Cartela TVR in mbox+newcs
Salutare, am facut si eu cum m-am priceput mai bine NewCS + Mbox ca sa deschid macar local cartela de TVR... dar nu decodeaza...
Asta e ce imi arata...
Code:
oot@dreambox:~> /var/script/mbox_0.5.0021_newcs_1.65_cam.sh start
[SCRIPT] start: Mbox 0.5.0021/NewCS 1.65
This is NewCS 1.66 [Build: 82] - the New CardServer by the Butter-team..
Compiled on May 22 2009 at 11:11:28
Reading Config file from /var/tuxbox/config/newcs.xml
TCP-log password is enabled, set to: NewCSpwd
TCP-log set to simple mode
level: normal
type: init
output: console,tcp
logger config: level 1 type 3 output 5
Console log options: level 1 type 3
TCP log options: level 1 type 3
[ 15:15:06 ] [ Box detect ] Box type 2 (Dream Multimedia (PPC) Box)
[ 15:15:06 ] [ Config ] Option <blockc0> for device 0 (lower) not present, defau
lting to NO
[ 15:15:06 ] [ Config ] Value in <ipk> for device 0 (lower) is INVALID, skipping
[ 15:15:06 ] [ Config ] Value in <ucpk> for device 0 (lower) is INVALID, skippin
g...
[ 15:15:06 ] [ Config ] Pincode for device 0 (lower): 0000
[ 15:15:06 ] [ Config ] /dev/sci0 ECM priority: round
[ 15:15:06 ] [ httpd ] httpd-user: newcs, password: newcs, accesslevel: admin
[ 15:15:06 ] [ EMM Cache ] Initialising dynamic Cache
[ 15:15:06 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 284
[ 15:15:06 ] [ Loader ] Starting Telnet on port 1001
[ 15:15:06 ] [ Loader ] Started HTTP-server on port: 8080
[ 15:15:06 ] [ Loader ] Reader type 5 on node /dev/sci0
[ 15:15:06 ] [ Sci ] Closing device /dev/sci0 [Handle=-1]
[ 15:15:06 ] [ Sci ] Opening device /dev/sci0
SCI returned 0 on IOCTL IOCTL_SET_PARAMETERS
[ 15:15:06 ] [ Sci ] resetting card now
[ 15:15:06 ] [ Sci ] Reset
[ 15:15:06 ] [ Sci ] Card reset
[ 15:15:07 ] [ ATR ] T=0 1etu=31.00us Guardtime:12etu WWT:115200etu
[ 15:15:07 ] [ ATR ] Historical bytes: [C2] [14] [00] [C1] h [90] [00]
[ 15:15:07 ] [ Loader ] Init Viaccess card
[ 15:15:07 ] [ KeymaN ] Adding key 000000bf6456ed type 0 on Provider 000000 for
caid 0500 ID=0
[ 15:15:08 ] [ KeymaN ] Adding key 000000bf6456ed type 1 on Provider FFF720 for
caid 0500 ID=0
[ 15:15:08 ] [ KeymaN ] Adding key 000000bf6456ed type 1 on Provider 025900 for
caid 0500 ID=1
[ 15:15:08 ] [ KeymaN ] Adding key 000000bf6456ed type 1 on Provider 025910 for
caid 0500 ID=2
[ 15:15:08 ] [ Loader ] Card 0500 on port /dev/sci0 ready
[ 15:15:08 ] [ Loader ] Starting Newcamd Server on port 34000
[ 15:15:08 ] [ NewCS ] Ready to GO! :)
[ 15:15:08 ] [ Newcamd ] Newcamd thread Server started on port 34000
newcamd: main loop
des_decrypt: bad len ?
[ 15:15:08 ] [ Newcamd:34000 ] Can't decrypt client msg, rejecting!
[ 15:15:08 ] [ Newcamd:34000 ] User dummy logout
[15:15:21] Checking for priority file ... no priority file.
[15:15:21] ExYuSAT Team [Only registered and activated users can see links. Click Here To Register...] , [Only registered and activated users can see links. Click Here To Register...].
php
[15:15:21] Starting MBOX version 0.5 BETA (build 0021) coded by The_Ripper
[15:15:21] This program is for educational & informational purposes only!!
[15:15:21] Donation to project: [Only registered and activated users can see links. Click Here To Register...]
[15:15:21] [ Box ] Dream Multimedia (PPC) SD Box
[15:15:21] ===> Net Mode <===
[15:15:21] Opened 'ca' device ...
[15:15:21] Opened 'demux' device ...
[15:15:21] Reading cwshare.cfg ...
[15:15:21] Trying to get online,please wait ...
