Imi poate spune cineva care foloseste oscam cu dvbapi activat care sunt setarile pentru a decoda pachetul Canal Digital Nordic?
Am pus in oscam.dvbapi linia P: b00 , dar degeaba...intuneric pe toate programele, HD, sau SD
Nu este neaparat necesar sa faci setari speciale ci sa ai carduri valide ... prio pui doar in momentul in care un anumit provider este codat cu mai multe sisteme de codare si doresti sa-ti decodeze dintr-un anumit sistem pentru ca acel sistem iti ofera timp mai bun de raspuns .
Pai asta e nelamurirea mea...am carduri...pt k ca doar cu cccam functioneaza!!!
P: 0b00:000000 # CDN
Sintaxa arata asa
Vezi si cu grupurile sa nu fie puse gresit, pune toate grupurile la userul dvb api. Ti-ai facut un user dvbapi?Code:#
# dvbapi configuration
# types:
# P - Priority
# format:
# P: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
# I - Ignore
# format:
# I: <caid>:[<provider>]:[<srvid>]:[<ecmpid>]
# M - Map
# format:
# M: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <target caid>:[<target provider>]
# D - Delay
# format:
# D: <caid>:[<provider>]:[<srvid>]:[<ecmpid>] <delay (ms)>
Uite un exemplu, inclusiv cu TVRHD
# TVR CARD
M: 0500:000000:000F 0500:025900 #TVRHD
M: 0500:000000:0001 0500:025900 #TVR1
M: 0500:000000:0002 0500:025900 #TVR2
P: 0500:000000:000F
P: 0500:000000:0001
P: 0500:000000:0002
M: 1880:000000 1880:002111
P: 0500:030b00 # TNTSAT
P: 0B02:000000 # UPC RO
#P: 09CD:000000:3312 # sky it ESP
#P: 09CD:000000:3b63 # sky it ESP2
#P: 0100:000068:3312 # cyf ESP
#P: 0100:000068:3b63 # cyf ESP2
P: 1880:002111:177a # Digi premium
P: 1880:000000 # Digi N4
P: 1802:000000
P: 0100:000068:3312 #ESP RO
P: 0100:000068:3bb3 #ESP2
P: 0b00:000000 #CND
P: 0500:030B00 # TNTSAT
P: 0100:000068 # Cyfra+
P: 0100:000065 # Cyfra+ VOD
P: 1803:000000 # Polsat
P: 0b00:000000 # conax
P: 0d02:000000 # UPC Direct
P: 0100:00006a # C+ NED
P: 0100:00006c # TV Vlaanderen
P: 1810:000000 # D+ nagra
P: 0100:004106 # D+seca
P: 09cd:000000 # sky it
P: 093b:000000 # sky it
P: 0919:000000 # sky it
P: 090f:000000 # Viasat
P: 093e:000000 # Viasat
P: 0963:000000
P: 0d00:0000c0 # Dturk
P: 1702:000000 # Premiere
P: 09c4:000000 # Premiere
Asa am...P: 0b00:000000
Nu am decat 2 grupuri: 1 pentru local, si 2 pentru proxy readere. Userul dvbapi setat pentru ambele grupuri. Numai cu acest caid am probleme...in rest functioneaza totul. La un moment dat chiar am crezut k s-a facut intuneric pt acest caid, dar am schimbat cu cccam si...surpriza....merge!!!!
Pune si tu un log fara chestii personale sa vedem ce zice. Rejected, not found, timeout?
Asta nu e un CAID cu probleme, undeva e o greseala, verifica readerul....
Am verificat si ecmwhitelist si am completat cu ce imi lipsea, dar tot degeaba.
Cam asta spune logul:
06/06/2012 12:29:39 737110 c dvbapi: [ADD PID 0] CAID: 0B00 ECM_PID: 0021 PROVID: 000000
06/06/2012 12:29:39 737110 c dvbapi: new program number: 012E (Canal+ Sport Sweden) [pmt_list_management 3]
06/06/2012 12:29:40 737110 c dvapi (0B00&000000/0000/012E/7A:D761): timeout (1508 ms) by laptop-cccam (6 of 6) - Canal+ Sport Sweden
Problema e ca incearca sa decodeze de la rederele unde exista caid 0b00, primeste timeout si pe urma nu mai incearca nimic...ramane ecranul negru
Probeaza cu setarile astea...Code:[dvbapi]
enabled = 1
au = 1 #daca vrei sa faci AU
boxtype = dreambox
user = userapi
pmt_mode = 0
request_mode = 0
reopenonzap = 0
delayer = 0
Am incercat si cu setarile de mai sus. Din pacate, acelasi "timeout".
