How To install CCcam 2.1.1 on AzBox HD Elite / Pre
How To install CCcam 2.1.1 on AzBox HD Elite / Premium
'' Tutorial : CCcam 2.1.1 for AzBox HD
1. Download and extract on Your PC archive Cccam 2.1.1 AzBox HD.rar
2. Connect on Your AzBox HD by FTP manager ( You can get one free File Zilla on :
[Only registered and activated users can see links. Click Here To Register...] ).
3. Enter the /EMU directory and transfer there directory lib which is located in extracted archive on Your PC. When transfer is finished select all files and give CHMOD 755 to them.
4. Now, enter the OpenXCAS folder on AzBox HD receiver, so You will have /EMU/OpenXCAS , and transfer there two files : module.seq and openxcas.conf which are located in OpenXCAS folder of extracted archive. Give CHMOD 755 to that two files.
5. Now transfer in /EMU/OpenXCAS folder named as dvbapiCAS which is located in OpenXCAs directory of extracted archive. Enter in that directory, so You will have /EMU/OpenXCAS/dvbapiCAS and give CHMOD 755 to 3 files : dvbapi.sh , dvbapi_module and openxcas.conf .
6. Do not forget to add Your C or N lines to CCcam.cfg file which is located inside of /EMU/lib directory.
7. After You start dvbapiCAS from Plug-ins -> OpenXCAS -> Camd activation & priority , You can test if CCcam is running by entering this in Your Web browser
: [Only registered and activated users can see links. Click Here To Register...]
in my Case, my AzBox HD in my LAN has IP adress 192.168.1.65, so I am entering
[Only registered and activated users can see links. Click Here To Register...] .
That is all for now, with this You have CCcam 2.1.1 Client and Server Installed on Your AzBox HD device . ''
HOW TO INSTALL CCcam ON AZBOX // VIDEO
HOW TO INSTALL CCcam ON AZBOX //VIDEO
How To change pasword on azbox //VIDEO
How To change pasword on azbox // VIDEO
Setari streaming AZBox HD
AZBox to PC
pentru streaming in wifi: (doar unicast) reteaua WiFi ramane OK
AZ>UTP>ROUTER>WiFi>PC (AZ>WiFI>ROUTER>WiFi>PC:netestat)
AZBox:
- ip:192.168.X.X(adresa IP a computerului client)
- port: 9000
- timp: nedefinit(ramane setat pe ultimile vs. fw)
in PC(VLC):
- protocol: UDP
- ip: fara ip,224.1.1.100 sau 192.168.X.X(adresa IP a PC)
- port:9000
udp://:9000
udp://@224.1.1.100:9000
udp://@192.168.X.X:9000
pentru streaming LAN (accepta muticast), "taie" reteaua de WiFi ptr. restul device-urilor.(la mine)
AZ>UTP>ROUTER>UTP>VLC
AZBox:
- ip:224.1.1.100(adresa IP a computerului client)
- port: 9000
- timp: nedefinit
in PC(VLC):
- protocol: UDP
- ip:224.1.1.100
- port:9000
functioneaza perfect SD, la HD1080 face un pic de freeze, cele 720 merg bine.
testate pe FW 0.9.4466,VLC v.1.0.5,Vista, WiFi N, CAT5.
PC to AZBox
pentru IP CHANNEL in AZBox se seteaza:
- protocol:UDP
- channel name: ~la alegere~default VideoLAN
- ip address: ~adresa ip a PC(192.168.X.X)
- port n°:~1234~
- buffer size:~99999~
In PC(VLC)
se activeaza transcodarea fluxului in incapsulare MPEG-TS cu codec video H264 si audio AAC(TS).
pentru inregistrari in VLC, se activeaza in Vizualizare/Controale avansate..(folderul initial este in C:/user/Documents)
rulat cu succes mkv, DVD,DVD ISO, radio online, webcam
AZBox HD streaming in internet
>>trimitere de flux video(canale TV) in internet prin VLC Player
ex: trimiterea unui meci,film... catre prieteni,....direct din AZBox
setari AZBox HD:
- port: 9000
- timp: nedefinit
setari PC(VLC client-server)
Difuzare ca flux(Crtl+S):
SURSA:
Retea/Protocol UDP, port 9000; (ex: udp://@:9000)
click "Flux",
destinatii:
HTTP; "adauga"
"Adresa":acelasi IP setat in AzBox:192.168.X.X:8080(adresa IP a computerului client), se activeaza transcodarea dupa caz, se activeaza "Afiseaza local" daca se doreste vizionarea si pe propriul PC.
