MRB312_10.02.07.zip KEY DIGITAL+ actualizate....
MRB307 for MR D+ fixed 13.02.2007 ..pentru reborn cu keyle din 13 feb
in curind reborn cu AU!
mrb 318.......d+ AU!!!
a aparut firm care citeste cartele originale nds..sky italia in matrix reborn!
editor matrix reborn...
a aparut mrb 309!!!
MRB 309 firmware (full dump) for MatrixCAM Reborn
Readme.txt - You are reading this!
mrb309.bin - Full binary file for CAS2 interface programming
mrb309.upd - Update file for PCMCIA/serial board method
Uload_software_flash.hex - Flash memory for Funcard5 and Funcard6
Uload_software_flash_FUN7.hex - Flash memory for Funcard7
mrb309_512_x_x.hex - EEPROM hex file for Funcard5
mrb309_1024_x_x.hex - EEPROM hex file for Funcard6
mrb309_2048_x_x.hex - EEPROM hex file for Funcard7
NOTE : Funcard/PCMCIA/serial board upgrade requires UCAS3.2 already in the MatrixCAM Reborn.
If you have ZCAS in your MatrixCAM Reborn, you need to change to UCAS3.2 using
zcas2ucas.zip package.
mrb309
- Aljazeera original smc activation ok
Enjoy!
regards
...pentru Matrix Reload nu ai nimic???
din pacate nu.....
mersi...imi vine sa dau cu el pe fereastra!!...dar n-as putea sa fac altceva din el???...un Reborn de exemplu??? :wink:
nu...doar din magic....dar cu reloaded poti sa-l pui in dsb 808 echostar si vezi d+---
da mersi!!!d+ e peste tot. :wink:
pai asta faci si cu reborn..doar ca are au...asteapta sa iasa bisscam... e in teste..si atunci vor merge toate
adica din doua sa fac unu??? :lol: ....pai n-as putea sa-mi cumpar altceva cu banii aia???Quote:
Originally Posted by outcast
nu te inteleg..iar esti distrat..spune clar ce ai si ce vrei sa faci...
pentru mondo...dupa cum ti-am spus se lucreaza la bisscam care e pentru toate matrixurile....
We are testing BISSCAM 1.1
ChangeLog:
+ D+ au
+ Added compatibility with UNIVERSAL CAM
+ Some internal optimization
maybe TPZ AU too, but this isn't sure, we have serious probem to handle clock operations
MRB 319 firmware pentru MatrixCAM Reborn
mrb319.bin - Full binary file for CAS2 interface programming
mrb319.upd - Update file for PCMCIA/serial board method
mrb319_512_x_x.hex - EEPROM hex file for Funcard5
mrb319_1024_x_x.hex - EEPROM hex file for Funcard6
mrb319_2048_x_x.hex - EEPROM hex file for Funcard7
HISTORY
mrb319
- Viaccess smartcard improvements
mrb318
- D+ AU
mrb316
- D+
are cineva un loader pentru laptop?
