(PR) NVIDIA Recommends GeForce RTX 5070 Ti GPU to AI Content Creators
The [Only registered and activated users can see links. Click Here To Register...]—built on the NVIDIA Blackwell architecture—are out now, ready to power generative AI content creation and [Only registered and activated users can see links. Click Here To Register...]. GeForce RTX 5070 Ti GPUs feature fifth-generation Tensor Cores with support for FP4, doubling performance and reducing VRAM requirements to run generative AI models.
In addition, the GPU comes equipped with two ninth-generation encoders and a sixth-generation decoder that add support for the 4:2:2 pro-grade color format and increase encoding quality for HEVC and AV1. This combo accelerates video editing workflows, reducing export times by 8x compared with single encoder GPUs without 4:2:2 support like the [Only registered and activated users can see links. Click Here To Register...]. The [Only registered and activated users can see links. Click Here To Register...] GPU also includes 16G B of fast GDDR7 memory and 896 GB/sec of total memory bandwidth—a 78% increase over the GeForce RTX 4070 Ti GPU.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
XFX MERCURY Radeon RX 9070 XT OC Magnetic Air Edition Models Appear on
Amazon Canada has listed two new XFX Magnetic Air Edition designs, within the last day or so—as discovered by the VideoCardz overwatch. Mid-way through last week, the first signs of these premium customized AMD RDNA 4 graphics cards [Only registered and activated users can see links. Click Here To Register...]; courtesy of another Canadian leak. Within the same timeframe, XFX registered its "[Only registered and activated users can see links. Click Here To Register...]" SKU at South Korea's National Radio Agency. Amazon.ca's two pre-order listings—likely prematurely published by accident—provide a first look at XFX's revised "Magnetic Air" modular fan system. The [Only registered and activated users can see links. Click Here To Register...] and White Editions appear to sport plenty of loud RGB lighting zones—contrasting greatly, when compared to [Only registered and activated users can see links. Click Here To Register...].
XFX's standard MERCURY Radeon RX 9070 XT OC Magnetic Air Edition seems to visually match with the manufacturer's [Only registered and activated users can see links. Click Here To Register...]. TechPowerUp handled this powered-off unit at last month's trade event, alongside a "premium white" sample. Based on a leak—[Only registered and activated users can see links. Click Here To Register...]—the pale candidate could be an XFX SWIFT model. Product and packaging imagery for Radeon RX 9070 (non-XT) SWIFT and QUICKSILVER emerged online, allegedly sourced from Amazon South Korea. Returning to XFX's highly-anticipated top-tier Magnetic Air options; price points of CAD$1438.03 (black) and CAD$1277.51 (white) are presently displayed on Amazon Canada. VideoCardz reckons that [Only registered and activated users can see links. Click Here To Register...] will occur up until release day—both third-party listings (Fennec, Inc) mention the exact same release date: March 6. Base GPU clock speed is set at 1870 GHz, while the card's boost capability takes matters up to 3100 MHz—possibly aligning with numbers generated by an [Only registered and activated users can see links. Click Here To Register...]. An expected VRAM assignment—of 16 GB—is described by Amazon's Canuck branch. Three 8-pin power connectors are present in XFX's Magnetic Air product renders.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Numemory Releases Optane Successor: "NM101" Storage-Class Memory
Numemory has introduced the NM101, a 64 Gb storage-class memory module that uses technology similar to Intel's now-discontinued Optane architecture. The device implements phase-change memory and crossbar technology in a 3D selector-only memory structure, matching Optane's 3200 MT/s transfer rate specification. The technical architecture diverges from Intel's implementation by using a single selector in its cross-point structure rather than the dual-selector approach of 3D XPoint memory. Operating at 1.2 V with an X8 bus width, the NM101 uses 3D stacking to achieve claimed performance metrics of 10x faster read/write speeds than NAND flash. Xincun Technology, which established the Numemory division in Wuhan in 2022, holds 273 patents related to the technology, including 60 international and 213 Chinese patents. The company's R&D team of 144 engineers has developed the architecture since 2019, three years before Intel ended its Optane program.
