Mbox Manager 1.64
05.09.2009
- Profile activation fix for AzBox
Mbox Manager 1.64
05.09.2009
vers 0.2
Small tool to manage your cccam and multicas data.
After succesfull installation, use the options tab to edit settings
for the ftp connection to your az box.
After that you will be able to upload / download / edit data from your box.
MaZ see. 2.0
Manager for AzboxHD by Morser
se poate programa inregistrarea
se poate edita lista de canale
- Added a button to telnet to the clipboard to copy the contents of text framed in the console window.
- Added the modification of satellites and transponders
- Ability to massive changes in satellites like putting selected satellites USALS motor mode or enable / disable the LNB feed.
- Ability to search our coordinates giving the name of our city or village.
- In the lists of favorites, if we try to add a channel that already, do not re-add.
- Added the copy to favorite channels or favorite lists complete and attach them to other lists (in the destination list must be the channel or did not stick).
- Added power also capture images from TV (no video, only static images)
- Added the creation and modification of reservations for recording
- Added a list of recorded programs with the ability to delete or download to your PC.
- Added multilanguage support (included with the Spanish, Portuguese, English, French, German, Italian and Serbo-Croatian)
MultiCASEdit v.1.2
Add:
- CCcam Status , get info of server status(on/off) and ecm info
- Edit Serever lines - now simply , you can add C: line
- Auto update of changes
trebuie sters versiuea anterioara,nu se suprascrie.
TuneAzBox v.2.2
- program for skinning the Azbox HD
Aveţi posibilitatea să modificaţi meniuri, fonturi, icoane, logo, vă puteţi crea deasemenea propriul skin şi sa-l impartasiti cu noi!!
Se dezarhiveaza si se ruleaza direct fara instalare, adaugat patch pentru interfata in limba engleza.
Testat fara probleme in 0.9.3686.
Download:
Code:http://www.fileshare.ro/1825548015.24
AZBox HD Remote Control (AZrctrl)
Version: 0.8.35
2009.11.28
Microsoft .NET Framework 2.0 (or later) is need.
Instalation: unpack and run.
Tested with Firmwares: 0.9.3911
Release History
Release 0.8.35
- Added capability to edit - and sort - channel category list (genre, country and provider).
0.9.2880a AZBoxEdit
Added:
Updated TPs for selected Satellite from KingOfSat
All Ch.Group - now you can move Ch.
Genre Group - you can add and remove from selected group and add,remove,rename Genre Group
Country Group - you can add and remove from selected Country group
Remember: One Ch. can be added only to one genre group and only to one Country Group !
Fixed:
Import from satellites.xml (from [Only registered and activated users can see links. Click Here To Register...] or E2) - OK
Improt from KingOfSatt - OK
Del Sat - OK
Add Sat - OK
Update Sat - OK
rgs,
telesat
AzBox Control Center - ACC - v 1.0 by telesat
Am facut versiunea in limba romana(tradus in proportie 90%), va rog sa verificati daca este ok. Fisierele trebuie copiate in C:\Program Files\telesat® . Daca aveti sugestile le astept. Luna viitoare trebe sa trimit versiunea finala lui @telesat pentru versiunea noua ACC.
TooL "TeChAZ" (per AZbox offline)
We have developed a simple tool to download files on your PC:
>>> Key.bin and new_biss.key (practically the softcam for azbox cam MULTICASA).
Usable by those people (few, but there are ...) who do not have them connected to the Internet AZ
and therefore can not use the TeChSat_AZK.
1) Unzip the folder TeChAZ.zip
2) enter the folder and launch the executable "TeChAZ"
3) Click the two buttons on the softcam (key and new_biss)
4) in the folder TeChAZ there are now new files
5) copy the files downloaded in the decoder / plugins / OpenXCAS / MULTICASA
by kanber_kav
instal...
Download MultiMenu.rar
Extract Azbox /PLUGINS/MultiMenu
all files chmod 755
(mgcamd info config)
MultiMenu change menu name
edit
/PLUGINS/MultiMenu/menuname.txt max 6 name
function change
Ultra edit script
/PLUGINS/MultiMenu/MultiMenu.sh
Azbox Plugins Download link
_http://www.mediafire.com/?nnjmnjuin0x
MultiCASEdit v.1.5
Add:
- NewCamd & CR ( in Spliter & CCcam TAB )
rgs,
telesat
I would like to say thanks with help of testing and creation of this Application to :
iPod ( NeotionBox ), Roger Rabbit, and all others who helped me to make this application.
This application dont contain any kind of Key's and nothing which is connected with illegal watching of Pay TV Channels.
This is just Cam Wizard which should help all beginners or normal users ( technicians, sellers in shops ) to set-up new AzBox HD without any problem.
It is up to you, end users, will You cross the legislative and Use this Installer in illegal operations.
rgs,
ToolBox AzBox HD 1.0 By Xonic
ACC - AZBox Control Center - v.1.1
Some minor and major bugs fixed.
