46:02 783 s camd 3.5x: disabled
2010/09/06 11:46:02 783 s cs378x: disabled
2010/09/06 11:46:02 783 s newcamd: disabled
2010/09/06 11:46:02 783 s cccam: disabled
2010/09/06 11:46:02 783 s radegast: disabled
2010/09/06 11:46:02 783 s logger started (pid=784)
2010/09/06 11:46:02 783 s Resolver thread started
2010/09/06 11:46:02 783 s http started (pid=786)
2010/09/06 11:46:02 783 s reader started (pid=787, device=001:005, detect=cd, mhz=357, cardmhz=357)
2010/09/06 11:46:02 783 s waiting for local card init
2010/09/06 11:46:02 786 h HTTP Server listening on port 84
2010/09/06 11:46:02 787 r02 Found smartreader device 001:005
2010/09/06 11:46:02 787 r02 card detected
2010/09/06 11:46:06 787 r02 ATR: 3F FD 13 25 02 50 00 0F 33 B0 0F 69 FF 4A 50 D0 00 00 53 59 02
2010/09/06 11:46:06 787 r02 Maximum frequency for this card is formally 5 Mhz, clocking it to 4.80 Mhz
2010/09/06 11:46:07 787 r02 [videoguard2-reader] type: VideoGuard BSkyB (0963)
2010/09/06 11:46:07 787 r02 card system not supported
2010/09/06 11:46:07 787 r02 Normal mode failed, reverting to Deprecated Mode
2010/09/06 11:46:10 787 r02 ATR: 3F FD 13 25 02 50 00 0F 33 B0 0F 69 FF 4A 50 D0 00 00 53 59 02
2010/09/06 11:46:11 787 r02 Maximum frequency for this card is formally 5 Mhz, clocking it to 4.80 Mhz
2010/09/06 11:46:12 787 r02 [videoguard2-reader] type: VideoGuard BSkyB (0963)
2010/09/06 11:46:13 787 r02 card system not supported
2010/09/06 11:46:13 787 r02 card initializing error
2010/09/06 11:46:13 783 s init for all local cards done
2010/09/06 11:46:13 783 s anti cascading disabled
2010/09/06 11:46:13 783 s dvbapi: initialized (pid=789)
2010/09/06 11:46:13 789 c01 plain dvbapi-client 127.0.0.1 granted (kathy, au=0)
2010/09/06 11:46:15 789 c01 dvbapi: [ADD PID 0] CAID: 0960 ECM_PID: 0508 PROVID: 000000
2010/09/06 11:46:15 789 c01 dvbapi: [ADD PID 1] CAID: 0961 ECM_PID: 0508 PROVID: 000000
2010/09/06 11:46:15 789 c01 dvbapi: [ADD PID 2] CAID: 0963 ECM_PID: 0508 PROVID: 000000
2010/09/06 11:46:15 789 c01 dvbapi: new program number: C7A9 (0960:C7A9 unknown)
2010/09/06 11:46:15 789 c01 kathy (0963&000000/C7A9/75:B631): rejected group (129 ms) ()
2010/09/06 11:46:15 789 c01 kathy (0960&000000/C7A9/75:B631): rejected group (129 ms) ()
2010/09/06 11:46:15 789 c01 kathy (0961&000000/C7A9/75:B631): rejected group (129 ms) ()
2010/09/06 11:46:15 789 c01 dvbapi: try pids again #1
2010/09/06 11:46:18 789 c01 kathy (0963&000000/C7A9/75:A1D0): rejected group (129 ms) ()
2010/09/06 11:46:18 789 c01 kathy (0960&000000/C7A9/75:A1D0): rejected group (129 ms) ()
I already had it working connected to a cccam server on another local receiver, just want to get it working locally as wellCode:[reader]
reconnecttimeout = 5
label = remote
protocol = cccam
device = 192.168.0.9,12000
account = kathy,password
group = 1
caid = 0963
cccversion = 2.1.4
enable = 0
#cccbuild = 3191
[reader]
label = mysmartreader
protocol = smartreader
device = 001:005
aeskey = 0102030405060708090a0b0c0d0e0f10
group = 1
caid = 0963
boxid = ####### (my boxkey from cccam here)
#mhz = 357
#Cardmhz = 368
EMMCache = 1,3,2
blockemm-u = 0
blockemm-s = 0
blockemm-g = 1
blockemm-unknown = 0
#detect = CD
enable = 1
After restarting the log now has a lot of these entries:-
r02 usb bulk write failed : ret = -1
Try tu use list_smargo-sh4-amino .
Output from list_smargo
./list_smargo-sh4-amino
bus 001, device 004 : 0403:6001 Smartreader (Device=001:004 Serial=?)