Production plans specify an initial manufacturing target of 10,000 units monthly by the end of 2025. Guao Technology has committed ¥10 billion to establish production facilities in Zhejiang province, with additional funding from the Anji county government. The NM101's operating temperature range spans 0-70°C, suitable for standard data center environments. While the device's specifications suggest the potential for data center deployment, specific IOPS and latency metrics remain unpublished. Initial production will serve domestic Chinese servers and storage manufacturers. The technology's viability in mass production remains to be demonstrated, particularly given the manufacturing challenges that contributed to Optane's market exit. The Chinese internal market is massive, so serving only domestic companies could be enough for Numemory at the beginning. If the company continues development, worldwide expansion could pick up where Optane stopped.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
PC Enthusiast's Next Stop is... 12VHPWR Power Connector with Active Fa
Just when you thought you'd seen everything, a Taobao seller has unleashed what might be the most over-engineered power connector solution yet: a 16-pin 12VHPWR power adapter complete with its own cooling fan and real-time monitoring display. Yes, you read that right—we're now actively cooling power connectors. The $30 adapter appears as manufacturers continue struggling with melting cable problems on NVIDIA's RTX 4090 series, despite the company's claims of resolving the issue. The adapter includes an LCD screen showing real-time temperature and power consumption readings, while its 180-degree design prevents sharp cable bends that are often blamed for connection problems. However, unlike more comprehensive solutions proposed by engineering experts, it doesn't address the fundamental issue of uneven power distribution across the connector's 12 power wires.
The adapter works with RTX 4090, 4080, and 4070 graphics cards. Still, it shouldn't be used with newer RTX 50 series cards, as the sales listing doesn't mention any GeForce RTX 50 series compatibility, and the latest "Blackwell" GPU design uses an updated 12V-2x6 power connector, which still appears riddled with issues. While adding a fan to a power connector may seem excessive, an intriguing possibility is that we may soon find water-cooler power connectors for the newer 12V-2x6, so users can prevent their $2000 NVIDIA GeForce RTX 5090 GPUs from melting their power connectors. Irony aside, power delivery safety is a growing concern, and no clear resolution exists. NVIDIA has [Only registered and activated users can see links. Click Here To Register...] that these problems are now solved, but the issues [Only registered and activated users can see links. Click Here To Register...] as more users get ahold of their RTX 5090 GPUs.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Arc & Snapshot Games Unveil Chip 'n' Clawz vs. The Brainioids, Ma
We're proud to reveal Chip 'n' Clawz vs. The Brainioids, a new action-packed strategy game that combines thrilling third-person action with the strategic depth of real-time strategy (RTS) gameplay - all set in a colorful, comic book-style world brimming with a unique cast of characters. Whether strategizing in battle or diving into the action firsthand, you will find a uniquely engaging and heroic adventure that keeps you coming back for more.
PLAY THE DEMO
As part of Steam Next Fest: February Edition from February 24 to March 3, the first-ever [Only registered and activated users can see links. Click Here To Register...] for you to experience this exciting heroic action RTS adventure before it launches on PC, Xbox and PlayStation this spring with cross-platform play support at launch. The demo will give you plenty of Chip 'n' Clawz action to dive into, as it'll feature online and local campaign co-op and PvP multiplayer support, four Mission levels, two Challenge levels, two PvP maps, and plenty of weapons, mods, collectibles and base building options! If you want to join the Chip 'n' Clawz community and find fellow Earthlings to adventure with or challenge in PvP, join the [Only registered and activated users can see links. Click Here To Register...]![Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
MSI RTX 5070 Ti VENTUS 3X Not Included in Launch Lineup, MSRP Models R
Over the past three weeks, press outlets and the buying public have levelled heavy criticism at NVIDIA board partners. The launches of three GeForce RTX 50-series "Blackwell" GPUs have—so far—been problematic; based on news reports and community feedback. Prior to release (on February 20), VideoCardz anticipated major price fluctuations for an all-custom portfolio of [Only registered and activated users can see links. Click Here To Register...] graphics cards. The publication did not hold back with its [Only registered and activated users can see links. Click Here To Register...]; one of Team Green's big time AIBs. Only a small selection of baseline MSRP ($749) conformant models were available on day one, and VideoCardz posited that manufacturers would implement price hikes soon after launch. A [Only registered and activated users can see links. Click Here To Register...] continues their investigation into a [Only registered and activated users can see links. Click Here To Register...], as well as so-called "fake promotions."