Code:
:sout=#transcode{vcodec=h264,vb=800,scale=1,acodec=mp4a,ab=128,channels=2,samplerate=44100,scodec=dvbs}:std{access=http,mux=ts,dst=192.168.X.X:8080} :sout-all :sout-keep
se deschide(port forwarding) poarta "8080" in router pe adresa :192.168.X.X(adresa IP a computerului client)
pentru IP dinamic se creeaza host dyndns
sesiunea se deschide cu VLC, (Crtl+N) protocol HTTP/your IP ori host dyndns port 8080
Code:
ex:http://XX.XX.XXX.XX:8080*** http://dyndns_host:8080
-testat OK pe client la 2500km in mod WiFi.
:cheers:
HDD mai mare de 1TB pe AzBox
Se pare ca merg "intrate" si hdd-uri mai mari de 1TB in AZBox.
pentru asta se creeaza 2 partitii active cu Acronis Disk Director Suite.
Pentru ca AZbox sa poata monta si a doua partitie se modifica fisierul:
DISK1/hdd_tools/check_hdb.sh, cu introducerea liniei: /bin/mount /dev/hdb2 /DATA/hdb2 dupa linia similara /bin/mount /dev/hdb1 /DATA/hdb1.
Pentru a modifica acest fisier se trece fisierul de la mod ro la rw
in telnet: mount-o remount,rw /dev/mtdblock5 /DISK1, dupa modificare se revine la modul ro: mount-o remount,ro /dev/mtdblock5 /DISK1
Reboot system
P.S. Am incercat trecerea HDD-ului pe UDMA6 cat duce hardul, dar se pare ca Azbox cunoaste maxim UDMA2.
Meniu în limba română pe Azbox
Cum să adăugam meniul in limba romană in azbox hd
trecem hda1/MMP in modul citire/scriere(după restart va reveni in mod "ro")
in telnet:
Code:
mount -o remount,rw -t ext3 /dev/hda1 /MMP
copiem dosar "Romanian" in:
Code:
/MMP/hd/System/message-td210
(in dosarul "Romanian" sunt prezente 16 fişiere text cu traducerile, pentru a modifica folosim Notepad++ şi păstrăm formatul!,
după care urcăm in azbox cu comanda de trecere in "rw")
chmod 755
inlocuim(sau modificăm) fişierul "setup_language.sh" din
Code:
if [ $# -ne 1 ]; then
exit 0
fi
# english reset
English_reset ()
cd /DISK2/message/
rm *.txt
echo 0 > .language
for i in `find ../../MMP/hd/System/message-td210/English -name '*.txt'`; do
ln -s $i ./
done
cd -
PortugueseP_reset ()
cd /DISK2/message/
rm *.txt
echo 1 > .language
for i in `find ../../MMP/hd/System/message-td210/PortugueseP -name '*.txt'`; do
ln -s $i ./
done
cd -
PortugueseB_reset ()
cd /DISK2/message/
rm *.txt
echo 101 > .language
for i in `find ../../MMP/hd/System/message-td210/PortugueseB -name '*.txt'`; do
ln -s $i ./
done
cd -
Dutch_reset ()
cd /DISK2/message/
rm *.txt
echo 2 > .language
for i in `find ../../MMP/hd/System/message-td210/Dutch -name '*.txt'`; do
ln -s $i ./
done
cd -
Czech_reset ()
cd /DISK2/message/
rm *.txt
echo 3 > .language
for i in `find ../../MMP/hd/System/message-td210/Czech -name '*.txt'`; do
ln -s $i ./
done
cd -
Deutsch_reset ()
cd /DISK2/message/
rm *.txt
echo 4 > .language
for i in `find ../../MMP/hd/System/message-td210/Deutsch -name '*.txt'`; do
ln -s $i ./
done
cd -
Russian_reset ()
