a aparut incubus 0.86......merge foarte bine .
download
IncubusCamd 0.86 does indeed work very good, however I have never managed to configure so that I can receive ECM-info... anyone that can help?
Tunneling for SKY HD 19.2E.
Add :
1833:1702:000000
in incubusCamd.conf
functioneaza foarte bine ultima versiuna....nu face figuri la sky ital si la premiere merge brici...
Cine poate sa ma lumineze si pe mine cum se schimba o clinie din cccam in incubus.Linia c din cccam imi merge bine dar nu reusesc sa o fac sa mearga in incubuscamd.Ajutorrrrrrrrrrrrrrrrrrrrrrrrrrr!
Daca o sa cauti pe forum, in primul topic legat de incubus vei gasi informatii legate de transfoarmarea liniei.
Urmareste apoi celelalte topicuri succesiv!
Am citit m-ai tot si am incercat dar nu reusesc sa urnesc incubuscamd de nici o culoare! Care ar fi cea mai potrivita sau cea mai stabila vers. ?
Finalul cfg e asa:
Code:[Prov:000000:CaID:0000]
# this provider is a stand-in for all cards and all caid not declared previously
# For example I choose to use cccam protocol on all other provider.
decoder_type=1
card_server_url_0=cccam://
########################### servers configuration ############################
[Servers]
# This is the section for the multi-server configuration.
# URL of card-server to use, formats are as follows:
# cccam://<username>:<password>@<hostname>:<port>/<receive_emu_shared>/[EMM]
# where <receive_emu_shared> should assume value "yes" (without quotes, if you like to receive emus data shared by the server) or "no" (this is assumed by default)
# gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>/[EMM]
# NOTE: The "EMM" suffix is optional and tells the card-server client whether
# to send EMM's to the card-server or not. Enabling or disabling this only
# has effect if the card-server is configured to accept emms from this client.
# NOTE 2: The "card_server_url" is not the same as previously declared in the prov/caid section
# use how many server as you like
#card_server_url=cccam://<username>:<password>@<hostname>:<port>
#card_server_url=gbox://<localhost>:<localport>:<password>@<peer_address>:<peer_port>:<peer_pass>
########################### CaIDs tunneling configuration ############################
[CaIDTunnel]
# All values are in hex notation
# In this file you can configure what CAIDs/PIDs incubusCamd should tunnel to another CAID
# situation 1: this caid, all idents, on all channels will use the tunnel_caid
# caid:tunnel_caid
# situation 2: this caid/ident pair will use the tunnel_caid
# caid:tunnel_caid:ident
# situation 3: this caid/ident pair, on channel 'sid' will use the tunnel_caid
# caid:tunnel_caid:ident:sid
# i.e:
# 1833:1702:000000:0082 # this one should tunnel premiereHD nagra3 into betacrypt cards
# 1833:1702:000000:0081 # this one should tunnel premiereHD nagra3 into betacrypt cards
1833:1702:000000
Se folosesc user si pass. din linia f din cccam in linia din incubus?
Am folosit cfg. ce ai postat mai inainte si acum imi da un mesaj de genul :
Configuration settings
Box type:CubeRevoHD
Debug level
Log out to file:no
Pune cfg asa:
Din linia F faci liniile de incubus, si le pui la serversCode:##############################################################################
# incubusCamd configuration file incubusCamd.V0.87 #
# All configuration options in this file observe the same format: #
# <configuration_name>=<configuration_value> #
# Each section are [<section_name>:<option_1>:<option_x>] like. #
# No matter about white spaces on any place or UNIX/DOS style files #
########################### general configuration ############################
[General]
# Enable (1) or disable (0) background execution
# 0 - Off
# 1 - On
background_execution=1
# This sets the level of console output for debugging:
# 0 - No debug messages, 1 - First level debug messages, 2 - Second level debug messages,
# 3 - Print all debug messages
debug_level=0
# This option enables (1) or disables (0) the writing of debug information to the
# console.
log_to_console=0
# This option enables (1) or disables (0) the writing of console output to a log file
log_to_file=0
# When log_to_file is set to 1, this is the path and filename to write console
# ouput to.
logfile_name=/tmp/incubusCamd.log
# Used to activate on-screen messages. Username and password required if
# HTTP authentication is enabled on enigma.
on_screen_messages_show=0
on_screen_messages_username=root
on_screen_messages_password=
on_screen_messages_key_update=0
on_screen_messages_wait_for_key_update=0
on_screen_messages_ecm=1
on_screen_messages_emm=0
#When activated, camd will listen on the specified port for connections. All
#log activity will be broadcast in real-time to connected clients.