Cine foloseste doar oscam cu dvbapi activat poate confirma ca oscam decodeaza caid 0b00 Canal digital Nordic? Si ce setari sa folosesc(oscam.conf, oscam.dvbapi, oscam.ecmwhitelist)
Nu era mai bine daca puneai tu de la inceput toate setarile tale, fara ip -uri, useri si pass?
Cum zicea cineva, oscamu' e "stufos"! Daca o luam pe ghicite, stam toata vara calare pe el!
Merge fara probleme:
PS Ceasul e cu 3 ore in urma la box, cred ca e un bug de la imaginea asta noua si nu pot sa-l dau corect sub nicio formaQuote:
2012/06/06 10:44:30 77211B18 c userapi (0B00&000000/0000/1008/7A:51F9): found (370 ms) by c1 (P/2/2/2) - BBC HD
2012/06/06 10:44:40 77211B18 c userapi (0B00&000000/0000/1008/7A:BE59): found (326 ms) by c2 (P/2/2/2) - BBC HD
2012/06/06 10:44:50 77211B18 c userapi (0B00&000000/0000/1008/7A:9F94): found (322 ms) by c1 (P/2/2/2) - BBC HD
2012/06/06 10:45:00 77211B18 c userapi (0B00&000000/0000/1008/7A:F4F3): found (373 ms) by c1 (P/2/2/2) - BBC HD
2012/06/06 10:45:11 77211B18 c userapi (0B00&000000/0000/1008/7A:3081): found (339 ms) by c2 (P/2/2/2) - BBC HD
2012/06/06 10:45:20 77211B18 c userapi (0B00&000000/0000/1008/7A:4EED): found (340 ms) by c2 (P/2/2/2) - BBC HD
Oscam decodeaza b00 #CDN , setarile puse de @lao sunt bune ... #b00 CDN este decodat si fara fisierele oscam.dvbapi si oscam.ecmwhitelist , conditia este sa ai carduri bune . Posibil sa ai ceva setari gresite prin oscam.server sau oscam.user sau probleme de reshare carduri b00 .
setari proste @steg27,ma repet mereu,oscam nu e ptr toti:)
nu e nevoie sa te superi:)
vb lui lao,pune tot aici..user,dvbapi,server si config global
apropo banuiesc ca nu ai pus acel prio pe b00 in oscam.config la sectiunea dvbapi?:)..desi trebuie sa deschida si fara acele prio
---------- Post added at 13:26 ---------- Previous post was at 13:23 ----------
apropo lao,lamureste ma si pe mine ce i cu astea?:)
Imi permit sa-ti raspund eu ... asa se pune care sistem de codare sa fie primul la incercarea de decodare , care este mai sus in lista acela va fi primul testat dar nu mereu se respecta regula iar oscam mai face si ce vrea muschiul lui :)Quote:
Dar din ce am vazut numai in sensul bun, adica ia din al 2-lea ca prioritate numai daca e foarte bun, daca e mai prost ca primu' nu cred ca o sa ia din el.Quote:
De curand am vazut asta la nemti, desi i-am zis sa prefere in primul rand 1702, el lua din 9c4, da' lua bine de tot!
Invers n-am intalnit.
pai indicat ar fi asa
sa ti testez cardurile o perioada si vezi care sant stabile.....si nu in ultimu rand reale:)
un card care nu e bine setat sau nu e real...ma refer la partener...imediat iti va raspunde aiurea...cu timeout,ecm mare,frezuri etc
din cauza asta eu nu vad ok aceasta setare cu toate caidurile
oricum atat oscam cat si 3c iti va lua automat din alt caid daca caidu setat in prio e aiurea
ma rog eu asa am setat
insa precum eu nu prea imi schimb parteneri si nu adaug altii noi cam de multa vreme...merge foarte bine doar cu un caid in prio daca acel caid e ok
daca faci invers si tot adaugi la parteneri cu linii N instabile si nu numai nici saracu prio nu prea mai rezolva multe