VideoCardz repeated its belief that ASUS will jack-up the asking price for its [Only registered and activated users can see links. Click Here To Register...] model. When looking at Newegg's listing of baseline MSRP cards, the intrepid investigator stumbled up another notable absence: "we wrote three articles about the ASUS RTX 5070 Ti PRIME model not being listed as an MSRP card by retailers, which finally led ASUS to intervene (most likely for a limited time) to sell this card at the promised price. What we can immediately notice is the lack of the VENTUS 3X model from MSI, which was basically 90% of the MSRP card review coverage yesterday, as NVIDIA had no Founders Edition card for this launch and relied on board partners. In fact, the [Only registered and activated users can see links. Click Here To Register...] is not even included in the official launch, meaning that the card you saw yesterday in reviews is simply not available anywhere." It should be noted that TechPowerUp received an [Only registered and activated users can see links. Click Here To Register...] sample unit for evaluation purposes (review guide pricing was $749); Newegg lists this particular model with a [Only registered and activated users can see links. Click Here To Register...], but stock is unavailable (at the time of writing).[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Rockstar Reveals Free Upgrade for Grand Theft Auto V PC Version,
On March 4, [Only registered and activated users can see links. Click Here To Register...] on PC is getting a free upgrade with sought-after features previously only available in the PS5 and Xbox Series X|S versions of GTA Online—including all the latest vehicles and performance upgrades available at Hao's Special Works, animal encounters, and access to purchase a GTA+ Membership—along with improved graphics options, faster loading times, and more. All players who currently own GTAV on PC will be able to upgrade to this new version for free, with the ability to migrate your Story Mode and Online progress.
New Features on PC
Once upgraded, current PC players—along with anyone playing the game for the first time—will have access to a full suite of much-requested GTA Online upgrades previously only available on the latest consoles. This upgraded version of GTA V on PC also features all of our recent player experience improvements for GTA Online, including [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] to help keep GTA Online fun for everyone.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Complete Specifications of AMD Radeon RX 9070 and RX 9070 XT Leaked
[Only registered and activated users can see links. Click Here To Register...] obtained AMD Radeon RX 9070 series specifications, which appear to be the official final configurations of the upcoming RDNA 4 GPUs. As we previously expected, the lineup consists of two models based on the Navi 48 GPU, which integrates 53.9 billion transistors on a 357 mm² die using a 4 nm (N5) process from TSMC. Both the RX 9070 XT and RX 9070 utilize identical memory configurations: 16 GB of GDDR6 memory running at 20 Gbps across a 256-bit bus, delivering 640 GB/s bandwidth. Each card implements 64 MB of 3rd Generation Infinity Cache and supports PCIe 5.0 x16 interface standards. The RX 9070 XT features 64 RDNA 4 Compute Units, equating to 4096 Stream Processors, 64 Ray Accelerators, and 128 AI Accelerators. It operates at a 2400 MHz game clock and 2970 MHz boost clock, providing 48.7 TFLOPS of single-precision FP32 compute performance.
Power requirements include a [Only registered and activated users can see links. Click Here To Register...] and a recommended 750 W power supply. The standard RX 9070 reduces specifications to 56 Compute Units (3584 Stream Processors), 56 Ray Accelerators, and 112 AI Accelerators. Clock speeds decrease to 2070 MHz game clock and 2540 MHz boost clock, with correspondingly lower power requirements of 220 W TBP and a recommended 650 W power supply. Since both SKUs use the same Navi 48 die, the separation between them is likely better binning for the XT version, and lower bins end up for the non-XT version. Both models support HDMI 2.1b and DisplayPort 2.1a UHBR13.5 outputs. AMD has confirmed the cards will launch exclusively through board partners with no reference designs planned and that the official unveiling will be in March. Earlier rumors have suggested a $699 price tag for the Radeon RX 9070 XT SKU, putting its expected price/performance near NVIDIA's GeForce RTX 5070 Ti. AMD notes that 85% of gamers buy cards below $700, which the RDNA 4 series will focus on.[Only registered and activated users can see links. Click Here To Register...]
Quit Struggling With Functions on Excel With This Training Bundle
Anyone who's ever worked an office job has probably used or encountered Microsoft's Excel app. The spreadsheet tool is handy, but it's not necessarily easy to navigate—in fact, you may have even nearly pulled your hair out trying to figure out how to manipulate Excel functions.