[15:15:21] Total 1 newcamd server(s) to connect
[15:15:21] Creating ecm parser thread ...OK
[15:15:21] Creating timer thread ...OK
root@dreambox:~> [15:15:21] Creating newcamd worker thread ...OK
[15:15:21] [NEWCAMD] Trying to connect to newcamd server (127.0.0.1:34000)
[15:15:21] [NEWCAMD] Connected to (127.0.0.1:34000) ...
[ 15:15:21 ] [ Newcamd:34000 ] User dummy logged in, client: Gbox2CS
[15:15:21] [NEWCAMD] Got card with CaID 0x0500 and 3 number(s) of ProvID (127.0
.0.1:34000)
[15:15:21] [NEWCAMD] Card: CaID 0x0500 ProvID: 0xFFF720 (127.0.0.1:34000)
[15:15:21] [NEWCAMD] Card: CaID 0x0500 ProvID: 0x025900 (127.0.0.1:34000)
[15:15:21] [NEWCAMD] Card: CaID 0x0500 ProvID: 0x025910 (127.0.0.1:34000)
[15:15:21] [NEWCAMD] Creating newcamd worker thread for (127.0.0.1:34000) ...OK
Cand schimb postul imi apare asa:
Code:
[15:17:06] [DMX - 0] ReReading pmt.tmp
[15:17:06] ==================================================================
[15:17:06] *ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0500
[15:17:06] *ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0030
[15:17:06] *ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0031
[15:17:06] Searching CW cache for CaID 0x0502, pid 0x0500...no CW in cache
[15:17:06] Searching CW cache for CaID 0x0502, pid 0x0030...no CW in cache
[15:17:06] Searching CW cache for CaID 0x0502, pid 0x0031...no CW in cache
[15:17:07] Searching CW cache for CaID 0x0502, pid 0x0500...no CW in cache
[15:17:07] Searching CW cache for CaID 0x0502, pid 0x0030...no CW in cache
[15:17:07] Searching CW cache for CaID 0x0502, pid 0x0031...no CW in cache
[15:17:17] Searching CW cache for CaID 0x0502, pid 0x0500...no CW in cache
[15:17:17] Searching CW cache for CaID 0x0502, pid 0x0030...no CW in cache
[15:17:17] Searching CW cache for CaID 0x0502, pid 0x0031...no CW in cache
Deci el face ceva ceva acolo din cate inteleg vede cartela, vede pid-ul postului, dar de ce nu se deschide?... Ce gresesc? Merci
Re: Cartela TVR in mbox+newcs
cardul e activat si updatat?
Cardul este al unui prieten care a venit pe la mine, el l-a folosit acum 3 zile intr-un Echosmart 791, acum vrem sa il testam pe dream...
Linia C din cwshare trebuie sa fie de genul:
C: { 127.0.0.1 34000 dummy dummy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 } { 05005900:05025900 }
Eu aveam cu { 0 } { 0 } la sfarsit
Am pus cum ai zis tu si acum apare
[16:34:28] Searching CW cache for CaID 0x0502, pid 0x0500...no CW in cache
[16:34:28] [NEWCAMD] Putting ECM ([DMX - 0]) (<-0) from local host, caid:0x0502,
ecmpid:0x0500,sidpid:0x0002 in ECM buffer (1/10)
[16:34:28] [NEWCAMD] Sending ECM caid:0x0502, ecmpid:0x0500, sidpid:0x0002 to (
127.0.0.1:34000).
[16:34:28] [NEWCAMD] sent sequence id 0021 , received sequence id 0021
[16:34:28] [NEWCAMD] Control words not received (127.0.0.1:34000), time (8 ms)
[16:34:28] Searching CW cache for CaID 0x0502, pid 0x0030...no CW in cache
ecmpid:0x0030,sidpid:0x0002 in ECM buffer (1/10)
[16:34:28] [NEWCAMD] Sending ECM caid:0x0502, ecmpid:0x0030, sidpid:0x0002 to (
127.0.0.1:34000).
[16:34:28] Searching CW cache for CaID 0x0502, pid 0x0031...no CW in cache
Dar tot nu se deschide nici tvr1 nici tvr2...
In var/keys ai creat un fisier cu denumirea 34000.list care sa contina ECM pid-urile de la TVR-uri?Daca nu creezi unul si pui:
E: { 0031 }
E: { 0034 }
Super, acum merge, nu stiam de 34000.list :)
mai am inca o intrebare, vad ca ai pus pid-urile pt 2 canale, tvr1 si tvr2, dar pt tvr hd ce tre sa pun ?
Ala nu merge?Sorry dar nu pot testa,doar un peer de al tau cu receptor HD poate.Parca era vorba ca are acelasi ECM pid cu TVR SD,dar pare putin ilogic.
Tot in 34000.list pune astea doua linii G:
G: { 0500F720 }
G: { 05005910 }
ca sa nu mai apara si acele doua pid-uri ca locale.