Faster FTP transfer and bugs related with it - fixed.
added:
* Supprt for messages in cyrillic (Russian, Macedonian...) without installing localisation.
* Translation into other languages.
* Update od FW trough Internet: in Tools-1 section, FW, firts click on Update list and when you get FW list, click on the one you want to be installed in your AZ box.
Oniline FW update process: download, prepare, transfer in azbox and flashing process, beacause of that be patient i follow the messages.
* Loading and saving channel lists into AzBox - in section: Tools-2, Channel List
Everybody who has problem loading lists in AzBox and strange stufs like crazy mix after loading lists (besides that you have already erased unnecessary satelites.
this way you will get clear and clean list with that that you really want to have on your STB.
* Font installer - also in Tools-2
you can install/add system font and before that previewing how does font looks like - in small window on right.
* FAN - section Tools-2, Front panel
you can turn on/off FAN
* CAM Section, CCcam status - writing out name od the server added
* CAM Section, ECM info for MGCamd and MBox
* CAM Section, Edit/read MGcamd cfg files
* CAM Section, Edit/Read MBox cfg files
* CAM Section, list of currently available card with writing out names od providers for MGCamd
* CAM Section, list of currently available card with writing out names od providers for MBox
hxxp://rapidshare.com/files/353545518/ACC_v.1.1.rar
Il tool permette di avere una unica maschera da cui richiamare l'applicativo desiderato. Una volta installato avremo a disposizione i seguenti applicativi:
AZBox HD Remote Control v0.8.35 realizzato by J2K
AzBox Control Center v1.0 by telesat
AZBoxHD Skin Uploader by @kajgan
Maz Manager v2.3 by morser
AZBoxEdit v0.9.2880c by telesat
TuneAzbox by mpiero
Pix2AZBox v0.25 grazie a pr2
Generatore di files xml per iradio gerazie ad 1-mail
Un grande ringraziamento va agli autori dei relativi pacchetti che ci aiutano ogni giorno ad usare al meglio il decoder.
Un immenso grazie a xonic per aver realizzato il tool
Note di versione
Versione 1.1:
Inserita la nuova versione di AZBox Control Center 1.1 by telesat
Despues del tuneazbox para httpd, he encontrado limitaciones a la hora de añadir nuevos skins y de añadirle funcionalidades, y he decidido hacer un programa para este fin, que aquí os presento.
Para el que no ha usado el tune para httpd, decir os va permitir cambiar el aspecto del azbox de arriba abajo, pudiendo personalizar todos los elementos visuales del deco.
Con respecto a la versión anterior para httpd los cambios son:
* Es un programa por lo que no requiere instalar el httpd ni nada. Se ejecuta el programa directamente una vez descomprimido (no requiere instalación), se pone los datos del azbox y a rular!
* Más skins de cosecha propia añadida en todos los apartados.
* Posibilidad de establecer temas completos (como el de jamanta o el de ilke o el mio propio) así como de crear temas vosotros y personalizarlos para compartirlos.
* Posibilidad de que un usuario pueda crear fácilmente desde el tune su propio juego de imagenes personalizadas. El programa permite crear un archivo .zip susceptible de ser importado directamente desde el mismo por otros usuarios.
Para crear por ejemplo el banner info personalizado, en la pestaña correspondiente, basta con ir a personalizado, elegir nuestras imágenes (en este caso 2) y enviarlas al deco. Con un simple clic en un botón se creará un archivo .zip con nuestras imagenes para que lo subamos al foro y otros usuarios lo descarguen y desde el propio programa con un clic en el botón de importar lo añadan a la lista.
Una volta installato avrete a disposizione i seguenti applicativi:
- AZBox HD Remote Control v0.8.35 by J2K
- AzBox Control Center v1.1 by telesat
- AZBoxHD Skin Uploader by @kajgan
- Maz Manager v2.3 by morser
- AZBoxEdit v0.9.2880c by telesat
- TuneAzbox v3.0 by mpiero
- Pix2AZBox v0.25 grazie a pr2
- Generatore di files xml per iradio gerazie ad 1-mail
Note di versione
Versione 1.1:
Versione 1.2:
Inserita la nuova versione di TuneAzBox 3.0
NOTA per TuneAzbox in caso di errori:
Codice di errore OLE 0x80040154: Classe non registrata.Per gli utenti che usano Windows 7 e che hanno riscontrato problema ne far partire dal tool i software AzBoxEdit e AzBox Control Center
- andare su una finestra dos (come amministratore): Start -> Esegui -> cmd
- Andare nella cartella di installazione del programma ad esempio cd c:\tuneAzbox
- Eseguire: regsvr32 MSWINSCK.OCX
sono state inserite in automatico con l'installazione del tool le ocx mancanti.
