Salut Horatiu cutia aceia 991 terestrial,se poate face ceva cu ia?:cheers:Quote:
Originally Posted by cris [Only registered and activated users can see links. Click Here To Register...]
Spaniolule la voi a aparut echo nou?Quote:
Care?.... cel HD?
da ala cind apare?Quote:
Originally Posted by dic_star79 [Only registered and activated users can see links. Click Here To Register...]
ce faci si cu echo 791 poti face si cu 991 +plus ca mai poti prinde si semnal digital terestruQuote:
dami un ID sa vb:)Quote:
Originally Posted by rock5 [Only registered and activated users can see links. Click Here To Register...]
Dar ATENTIE ! la terestrial , DSB-991 stie numai MPEG-2 nu si MPEG-4 :sorry: ce este cam in toata Europa la DVB-T.Quote:
Numai bine.
cu ce flash merge {tps aes softcam}?....cu 3.33 nu merge.
:)ce soft se pune la un receiver virgin 791?Quote:
cu SBCL +vplug +transer to net mergeQuote:
Originally Posted by felix73 [Only registered and activated users can see links. Click Here To Register...]
2.92 + alta versiune superioara(3.33)Quote:
asta stiam ,dar am crezut ca poate merge cu vreun soft ,aes key in softcam multumesc oricum HORATYUQuote:
pai cu gbox sharing iara poti vedea TP$
Pe 1w- nu se mai vede nimic... E doar la mine,sau e o schimbare de key sau de sistem?
pina la urmatorul sistem ....:tv:Quote:
Originally Posted by joliyy [Only registered and activated users can see links. Click Here To Register...]