Mbox si incubuscamd + NewCS pe UFS910 merg cu card TVR de zbirniie. Tot ce stiu e ca Zildan a explicat [Only registered and activated users can see links. Click Here To Register...] iar mie mi-a folosit foarte mult. Sper sa te ajute si pe tine.
Pfai si cat am cautat topicul ala.E aici [Only registered and activated users can see links. Click Here To Register...] dar normal ar fi fost tot aici la mbox ca nu o mai luam noi de la capat cu toate,setarile fiind aceleasi pentru toate receptoarele.:)
Pana la urma cu ajutorul informatiilor din debug.txt postate de @crizatu s-a rezolvat.Intotdeauna postati acele informatii,sunt extrem de utile.
Esti tare tata, era acelasi PID :)
Uite ce am facut de fapt, am sharuit prin newcs cartela dintr-un DM500 si deschid posturile pe un alt receptor tot la mine in casa (ipbox 900 hd)
Acum merge :) super super tare.
Oare merge sa pun cartela in cccam+newcs dar s-o deschid pe alt receptor folosind mbox? Teoretic ar trebui sa mearga, nu? Pe receptorul cu cccam nu ma intereseaza sa se deschida.
Da,merge.Cardul in newcs si faci linie C in receptorul cu mbox.Nu ai cititor la Ipbox?Nu merge in phoenix?Port.list il pui tot in receptorul cu mbox.
Sa mai specificam odata ca pe acel receptor nu va merge in cccam si nici macar nu mai pui linie ca nu are rost.Ca sa nu inteleaga lumea gresit.
Acum am o alta problema... TVR1 si TVR HD au acelasi pid, da?
Pana acum a mers, dar acum vad ca pe TVR 1 vin ECM-uri, pe TVR HD merge 2-3 secunde (cat tine ecm-ul) si altul nou nu mai vine... si moare HD-ul.
Ce ar putea avea?
Pune debug sa vedem ce cereri face.
Uite asa face
[01:40:22] Searching CW cache for CaID 0x0502, pid 0x0034...no CW in cache
[01:40:22] [newcamd] Putting ECM ([tuner0 - 0]) (<-0) from local host, caid:0x0502, ecmpid:0x0034,sidpid:0x000F in ECM buffer (1/10)
[01:40:22] [newcamd] Sending ECM caid:0x0502, ecmpid:0x0034, sidpid:0x000F to (192.168.2.5:34000).
[01:40:22] [newcamd] sent sequence id 0024 , received sequence id 0024
[01:40:22] [newcamd] Control words not received (192.168.2.5:34000), time (5 ms)
[01:40:26] Searching CW cache for CaID 0x0502, pid 0x0032...no CW in cache
[01:40:26] [newcamd]Dropping local ECM , caid:0x0502, ecmpid:0x0032, sidpid:0x000F cant decode localy
[01:40:26] Searching CW cache for CaID 0x0502, pid 0x0033...no CW in cache
[01:40:26] [newcamd]Dropping local ECM , caid:0x0502, ecmpid:0x0033, sidpid:0x000F cant decode localy
[01:40:26] Searching CW cache for CaID 0x0502, pid 0x0034...no CW in cache
[01:40:26] [newcamd] Putting ECM ([tuner0 - 0]) (<-0) from local host, caid:0x0502, ecmpid:0x0034,sidpid:0x000F in ECM buffer (1/10)
[01:40:26] [newcamd] Sending ECM caid:0x0502, ecmpid:0x0034, sidpid:0x000F to (192.168.2.5:34000).
[01:40:26] [newcamd] sent sequence id 0025 , received sequence id 0025
[01:40:26] [newcamd] Control words not received (192.168.2.5:34000), time (5 ms)
Culmea e ca primele 3-4 secunde merge inca HD-ul cu ECM-ul ce-l avea de pe TVR 1 :)) Dar apoi iti dai seama ca moare...
Incearca sa adaugi lini E:
E: { 0032 }
E: { 0033 }
Eventual le pui pe rand si vezi cu care deschide.
Nu vrea nici asa... ce-o avea? Ca a mers... m-am dat si eu putin pe alt receptor (pe alte posturi, n-am modificat nimic in config la dm500 si la ipbox) si cand m-am dat si eu inapoi pe tvr a luat-o razna :(
in 18.10.2008 scriam:
Code:
Aseara am pierdut ceva timp cu cardul de TVR si am reusit sa il pornesc pe Kathy cu Mbox si Newcs., acum e o problema rezolvata.
Pasii care trebuiesc facuti sunt urmatorii:
1. Newcs 1.60 beta (sigur aceasta versiune citeste cardul )
2. Linia C de forma
C:{ 127.0.0.1 port kathy kathy 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 } { 05005900:05025900 )
3. In cwshare.cfg
H: { 05025900; } ( cu versiunea Mbox 0.4 built 0013, dar se pare ca nu prea are efect)
4. In port.list se pun
G: { 05005910 }
G: { 0500F720 }
E: { 0031 }
E: { 0034 }
Spor la treaba!