cd /DISK2/message/
rm *.txt
echo 5 > .language
for i in `find ../../MMP/hd/System/message-td210/Russian -name '*.txt'`; do
ln -s $i ./
done
cd -
Spanish_reset ()
cd /DISK2/message/
rm *.txt
echo 6 > .language
for i in `find ../../MMP/hd/System/message-td210/Spanish -name '*.txt'`; do
ln -s $i ./
done
cd -
Polish_reset ()
cd /DISK2/message/
rm *.txt
echo 7 > .language
for i in `find ../../MMP/hd/System/message-td210/Polish -name '*.txt'`; do
ln -s $i ./
done
cd -
Serbian_reset ()
cd /DISK2/message/
rm *.txt
echo 8 > .language
for i in `find ../../MMP/hd/System/message-td210/Serbian -name '*.txt'`; do
ln -s $i ./
done
cd -
Hungarian_reset ()
cd /DISK2/message/
rm *.txt
echo 9 > .language
for i in `find ../../MMP/hd/System/message-td210/Hungarian -name '*.txt'`; do
ln -s $i ./
done
cd -
Hellenic_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Hellenic -name '*.txt'`; do
ln -s $i ./
done
cd -
Romanian_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Romanian -name '*.txt'`; do
ln -s $i ./
done
cd -
Italian_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Italian -name '*.txt'`; do
ln -s $i ./
done
cd -
French_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/French -name '*.txt'`; do
ln -s $i ./
done
cd -
Slovak_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Slovak -name '*.txt'`; do
ln -s $i ./
done
cd -
Turkish_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Turkish -name '*.txt'`; do
ln -s $i ./
done
cd -
Arabic_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Arabic -name '*.txt'`; do
ln -s $i ./
done
cd -
Danish_reset ()
cd /DISK2/message/
rm *.txt
echo 10 > .language
for i in `find ../../MMP/hd/System/message-td210/Danish -name '*.txt'`; do
ln -s $i ./
done
cd -
# routine
if [ $1 -eq 0 ]; then
English_reset
elif [ $1 -eq 1 ]; then
PortugueseP_reset
elif [ $1 -eq 2 ]; then
PortugueseB_reset
elif [ $1 -eq 3 ]; then
Dutch_reset
elif [ $1 -eq 4 ]; then
Czech_reset
elif [ $1 -eq 5 ]; then
Deutsch_reset
elif [ $1 -eq 6 ]; then
Russian_reset
elif [ $1 -eq 7 ]; then
Spanish_reset
elif [ $1 -eq 8 ]; then
Polish_reset
elif [ $1 -eq 9 ]; then
Serbian_reset
elif [ $1 -eq 10 ]; then
Hungarian_reset
elif [ $1 -eq 11 ]; then
Hellenic_reset
elif [ $1 -eq 12 ]; then
Romanian_reset
elif [ $1 -eq 13 ]; then
Italian_reset
elif [ $1 -eq 14 ]; then
French_reset
elif [ $1 -eq 15 ]; then
Slovak_reset
elif [ $1 -eq 16 ]; then
Turkish_reset
elif [ $1 -eq 17 ]; then
Arabic_reset
elif [ $1 -eq 18 ]; then
Danish_reset
fi
chmod 755
repornim AzBox
selectăm Bulgarian (nu am găsit incă unde să adaug/modific pentru Romanian )
O puteţi modifica după bunul plac, deci fără carcoteli...
Language-Patch Romanian Installer v.1.0 Azbox HD
se dezarhiveaza si se copieaza prin FTP in: /tmp
in telnet dam comanda:
Code:
chmod 755 /tmp/patch_RO/*
/tmp/patch_RO/install
