TinySniffer is a USB sniffer based on the Allwinner H3-powered NanoPi Neo Air SBC, designed...
The Pico Video4 Display is a Raspberry Pi RP2040-powered board that supports up to 4...
Sagire AI’s SagireEdge AI 600 is a SMARC-compliant system-on-module (SoM) and a development kit based...
Lattice Semiconductor has added two new devices to its small, low-power Lattice Certus-NX FPGA family,...
GEEKOM has yet another discount for us with the AMD Ryzen 9 8945HS-powered GEEKOM A8...
Waveshare “ESP32-S3-Touch-LCD-4.3B” is a capacitive touch display development board built around an ESP32-S3 SoC with...
Today, I will be reviewing the AgroSense LoRaWAN sensors from Makerfabs designed for high-precision agriculture....
Waveshare Pi5 Module BOX is a multi-functional mini-computer kit designed for the Raspberry Pi 5....
AAEON ACP-1078 is a 7-inch touchscreen panel PC powered by a Rockchip RK3568 quad-core Cortex-A55...
The T2-U is a development board compatible with the Tuya Smart Home framework that features...
The iBASE IB961 from FORTEC Integrated (previously known as Distec) is a 3.5-inch Single Board...
Electronic Cats’ Flipper Add-On CANBus is a new add-on board for the Flipper Zero adding...
Mekotronics R58X-IP68 is a Rockchip RK3588-powered embedded mini PC with an IP68 ingress protection rating...
Following Arm’s decision to stop supporting Mbed from July 2026 onwards, Arduino has now decided...
The TinyWatch S3 is an ESP32-S3 development board in a smartwatch form factor from Seon...
Radxa ROCK 5 ITX is a mini-ITX motherboard powered by a Rockchip RK3588 octa-core Cortex-A76/A55...
ASRock DSF-A6000 embedded box PC is built around the AMD Ryzen Embedded R2314 processor with...
LILYGO T-Halow is an ESP32-S3 board equipped with a WiFi HaLow module with up to...
Remote.It, a company providing remote access services, has released an open-source project to enable Raspberry...
We’ve already checked out the hardware for LattePanda Mu and tested it on Windows 11...