Ultimele versiuni Newcs citesc cardul, asa ca prima parte (cea cu versiunea NewCS 1.60) se poate sari.
Multumesc frumos tuturor, pana la urma am reinstalat imaginea pe DM500, am refacut toate setarile si a inceput sa mearga :)
Revin si eu cu o mica "problemutza"
M-am inspirat din exemplele voastre, am primit si fisierele gata configurate de la cineva...Am asa:
Code:
<?xml version="1.0"?>
<newCSconfig>
<readers name="Card Readers">
<device>
<name>upper</name>
<type>azbox</type>
<node>/dev/scard</node>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>No</blockga>
<newcamd_port>20000</newcamd_port>
<autosid>yes</autosid>
<carddetect>yes</carddetect>
<priority>hard</priority>
<mhz>357</mhz>
<boxkey>000000000000000000</boxkey>
<rsa>000000000000000000000000000000000000000000</rsa>
</device>
</readers>
<xmlserver>
<enabled>0</enabled>
</xmlserver>
<radegastserver>
<enabled>Yes</enabled>
<port>16000</port>
<allow>
</allow>
</radegastserver>
<cache>
<emm>10</emm>
<ecm>-1</ecm>
</cache>
<debug>
<darint39>sintoi51</darint39>
<level>internal</level>
<type>all</type>
<output>console, tcp</output>
<logfile>/tmp/newcs.txt</logfile>
<console_options></console_options>
<file_options></file_options>
<udp_host>172.16.1.1</udp_host>
<udp_port>9000</udp_port>
<udp_options></udp_options>
<tcp_port>1001</tcp_port>
<tcp_options></tcp_options>
</debug>
<newcamdserver>
<name>local</name>
<user>
<name>azbox</name>
<password>lica</password>
<hostname>127.0.0.1</hostname>
<port>12000</port>
</user>
</newcamd_server>
</newCSconfig>
Apoi in cwshare:
Code:
M: { lic........no-ip.info { ******** }}
C: { 127.0.0.1 20000 azbox lica 01 02 03 04 05 06 07 08 09 10 11 12 13 14 } { 10 } { 05005900:05025900 }
I: { 3 }
O: { 4000 2000 }
X: { 9 }
H: { 05025900 }
Iar in 20000.list am asa:
Code:
E: { 0031 }
E: { 0034 }
G: { 0500F720 }
G: { 05005910 }
Nu inteleg de ce imi merge doar TVR 1. Iar daca schimb pe TVR HD imi merge doar cateva secunde apoi se blocheaza.
In debug imi arata ca decodeaza la inceput apoi cand schimb se blocheaza si zice de "ReReading.tmp" Mie nu-mi genereaza acest fisier in /tmp/
Code:
*ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0032
[21:06:01] *ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0033
[21:06:01] *ECM: CA ID: 0x0500 Viaccess (000000) -> CA PID: 0x0034
[21:06:01] ==================================================================
[21:06:02] Searching CW cache for CaID 0x0502, pid 0x0032...no CW in cache
[21:06:02] Searching CW cache for CaID 0x0502, pid 0x0033...no CW in cache
[21:06:02] Searching CW cache for CaID 0x0502, pid 0x0034...no CW in cache
[21:06:02] [NEWCAMD] Putting ECM ([DMX - 0]) (<-0) from local host, caid:0x0502, ecmpid:0x0034,sidpid:0x0001 in ECM buffer (1/10)
[21:06:02] [NEWCAMD] Sending ECM caid:0x0502, ecmpid:0x0034, sidpid:0x0001 to (127.0.0.1:20000).
[21:06:02] [NEWCAMD] sent sequence id 0008 , received sequence id 0008
[21:06:02] [NEWCAMD] Control words received successfully (127.0.0.1:20000), time (300 ms).
[21:06:02] <-[DMX - 0] CW FOR ME :), from (127.0.0.1:20000) (<-0) (302 ms)
[21:06:02] ===== Viaccess ECM on CaID 0x0502, pid 0x0034 ====
[21:06:02] prov: 0D77
[21:06:02] CW0: 87 3C 38 FB 10 D5 CE B3
[21:06:02] CW1: 1A A4 82 40 8C 53 07 E6
[21:06:02] =================================================
[21:06:06]
[21:06:06] [DMX - 0] ReReading pmt.tmp
[21:06:06] ==================================================================
[21:06:21]
[21:06:21] [DMX - 0] ReReading pmt.tmp
[21:06:21] ==================================================================
[21:06:25]
[21:06:25] [DMX - 0] ReReading pmt.tmp
ce pot sa fac sa-mi decodeze si TVR HD sau TVR2? Precizez ca am un AZBOX premium
