Echosmart 500s-clona DM 500
Teamul echosmart se pare a renuntat la ideea de a scoate ei echosmart pe linux si a renuntat la proiectul acesta si au clonat pur si simplu un receptor celebru si anume Dreambox 500 ca sa poata scoate un receptor pe linux
la elstar.ro a aparut oficial pe site
Code:
ECHOSMART Enigma 500s(~Dreambox 500)
[Only registered and activated users can see links. Click Here To Register...] Culoare neagra
- 250 MHz IBM PowerPC Processor (350 Mips)
- Linux Operating System
- 1 x Smartcard-Reader
- MPEG2 Hardware decoding
- Common available NIMs (DVB-S, DVB-C)
- V.24/RS232 Interface
- 100Mbit full duplex Ethernet Interface
- 2 LED status
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- full automatic service scan
- supports directly bouquet-lists (indirect unlimited)
- supports EPG (electronic program guide)
- supports multiple LNB-Switching control (supports DiSEqC)
- fully adaptable OSD in many languages (skin-support)
- SPDI/F Interface for GOGUtal bit stream out (AC-3 / DTS)
- 1 x Scart-interfaces (fully controlled by software)
DBS-Tuner:
Frequency Range 950 …. 2150 MHz
Signal Level - 65 dBm …. - 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK
Input Symbol rate 2 …. 45 Mbaud/s, SCPC / MCPC
FEC Viterbi and Reed-Solomon
Viterbirate 1/2, 2/3, 3/4, 5/6, 7/8, automatic assimilation
Roll-off Factor 35 %
Demultiplexing according ISO 13818-1
Video decoder:
Video Compression MPEG-2 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz
Video Formats 4:3 / 16:9
Footage 16:9, automatic assimilation for 16:9 TV-Device (over Scart)
Letterbox precolating for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output GOGUtal:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS,RGB,S-VHS over OSD selectable
Serielle Interface RS 232:
Typ RS232 bidirectional
Bitrate 115,2 kBit/s max.
Plug Connector SUB-D-9
Function Update of Firmware and Preprogramming
Ethernet:
100 MBit compatible, bi-direktional interface
LNB Power and polarisation:
LNB Current 500mA max. ; short-circuit-proof
LNB Voltage vertical < 14V without load, > 11,5V at 400mA
LNB Voltage horizontal < 20V without load, > 17,3V at 400mA
LNB shut-off at Standby-Mode
Count of active satellite position:
DiSEqC 1.0/1.2 SAT POSITION / SAT OPTION
DiSEqC - Rotor Control
Power consumption:
< 10W / 12V
Input voltage:
DC12V,alternating acurrent +/- 15%
Extern power supply:Input:
110-240V AC / 50-60Hz / 0,6A
Output:
12V = / 1A
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 195 mm x 130 mm x 40 mm
Weight: 0,6 kg
In Stoc - Pret - 295 Lei
Schimbarea imagini se face cu cablu utp,sau crossover .. cu aplicatia Dreambox Control Center sau cu FlashWizard...pentru ca nu raspunde la DreamUP..
asa ca..nu mai trebuie sa schimbi tranzistorul
De ce atata graba la schimbarea imaginii ???
De ce se grabeste toata lumea sa-i schimbe repede imaginea ?
Poate mufa aceea laterala functioneaza doar cu imaginea originala. Sigur nu va functiona pe o alta imagine, care este destinata receptoarelor fara acea mufa.
Nu ar fi mai indicat sa exerimeteze cei care au acest receptor si sa descopere ( poate gasesc indicii prin meniuri !!! ) la ce se foloseste acea mufa ??
:sorry::sorry:
