ma ajuta si pe mine cineva sa vad tvr hd in dream800 cu un card tvr
:tv:
:tv:
Cardul TVR HD merge OK pe oscam 1.0 si cccam 2.1.3!
poti te rog frumos sa ma ajuti cu un script ceva ca banuiesc ca trebuie.
multumesc frumos
:cheers:
La ce script te referi ? ai aici [Only registered and activated users can see links. Click Here To Register...] un model de configurare a cardului in oscam.
multuesc frumos dMd sa mananc si ma apuc de treaba
---------- Post added at 18:33 ---------- Previous post was at 18:02 ----------
nu se deschide tvr
:comp:
poate cineva sa ma ajute?
Eu personal am instalat doar MgCamd 1.35/Newcs 1.67 si deschide tvr-urile direct inclusiv tvr hd fara nici o alta setare suplimentara!
TVR1 - TVR2 - TVRHD (16 est) merg deschise in MgCamd 1.35 cu linii C.
In mg-cfg se modifica G: { 01 } in G: { 32 }
# network mode, use summ for several clients
# 00 no network (default)
# 01 newcamd netclient
# 02 radegast netclient
# 04 camd3 netclient
# 08 gbox netclient
# 32 cccamd netclient, card list saved as /tmp/cccamd.info
# (ECM only, supported server version up to 2.1.1, later not work)
G: { 32 }
In cccamd se trec linii C
C: exemplu.dyndns.tv port user password
Modificarile se fac in /usr/keys/cccamd si /usr/keys/mg-cfg .
Am testat pe Gemeni 4.70 cu o linie C care avea local card de TVR.
VIZIONARE PLACUTA, FUNCTIONEAZA IMPECABIL.
PS: merg deschise si alte canale de pe alti sateliti cu linie C in MgCamd 1.35.
ce se intampla cu tvr local in oscam?de azi dimineata la mine e intuneric...card ok toate cele in regula dar iaca dupa un aproape un an e...negru:)
Si la mine merge intrerupt,da merge ...
Si la mine merge ok
2012/08/13 23:18:16 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (97 ms) by tvr (L/1/1/4)
2012/08/13 23:18:26 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (95 ms) by tvr (L/1/1/4)
2012/08/13 23:18:36 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (103 ms) by tvr (L/1/4/4)
2012/08/13 23:18:46 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (117 ms) by tvr (L/1/4/4)
2012/08/13 23:18:56 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (109 ms) by tvr (L/1/4/4)
2012/08/13 23:19:06 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (95 ms) by tvr (L/1/4/4)
2012/08/13 23:19:16 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (99 ms) by tvr (L/1/4/4)
2012/08/13 23:19:26 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (92 ms) by tvr (L/1/4/4)
2012/08/13 23:19:36 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (101 ms) by tvr (L/1/4/4)
2012/08/13 23:19:46 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (92 ms) by tvr (L/1/4/4)
2012/08/13 23:19:56 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (96 ms) by tvr (L/1/4/4)
2012/08/13 23:20:06 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (98 ms) by tvr (L/1/4/4)
2012/08/13 23:20:16 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (93 ms) by tvr (L/1/4/4)
2012/08/13 23:20:26 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (93 ms) by tvr (L/1/4/4)
2012/08/13 23:20:36 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (97 ms) by tvr (L/1/4/4)
2012/08/13 23:20:46 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (95 ms) by tvr (L/1/4/4)
2012/08/13 23:20:56 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (95 ms) by tvr (L/1/4/4)
2012/08/13 23:21:06 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (91 ms) by tvr (L/1/4/4)
2012/08/13 23:21:16 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (94 ms) by tvr (L/1/4/4)
2012/08/13 23:21:26 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (92 ms) by tvr (L/1/4/4)
2012/08/13 23:21:36 29952FE0 c amiko (0500&025900/0000/000F/6B:9E8A): found (93 ms) by tvr (L/1/4/4)
2012/08/13 23:21:46 29952FE0 c amiko (0500&025900/0000/000F/6B:9F8A): found (91 ms) by tvr (L/1/4/4)
mersi frumos ptr raspunsuri...sa vedem ce masa are:)
doar in oscam face figuri?
