LINUX O/S (IBM´s PowerPC 405, 32 MB SDRAM)
Smart Card reader (X-Crypt CAS, Firecrypt CAS )
Ethernet 10/100 , RS232 connection support
Software upgrade throught internet
Application and Expansion
LINUX O/S enables ultimate applications and expansions to fulfill the customer’s need
Two Channels Recording and One Prerecorded File Playback
Receiver is supplied in full configuration, after turning on is ready for use without any software upgrade.
Full graphical OSD menu
User friendly interface
DiSEqC 1.0, 1.1 switches and DiSEqC 1.2 driving motors, USALS control supported
4000 Channel Memory
Enhanced Search Channel Option:
Search by all satellite
Search by satellite/ network
Search by all TP scanningSupport fast TXT (250 TXT pages in memory)
Digital optical output SPDIF with AC3 supported
Smart EPG
Automatically updates Program Info
EPG shows all Satellites’ Program Guide
Search programs by Genre on the EPG
Enhanced timer setting/ EPG
Modification settings and devices in PC
Ethernet 10/100 port supported. Possibility to connect receiver to Internet and interface receivers through LAN ,
automatic identification and configuration of network connection
Possibility of automatic software upgrade through Internet
Band selection 22 KHz tone
Switch DiSEqC 1.1/1.2 /1.3(USALS)
Polarization 13/18V (400mA Max/per each)
Transport Stream ISO/IEC 13818-1 Specification
Aspect Ratio 4:3, 16:9 with pan vector
Video Resolution 720 x 576(PAL)
Audio Decoding MPEG-1 Audio Layer 1,2
Ethernet RJ-45(10Base-T/100Base-TX)
Flash Memory 8 MB SDRAM
Smartcard 1 slot
RF-Connect 75ohm, IEC 169-2, Male/ Female
Output Frequency 470MHz to 860MHz
Output Channel CH 21-69
TV Standard PAL D/K, PAL B/G, PAL I
TV SCART 1 x SCART
VCR SCART 1 x SCART
RCA Video x 1, Audio x 2
Data Interface 9 Pin D-Sub, RS232C
Input Voltage AC90-240V, 50Hz/60Hz
Power Consumption 50W max.(Under 7W max. at stand-by mode)
Size (W x H x D) 300mm x 58mm x 235mm
Weight About 2kg
soft: [Only registered and activated users can see links. Click Here To Register...]
in Romania se gaseste la [Only registered and activated users can see links. Click Here To Register...] ;pretul: 695lei (tva inclus)
