stie cineva ceva de asta
Este un Tuner Satelit. Digital. Stereo. PCI. Are Telecomanda. Are urmatoarele Intrari SVIDEO + RCA. Captura MPEG 2. Autoscan. TimeShifting. PiP.
Pretul in jur de 100 Roni.
Altceva mai special????
ma interesa daca merge cu progdvb, ceva cam, nu doar pt programele fta.
Din cate-mi aduc aminte merge.......problema e de compatilibilate cu noile softuri dar cred ca a fost inclusa..in mai toate acuma.
Are drivere BDA deci e compatibil cu toate aplicatiile.
Title The DVB-S 100 BDA Driver 2007/06/22
Version V6.0.1020.4
Size 2.89 MB
Operating System Windows XP / Vista
Description 1.It supports Microsoft Windows XP and Vista operation system.
2.Before update and install this latest version,please remove the previous version and reboot PC.
la progdvb
Currently works with DVB-S, DVB-S2, DVB-T and DVB-C cards of the following manufactures:
Anysee (E30S Plus,...)
AverMedia DVB-S
Azurewave (TwinHan) (VP-1027, VP-1034, VP-1041,... ).
BroadLogic 2030/1030
Compro VideoMate DVB-S
Digital everywhere FireDTV/FloppyDTV
DVBWorld USB2.0 DVB-S/DVBWorldDTV(PCI-Sat), Acorp TV878DS/DS110/DS120, Nextorm NBS240/NSC120
GeniaTech products(Digistar DVB-S PCI, satbox, TVStar, Digistar2, Digiwave 103G,...)
Hauppauge
Kworld DVB-S 100 compatible (Vstream, Dynavision..... )
LifeView FlyDVB
10moons
Netcast DVB
NEWMI Advanced DVB
Pinnacle
Technotrend
Tevii
TBS Q-Box
Technisat
Telemann Skymedia 300 DVB (not official)
Tongshi
Terratec
St@rKey usb box
Cards with BDA driver (possible issues with some cards)
Also works without a card, for example, as a video player or as a broadcast client
Multumesc pentru raspunsuri.
Merita banii o placa dvb??
Din toate punctele de vedere merita sa cumperi o placa dvb-s, evident trebuie sa alegi cu grija placa pe care vrei sa o cumperi , cel mai mult pentru suportul de drivere/software fiindca dupa cat de profi e tunerul nu te poti lua, fiindca la placi tot timpul va fi la nivel mediocru tunerul, oricum peste dm500... :)
..................titrarile merg?
Tot ce tine de receptie date , tine de placa, si de treaba asta se ocupa in totalitate fiecare, unele au facilitati gen diseq1.2 unele nu.
Dar titrarile, subtitrarile, decodare, si tot ce e in afara de ce vine de la satelit e software si nu tine de placa, aici ma refer ca faza cu titrarile si toate restul functioneaza datorita aplicatiilor, nu tine de placa pe care o ai.
ieri am primit placa. am instalat drivere si progdvb. am pus vplug si am reusit sa deschid 1w. nu am reusit sa fac sa mearga flycccam si cu telecomanda tre sa mai vad. daca exista pe undeva un "how to" ceva.....help. o sa mai revin cu detalii.
am reusit sa o fac sa mearga. pana acum cu DVB dream a mers cel mai bine, chiar si telecomanda. dezavantaj .... proramul asta nu stie de titrari dvb...poate pe viitor. pana acum e super ok...si cccam e ok.
multa stima
Pentru uzzy2008,spune-mi te rog ce soft folosesti acum la placa k-world,keyuri si asa mai departe,poti folosi mess-ul ca sa imi raspunzi daca vrei,mess: "ianaalina",sau imi poate raspunde oricine are aceasta placa...multumesc pentru intelegere,fac cinste cu o :drinks:
buna. acum folosesc progdvb dar nu merge telecomanda. am mai folosit si dvbdream, asta e super ok, merge si telecomanda numai ca nu stie de titrari dvb(nu ai titrare la gigi film etc.). eu sunt multumit de placa. am mai folosit si altdvb dar fara succes. ambele softuri merg cu vplug si flycccam.
numai bine.
regula 12
Salut,
si eu am aceasta placa si momentan sunt pe Amos din cauza de B**m este dupa receptorul lor in loop.
Eu momentan folosesc programul Altdvb imi merge cel mai bine cu alte programe gen progdvb respectiv dvbdream nu se intelege la codecuri cred ?! deoarece merge cu foarte multe intreruperi .
Poate facem schimb de experienta tu cu dvbdream si eu iti dau setarile de la altdvb, folosesc si Vplug respectiv s2emu am deschis ceva sport2...codare SECA etc...mai putin ce ma intereseaza pe mine
Poti sa-mi dai pm cu setarile ptr flyccam respectiv vplug eventual ce versiuni folosesti
De telecomanda poti sa folosesti si o telecomanda gen mediacenter eu momentan asa ceva folosesc :):cheers:
ps:Eu unu ma gandeam sa imi cumpar un tuner standalone sau o placa DVB-S2 gen Tevii deoarece daca aceasta placa merge asa de bine :)
Nu iti va merge cu niciun emu ce te intereseaza pe Amos (boom)!Quote:
Originally Posted by amorphys [Only registered and activated users can see links. Click Here To Register...]
Scoate-o din loop si conecteaz-o la o antena mobila ca sa o folosesti pentru ceva mai bun...