Instead of struggling with using spreadsheets and wasting precious time, [Only registered and activated users can see links. Click Here To Register...] with these e-learning courses. You could just become an Excel master—and Google Sheets, too—once you learn these tips and tricks. Grab lifetime access while it's available for only $34.99 (reg. $140).
Want to become proficient in Excel? Grab this [Only registered and activated users can see links. Click Here To Register...] for just $34.99 while supplies last.[Only registered and activated users can see links. Click Here To Register...]
(PR) Goodram Industrial to Showcase Latest Memory Solutions at Embedde
The Polish industrial memory manufacturer will once again be showcasing its product range at Embedded World, which takes place in Nuremberg, Germany, from 11 to 13 March. The company will be showcasing its latest solutions for industrial, defense, data center and artificial intelligence (AI) applications. Goodram Industrial offers DRAM modules, SSDs and Flash memory for use in demanding industrial environments. Manufacturing in Poland, full memory testing and an in-house R&D department underpin product quality. Goodram Industrial memory is characterized by reliability, long life and resistance to extreme operating conditions. The range includes customized solutions for automation, robotics, transportation, medical, security systems, energy and telecommunications.
This year's launches include DDR5 CUDIMM/CSODIMM memory modules. These offer not only high capacity but also increased speed and stability of operation. Another interesting innovation is a microSD card with pSLC-Boost technology, which offers up to 100,000 program/erase cycles, far exceeding the standard parameters.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Bloober Team and KONAMI Extend Collaboration
[Only registered and activated users can see links. Click Here To Register...], a legendary name in the gaming industry, sought a partner who could breathe new life into one of its most iconic franchises—[Only registered and activated users can see links. Click Here To Register...]. [Only registered and activated users can see links. Click Here To Register...] was selected for their expertise in horror and atmospheric storytelling, and in 2021, both companies signed a partnership agreement. In October 2022, during the official SILENT HILL Transmission livestream, it was announced that Bloober Team was working on a [Only registered and activated users can see links. Click Here To Register...], widely regarded as one of the best psychological horror games in history.
The success of the remake proved that Bloober Team had perfectly captured the atmosphere and depth of the original while introducing crucial innovations. The game was well-received by players, earning an 86/100 rating on Metacritic and an 88/100 on OpenCritic, along with numerous awards, including Game of the Year 2024 from IGN Japan and Best Horror Game of the Year from the IGN Community Awards.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Strix Point-Powered Framework Laptop 13 Introduced With Prices Startin
Framework has finally introduced its next-generation Framework Laptop 13, now powered by the extremely potent [Only registered and activated users can see links. Click Here To Register...]. The product is already available for pre-order on Framework's website, with prices starting from $899 for the Do-It-Yourself variant, and [Only registered and activated users can see links. Click Here To Register...]. From the outside, the design of the product has been left mostly unchanged, which may appear somewhat disappointing at first, although an unaltered design likely indicates compatibility of components between the two laptops, which is undoubtedly one of the primary selling points for the Framework Laptop.
As mentioned, the biggest upgrade that the [Only registered and activated users can see links. Click Here To Register...] brings to the table is the new selection of processors, with the Ryzen AI 9 HX 370 APU sitting at the highest-end. Unsurprisingly, the Strix Point APUs allow for excellent performance improvements to both CPU and GPU side of things. With 12 cores (4 Zen 5 + 4 Zen 5c) and 24 threads, the highest-end Ryzen AI 9 HX 370 APU performs admirably well in benchmarks as well as real-life workloads. The Radeon 890M iGPU is among the fastest available on the market, trading blows with the Arc 140T iGPU in synthetic benchmarks. Of course, the 50 TOPS NPU allows for CoPilot functionality, for those who care. The Windows variant ships with a dedicated CoPilot key as well, while the DIY variant does not.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Baya Systems and Semidynamics Collaborate to Accelerate RISC-V Sy
Baya Systems, a leader in system IP technology that empowers the acceleration of intelligent compute, and Semidynamics, a provider of fully customizable high-bandwidth and high-performance RISC-V processor IP, today announced a collaboration to boost innovation in development of hyper-efficient, next-generation platforms for artificial intelligence (AI), machine learning (ML) and high-performance computing (HPC) applications.
