Am si eu o problema cu un reciver kaon ksf 100 sco si nu reusesc sa ii dau de cap am incercat sa pun softul pe el dar imi da eroare
UPGRADE TOOL (V2.30) 22-MAR-2004 Patch
File open O.K.!
> Old version binary.
-. Target loader version :L 620
-----------> Front :: 74HC164 used (connector: 14pin)
-----------> Target 2M Flash.
-----------> Target AMD/ST FLASH(TOP).
Connect Success
// FileInfo: KAON-TEAM, H/W(FF.0C.FF), S/W(03.00.00)
// Target: L 620, u-C[0] , FLS[2M], KSF-100SCO, H/W(12.C0.A5), S/W(03.00.3C)
Target Model Mismatch : KSF-100SCO
Hardware Version Mismatch
Your DVB-S/T/C is not same !
MICOM Type mismatch !
CI/CAS Type mismatch !
HDD Type mismatch !
You got 5518-B parallel, cannot upgrade 5518-D serial.
-. STB Model : KAON-TEAM
-. STB H/W Ver : 12.C0.A5
-. STB S/W Ver : 03.00.3C
DownLoad Start
:>> flash not ok.
DownLoad Failed
:>> ERR: on STB->PC
Aveti idee de ce face asa sau puteti sa imi daci itro arhiva fostul si cu toate aplicatiile ce treb sa fac multumesc