pe normal merge?
daca nu merge nici pe normal suna eventual la ei, poate trebuie un update
cum pe normal?te referi la alt emulator
tvr e in oscam cu dvbapi activ ptr ca merge pe dm de la tv,iar dintr o data nu mai deschide
totu e ok,citirea,update etc
[reader]
label = tvr
description =
enable = 1
protocol = internal
device = /dev/sci0
key =
password =
pincode = none
readnano =
services = tvr
resetcycle = 0
smargopatch = 0
sc8in1_dtrrts_patch = 0
fallback = 0
logport = 0
caid = 0500
boxid =
fix9993 = 0
rsakey =
ins7e =
ins7e11 =
force_irdeto = 0
boxkey =
atr =
ecmwhitelist =
detect = cd
nagra_read = 0
mhz = 500
cardmhz = 357
ident = 0500:025900
chid =
class =
aeskeys =
group = 1
emmcache = 0,0,0
blockemm-unknown = 0
blockemm-u = 0
blockemm-s = 0
blockemm-g = 0
saveemm-unknown = 0
saveemm-u = 0
saveemm-s = 0
saveemm-g = 0
blockemm-bylen =
lb_weight = 100
savenano =
blocknano =
dropbadcws = 1
ccchop = 0
deprecated = 0
audisabled = 0
auprovid =
ndsversion = 0
ratelimitecm = 0
ratelimitseconds = 0
cooldown = 0,0
2012/08/14 12:20:17 101054F0 r tvr [internal] card detected
class 0500 025900 000000000000000A 0000000A 2012-03-23 2012-09-26 TVR (16E)
2012/08/14 12:20:18 101054F0 r tvr [internal] ATR: 3F 77 18 00 00 C2 14 00 C1 68 90 00
2012/08/14 12:20:20 101054F0 r tvr [internal] Maximum frequency for this card is formally 5 Mhz, clocking it to 5.00 Mhz
2012/08/14 12:20:21 101054F0 r tvr [internal] type: Viaccess (standard atr), caid: 0500, serial: ##########
2012/08/14 12:20:22 101054F0 r tvr [internal] providers: 3 (FFF720,025900,025910)
2012/08/14 12:20:22 101054F0 r tvr [internal] ready for requests
2012/08/14 12:20:22 101054F0 r tvr [internal] found cardsystem viaccess
2012/08/14 12:20:22 101054F0 r tvr [viaccess] card detected
2012/08/14 12:20:22 101054F0 r tvr [viaccess] serial: ##########
2012/08/14 12:20:22 101054F0 r tvr [viaccess] provider: 1, id: #################, sa: ########, geo: empty
2012/08/14 12:20:22 101054F0 r tvr [viaccess] provider: 2, id: ###################, sa: ########, geo: FF FF FF FF
2012/08/14 12:20:22 101054F0 r tvr [viaccess] class: 0A, expiry date: 2012/03/23 - 2012/09/26
2012/08/14 12:20:22 101054F0 r tvr [viaccess] class: 0A, expiry date: 2011/09/28 - 2012/03/28
2012/08/14 12:20:22 101054F0 r tvr [viaccess] class: 0A, expiry date: 2011/09/19 - 2012/03/28
2012/08/14 12:20:22 101054F0 r tvr [viaccess] class: 0A, expiry date: 2011/09/15 - 2011/09/28
2012/08/14 12:20:22 101054F0 r tvr [viaccess] class: FF, expiry date: 2009/12/14 - 2010/01/12
2012/08/14 12:20:22 101054F0 r tvr [viaccess] provider: 3, id: ###################, sa: ########, geo: FF FF FF FF
2012/08/14 12:20:23 0 s init for all local cards done
Mi-a facut si mie figuri mai demult, tot asa dar lua din share. Am schimbat bin-ul.
