Am facut acest nou thread pentru plugins,va rog sa postati aici ce apare nou,multumesc!
Cine poate sa-l puna la Sticky,multumesc!
Plugins: HackSat Keys Downloader v5
Choose which keys you would like to download, i think it is for all dreamboxes,now i have installed on DM500s with Nabilo s/w..
just send the files to var/tuxbox/plugins and put them at 755 tribute. thats it,,
then click on blue buttom (Gemini) and press ok on the plugin from their and choose which keys u like. within few seconds it is updated
In sfarsit ceva nou si fff bun!,probat merge excelent!
Descarca de aici:
downloaded all time updated keys
mgcamd keys (SoftCam.Key AutoRoll.Key tps.au files)
evocamd keys (Keylist.txt and Autoupdate.Key files)
newcamd keys ( rsakeylist and keylist files)
gxxx keys (nagra key file)
camd3 keys (camd3.keys file)
DreamboxRSS_NewsRoom cu siteul asta in el si fara alte lucruri inutile ar fi bun. Un Dreamcast tot asa cu programe romanesti in favorite.
serrabichos v.1.08
functionabil 100%
Ok - [+] Keys dos Server no web para os providers do Florikey
Ok - [+] Cams suportadas Camd3, MGCamd, Evocamd, CCam, Dccam, Gbox2.1, Gbox 2.2 e superiores, Scam3x
Ok - [+] Actualização automatica e manual dos ficheiros
Ok - [+] Posibilidade de ver as Keys do server "Florikey" e ver as Keys dos ficheiros das Cams
Ok - [+] Possibilidade Acesso VIP/Publico
Ok - [+] Actualizacao automatico do Plugin
[+]Novas Funcionalidades [-]Bugs Corrigidos [*]Melhorias
Blue Panel
Addons para instalar pelo Blue Panel:
Meter em /tmp e depois instalar pelo Blue Panel -> Addons -> Manual install
The first file is for dm 7020 ONLY
The seond file is for dm 500/600/7000 ONLY
Unpack the rar files, and you get 2 .gz files, then manually ftp the file you want to /tmp folder in your dreambox.
Attached Files [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] (315.2 KB) [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] (315.1 KB)
Acum il puteti da jos si pentru DM 500 de aici;
cred ca imaginile spun tot!
pai urca-l si pentru 7020 pe upload-ul nostru!Quote:
Pai lam urcat,este tot acolo unde este si DM 500
mersi!:)...Quote:
Originally Posted by outcast [Only registered and activated users can see links. Click Here To Register...]
Cu placere!
Il puteti da jos si de aici;
il puteti descarca de aici;
[Only registered and activated users can see links. Click Here To Register...]&
TV GUIDE PLUGIN
POGRAMUL SAPTAMANAL A 101 CANALE ROMANESTI SI STRAINE
MULTUMIRi!!!Quote:
Originally Posted by Sunt_Oltean74 [Only registered and activated users can see links. Click Here To Register...]
e cel mai tare plugin!:clap:
poate incerca cineva sa vada daca-i merge hack sat V.5 sau V.7?
la mine apare Hacksat site in progress si se blocheaza....la 11,45 - face asta si cu v5 si cu v7
multumesc!
da, merge cu v7bQuote:
Originally Posted by dragos [Only registered and activated users can see links. Click Here To Register...]
Merge,daca iti arata in progres si nu face nimic[se blocheaza] atunci verifica conexiunea la net ca asta e problema,el merge bine mersi,de fapt ambele versiuni!Quote:
acum merge si la mine ....conexiunea am verificat-o si pare ok.
am repus v7 si cel putin fata de azi dimineata e o schimbare...fiind pe mgcamd arata acum si keya ...ceea ce inainte nu o facea desi mergea...poate ca inainte aveam o problema .
multumesc!
HackSat Keys Downloader v8
whats new :
not news
only changed all keys address
and die all old versions
pls upgrade v8 for use this plugins
Attachment:[Only registered and activated users can see links. Click Here To Register...] (13 KB, 43 downloads
Sau descarcati de aici;