In my oscam.server above it was 5, because i'd unplugged it and put it back, got device using :-
cat /proc/bus/usb/devices
Do i need insmod $MODDIR/ftdi.ko in start.sh, currently
Code:mknod /dev/ttyUSB0 c 188 0
chmod 666 /dev/ttyUSB0
insmod $MODDIR/usbserial.ko
insmod $MODDIR/pl2303.ko
For some reason my start.sh is not being processed, if i try
. /var/config/start.sh
i get the following error:-
Kathy_RSP:/var/config# . /var/config/start.sh
-sh: .: line 1: can't open /var/config/symlink
The file is there it contains
SYMLINK="/usr/lib/enigma2/python/Plugins/Extensions/Fantastic"
Whilst looking at the file, i think it only loads usbserial if newcs is used, dont know enough about linux to tell properly.
Zildan, will there be a new RSP Image released soon, as my start.sh is messed up so i will need to re-install
Am Smargo setat pentru tvr conectat la un port usb in spatele receptorului cu RSP 3.128 cu oscam care functioneaza ca si client dar nu deschide tvr hd de pe card
[reader]
label = ReaderExtern
#enable = 1
protocol = mouse
device = /dev/ttyUSB0
#ecmcache = 1
emmcache = 1,3,2
detect = CD
#showcls = 20
#maxqlen = 128
Group = 2
services = tvrhd
mhz = 357
caid = 0500
ident = 0500:025900,025910,00000,fff720
#lb_weight = 200
2010/09/12 11:56:08 489 r05 ERROR opening device /dev/ttyUSB0
2010/09/12 11:56:08 489 r05 Cannot open device: /dev/ttyUSB0
vezi in /dev poate nu-l vede sau il vede altfel decit /dev/ttyUSB0
Si de ce " #enable = 1" ?
in /dev nu am ttyUSB0 doar ttyAS0..1,2,3,4
Pai atunci daca nu-l vede....
Nu am priceput ce receptor ai, poate iti trebuie drivere...
Kathrein cu imagine RSP 3.128 care are drivere
@dorin55
Panelul era "croit" sa puna driverele doar daca ai newcs instalat.
Descarca din installer Newcs si da un restart.
Lucrez la imagine si o sa refac si partea asta.
multumesc,am acum in /dev , ttyUSB0 ,deci vede smargo dar oscam tot nu citeste cardul,
Salutare,
Mi-am luat un smargo plus dar nu reusesc sa-l configurez pe oscam pe rsp imagine in kathrein910 .Am card de tvr.
Cineva care sa ma ajute?
in panel rsp :enable ftdi
######## oscam.conf ############
########## oscam.server ###########Code:[global]
Nice = -1
ClientTimeout = 7
FallbackTimeout=3
ClientMaxIdle=120
CacheDelay = 100
BindWait = 5
ResolveDelay = 15
WaitForCards = 1
PreferLocalCards = 1
LogFile = stdout
#LogFile = /var/keys/oscam.log
PidFile = /tmp/oscam.pid
#usrfile = /var/keys/oscam_usr.log
[webif]
httpport = 84
#httpuser = root
#httppwd = oscam
httpallowed = 127.0.0.1,192.168.0.0-192.168.255.255
[monitor]
appendchaninfo = 1
nocrypt = 127.0.0.1,192.168.0.0-192.168.255.255
[dvbapi]
enabled = 1
user = dvbapi
boxtype = ufs910
au = 1
priority = 0500:025900,1880,1802,0963,0B02,0100:003311,093B,0100:1F1F1F
ignore = 0500:040810
########## oscam.user ###########Code:[reader]
label = ReaderExtern1
protocol = mouse
emmcache = 1,1,2
detect = CD
Group = 1
services = tvrhd
mhz = 357
caid = 0500
deprecated = 1
#### bei seriellem Reader anstatt SMARGO auskommentieren ######
smargopatch=1
##################################Code:[account]
user = dvbapi
pwd = dvbapi
au = ReaderExtern1
uniq=0
group = 1
caid =
Cum enable ftdi ,unde anume in menu?
RSP Kathy TEAM Menu/USER OPTIONS/USB Drivers/ENABLE FTDI
RSP Kathy TEAM Menu > USER OPTIONS> USB Drivers > enable USB2Serial
apoi
RSP Kathy TEAM Menu > USER OPTIONS> USB Drivers > enable FTDI
Merci mult de ajutor , am reusit pina la urma ,a trebuit sa incarc rsp imaginea din nou ca se bloca la user menu , apoi dupa o gramada de restart am reusit!
Multumesc la toti de ajutor......................Zildane............palaria jos!:clap:
