se poate pune si de pe stick:)Quote:
Originally Posted by cris [Only registered and activated users can see links. Click Here To Register...]
add tps function. need upgrade tps key(tps.bin) at every 3 days. please upgrade s/w at first, then upgrade tps.bin by usb(like upgrade software).
tps.bin can find in [Only registered and activated users can see links. Click Here To Register...] (other stb web same have tps.bin), we can directly upgrade this tps.bin by usb. annex tps.bin data is 2008.9.18~2008.9.21.
can not upgrade tps.bin by chedit.exe now. we are modifing tools for upgrade tps.bin. will give you new tools about this week end.[Only registered and activated users can see links. Click Here To Register...] noi cei fara stik mai asteptam pina la sfirsitul saptaminii:)
softul 3.37 pt 791
cred ca fixeaza problema tps-ului , dar se pare ca la rai-ulile de pe hotbird sunt ceva probleme
Uite ce spune Magic :
"hello:
can not upgrade tps.bin by chedit.exe now. we are modifing tools for upgrade tps.bin. will give you new tools about this week end."
[Only registered and activated users can see links. Click Here To Register...] ====>soft 3.37 pentru 791
Da, pe softul nou functioneaza TPS.
Si cum se misca?
Cam toate receptoarele care le-am vazut si aveau implementata si varianta TPS se miscau ca melcul plus blocaje.
se misca ca si pana acumQuote:
Originally Posted by pytonu [Only registered and activated users can see links. Click Here To Register...]
adica bine
tu de ce nu incerci?
este cel mai tare receptor de pe piata la pretul care il are si la cat suport are din parte lui Magic:cheers:
echo 790? deja depasit? ca vad ca 3.37 e numai pt 791 :(
la gunoi cu el?
o sa apara dar mai asteptati putin
nu e depasitQuote:
Originally Posted by badeaghio [Only registered and activated users can see links. Click Here To Register...]
aveti rabdare
acum e drept ca prima data apar softuri pentru 791
dar se pot face inca multe si cu 790 cu key si cu sharingul
nou loader pt tps.bin=====> Chedit 9.4
newecho loder 771 and 791 new fuction tps bin upgrader
:cheers:Cipcirip99 m-ai dai raspuns pe forum???:cheers: sa bem o bere la Horezu?
uite ce vesti avem , dar nu si softul
se pare ca Magic lucreaza , dar....nu vedem noi inca:cheers:
am pus si softul dincolo
3.38 pentru 791
dupa ce puneti lista de canale trebuie softcam.key pt ca se sterg keyle
IL GASITI SI AICI : [Only registered and activated users can see links. Click Here To Register...]
Salut,
de azi sint fericit posesor de echo 791 si asta in urma celor citite pe forumul vostru.
am instalat versiunea 3.35 cu key, totul a fost ok , ma si miram cat de simplu a fost dar m-a mancat undeva sa fac update la versiunea 3.38 si acum in lista satelitilor nu mai gasesc intelsat 1002 ci doar hotbird, astra1ek, si mai multe newsat01-02--etc neconfigurate
Va rog sa ma ajutati cu o solutie, eventual cum as putea sa fac un downgrade.
Pls....am facut buba