console_logs_broadcast=1
console_logs_broadcast_port=666
############################ caid configuration ##############################
# First of all the cam use the incubusCamd.prio file, then use the
# configuration below.
# Sections are defined by the value of the CaID.
# You can choose the default ecm table used by the codify, this means that
# you can choose the first byte of the raw ecm that is downloaded from sat.
# If you don't know what value to insert, use "80". (all value are in hex)
# Default value for ecm_table is 0x80.
# The option "priority" tells if one caid should be selected before try
# another one with a priority value greater.
# The less is the value the greatest is the priority. Choose from "0" to any value,
# priority value is decimal.
[CaID:0100]
ecm_table=80
priority=1
[CaID:0500]
ecm_table=80
priority=1
[CaID:0600]
ecm_table=80
priority=1
[CaID:0919]
ecm_table=80
priority=1
[CaID:093B]
ecm_table=80
priority=1
[CaID:0B00]
ecm_table=80
priority=1
[CaID:0D00]
ecm_table=80
priority=1
[CaID:1700]
ecm_table=80
priority=1
[CaID:1800]
ecm_table=80
priority=1
[CaID:2600]
ecm_table=80
priority=1
########################### provider configuration ###########################
# All parameters are in hexadecimal notation.
# Each section is defined by the provider id value.
# If you don't know the provider id value then use the provider id "000000" and ca id "0000".
# On provider 000000 caid 0000 goes all provider wich are not declared. If the provider
# is declared then the cam will use the provider founded.
#[Prov:000501:CaID:1833]
# Decoder type indicates whether the cam will attempt to decode this provider
# in software, or through a card-server. Supported values are:
# 0 - Use internal softcams.
# 1 - Connect to a card sharing protocol card-server.
decoder_type=1
# newcamd://<username>:<password>@<hostname>:<port>/<des_key>
# aroureos://@<hostname>:<port>
# radegast://@<hostname>:<port>
# Example:
# newcamd://foo:bar@192.168.0.100:12345/0CE3476FF2E1C9D9A0A109B371E3
# Multiple card-server url's can be specified for server fail-over.
# If the emu fails to connect or fails to get valid CW's, it will try to
# connect to other servers in a round-robin fashion.
# Up to 16 servers can be added from index 0 to 15.
# You can choose also to select a cccam or gbox server, but they must be declared
# in the "servers configuration" section ( [Servers] ).
# e.g. : if you want to use a cccam server for a provider you must put it on
# the parameter card_server_url_0=cccam://
# NO MATTER the value after the double slash because server configuration is
# made in the section [Servers].
# Only for newcamd, radegast and aroureos is usefull to put correct connection
# parameters because they are provider dependent.
# Example i want to use mine card into the slot with newcs for prov 0501 on nagra3 (caid 1833)
#card_server_url_0=newcamd://username:password@192.168.0.100:10550/0102030405060708091011121314
#[Prov:000000:CaID:0502]
#decoder_type=1
#[Prov:002111:CaID:1801]
#decoder_type=1
#[Prov:00000:CaID:0961]
#decoder_type=1
#[Prov:00000:CaID:0B00]
#decoder_type=1
#[Prov:000000:CaID:093B]
#decoder_type=1
decoder_type=1
[Servers]
[CaIDTunnel]
# caid:tunnel_caid
# i.e:
1833:1702:000000
C:xxxxxxxxxx.dyndns.org.12000user(dat de cine a trimis linia)password( dat de cine a trimis linia)
F: user(dat lui de mine) password (dat lui de mine)
Cu aceste settinguri cum scriu cele 2 linii in incubus?
Sa ceri linia F pe care o pune el in server.
Momentan incubus e doar client!
C:xxxxxxxxxx.dyndns.org.12000 user password
card_server_url=cccam://user:password@ xxxxxxxxxx.dyndns.org:12000
asa pui!
Conteaza daca sint connectat la server cu alt receiver in acelasi timp?
Va dati afara pe rand!!
Pune doar o singura linie, de la un singur receptor.
card_server_url=cccam://user@ [Only registered and activated users can see links. Click Here To Register...]:12000
Sarutmina coane Zildane , ai avut dreptate , a trebuit sa opresc dm500 iar apoi kathy s-a conectat fara probleme , mai ramine sa vad cum se comporta acum, cite intreruperi si blocaje !
Multumesc mult inca o data pt. rabdare!
Bafta si happy sharing!
Vezi ca au aparut alte versiuni la pannel.
Faci download din pannel, si apoi de la emu lansezi ce ai instalat!
Ultima pare cea mai stabila de pana acuma!!!
Am instalat v0.87 si vad ca se comporta destul de bine ,din cind in cind se blocheaza!
Hi!
My question is: I have an Ipbox910hd with NLB9580 image. I have tried to connect my payserver c-line to the incubuscamd.conf, and think I have done most things right. My question is: how should the incubuscamd.prio fil look like when this is my incubus.conf file:
[General]
[Prov:0501] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
[Prov:FF00] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
[Servers] card_server_url_0=cccam://spirit:bardmsn@laserserver.no-ip.org:12000
Thanks!
Bard
decoder_type=1
[Servers]
card_server_url=cccam://<username1> : <password1>@<hostname1>:<port2>
card_server_url=cccam://<username2> : <password2>@<hostname2>:<port2>
