Re: E2 RSP 3.17b TDT 1142
Merci mult maestre!!!
Trec la testat
f11
Thank you Zildan , trying it now.
Thx RSP Team , alredy tested and i can say only :
very good and stable img
imagine foarte buna si rapida... felicitari
doua intrebari:
vede partitiile ntfs?
cum se mareste textul in subtitrari... subtitrarea mi se pare putin mica... sau poate ar trebui sa-mi iau niste ochelari....
merci
@Zildan
I need your help please. IncubusCamd 0.55 works for me conecting to a CCCam server, but the 0.82 does not. Any special change required in the conf file compared to the one that works with 0.55?
Do you intend to release a flash version of your image or not?
Regards,
Afzal
Download IncubusCamd.conf with RSP Pannel, (RSP menu > installer >Download Emu Config >Incu,,,).
Code:
[Prov:000000:CaID:0000]
decoder_type=1
card_server_url_0=cccam://myuser:mypasswd@servername.homelinux.com:12000
card_server_url_1=cccam://myuser22:mypasswd22@servername22.homelinux.com:120 00
card_server_url_2=cccam://myuser333:mypasswd333@servername333.homelinux.com: 12000
[Servers]
card_server_url=cccam://myuser:mypasswd@servername.homelinux.com:12000
card_server_url=cccam://myuser22:mypasswd22@servername22.homelinux.com:120 00
card_server_url=cccam://myuser333:mypasswd333@servername333.homelinux.com: 12000
@Zildan
Thanks a lot. You are a Genius! It worked
Regards,
Afzal
hi RSP moderator tank you for new image
no any incubusCamd worked for me
what is a problem ?
help please
look at the example config up
Shi apare shi ceasul in Stand by (o surpiza placuta despre care nu se vorbeshte in prezentarea Imaginei din primul post). Multumim lui Zildan shi echipei. E stabila shi merge foarte bine... Cine nu a instalat-o inca s-o faca mai de curand...
Good work, thank your,
I format a one particion of 3 in ext3,
I install with KCC-3.2 in the partition ext3, I modifi in ba the bootp.conf:
ASSIGNUSBDEVICES=y
MOUNTDIFFERENT=0
BADEVICE=/dev/sda3
BADEVID=0:3
IPADDR=192.168.1.9
SERVERIP=192.168.1.20
GATEWAY=192.168.1.1
BOOTARGS=console=ttyAS0,115200 root=$badevice rw ip=$ipaddr:$serverip:$gateway:255.255.255.0:kathrein:eth0:off mem=64m coprocessor_mem=4m@0x10000000,4m@0x10400000 rootdelay=6 nwhwconf=device:eth0,hwaddr:$ethaddr init=/bin/devinit
BOOTCMD=usb reset;usb reset;ext3load usb $badevid a5000000 boot/uImage;bootm a5000000
But dont start de image, she a bucle and continius restart when arrive at ufs-910 restard a initial bootmenu, and repit the same all time.
What is my problem?
Is correct the "ext3load" in ba/ba/RSP-1141/bootp.conf?
Thank Your in advance for your help
Regards
He he ...ceasul, in sfirsit...cite cereri a avut @zildan sa introduca ceasul...nici el nu mai stie.:clap:
@javier3034
For the image to work on an ext3 partition you don't have to edit bootp.conf.
Format ext3 fs partitions and install e2.
thank your zildan,
Work very good,
I format a partition with:
busybox mke2fs -j /dev/sda3
And work good,
is correct this commands to format a partition in axt3 fs?
Regards
Use KCC 3.2 Experts.