The collaboration integrates Semidynamics' family of 64-bit RISC-V processor IP cores, known for their exceptional memory bandwidth and configurability, with Baya Systems' innovative WeaveIP Network on Chip (NoC) system IP. WeaveIP is engineered for ultra-efficient, high-bandwidth, and low-latency data transport, crucial for the demands of modern workloads. Complementing this is Baya Systems' software-driven WeaverPro platform, which enables rapid system-level optimization, ensuring that key performance indicators (KPIs) are met based on real-world workloads while providing unparalleled design flexibility for future advancements.[Only registered and activated users can see links. Click Here To Register...]
TechPowerUp GPU-Z v2.64.0 Released
TechPowerUp today released the latest version of TechPowerUp GPU-Z, the handy graphics sub-system information, monitoring, and diagnostics utility. Version 2.64.0 comes with support for the upcoming GeForce RTX 5070 graphics card. Support is improved for the upcoming Radeon RX 9070 XT and RX 9070. Among the issues fixed are incorrect TMU/ROP/shader counts displayed for Intel Arc B570; and when a message pops up "This service has been marked for deletion" comes up, a hint has been added which says that restarting the machine solves the problem. GPU-Z no longer checks for PhysX acceleration on non-NVIDIA GPUs, which should speed up startup.
We have an update relevant to the recent Blackwell [Only registered and activated users can see links. Click Here To Register...]. On machines with no NVIDIA graphics drivers installed, and an RTX 50-series GPU such as the RTX 5090, RTX 5090D, RTX 5080, or RTX 5070 Ti installed, the ROP count is now shown as "unknown." NVIDIA drivers need to be installed for GPU-Z to read the actual ROP count of the card. This is important, because without drivers, previously, GPU-Z displayed a fallback hardcoded value for ROPs (reference spec), so we changed that to list "unknown" instead, to avoid causing confusion.
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
AMD Launches Socket AM4 Ryzen 5005 Series APUs
AMD is launching new Socket AM4 processor SKUs well into 2025, eight years into the platform's lifecycle. The company just launched six new processor models under the Ryzen 5005G series. These span the Ryzen 7, Ryzen 5, and Ryzen 3 tiers, and are all desktop APUs based on the 7 nm "Cezanne" monolithic silicon that combines up to 8 "Zen 3" CPU cores with an iGPU based on the "Vega" graphics architecture, featuring up to 8 compute units (CU). There's nothing [much] to report about the 5005G series, except that they are iGPU speed bumps of existing SKUs. These are not meant to be confused with the 5000GT series, which were CPU speed-bumps of the chips AMD launched in 2024.
Among the six new SKUs, the top-spec part is the Ryzen 7 5705G, which maxes out the silicon, enabling the full 8-core/16-thread "Zen 3" CPU with 512 KB of L2 cache per core and 16 MB of shared L3 cache; and the iGPU with all 8 CUs. This chip comes with CPU clock speeds of 3.80 GHz base with 4.60 GHz boost, with 2.20 GHz max engine clock for the iGPU. The CPU clock speeds are unchanged compared to the Ryzen 7 5700G, but the iGPU gets a 10% increase in max engine clock. The Ryzen 7 5705GE is an energy efficient variant with 3.20 GHz base and 4.60 GHz boost for the CPU to achieve a 35 W TDP, but the iGPU engine clock gets the same 200 MHz speed bump.[Only registered and activated users can see links. Click Here To Register...]
NVIDIA Ready with GeForce RTX 50-series Black Screen Issue Fix
Late last week, we reported that NVIDIA is [Only registered and activated users can see links. Click Here To Register...] a software-level bug with certain GeForce RTX 50-series "Blackwell" graphics cards exhibiting black screen and BSOD errors. The black screens appear at random, there's no set way to reproduce to cause for the bug. The display head goes black, and sometimes the OS could even run into a bluescreen of death (BSOD) halt. NVIDIA earlier this week released a video BIOS update through its add-in card (AIC) partners, which should be distributed in the support sections of the brand websites. For those without such a VBIOS update, NVIDIA says that later this week, the company will release a GeForce Game Ready driver update that applies the same VBIOS update.[Only registered and activated users can see links. Click Here To Register...]
NVIDIA GeForce RTX 5060 Ti Arriving Late-March with 16GB and 8GB Varia
NVIDIA is preparing a late-March 2025 launch of the GeForce RTX 5060 Ti following its [Only registered and activated users can see links. Click Here To Register...]. The card will reportedly come with 16 GB and 8 GB memory variants, much like its predecessor, the RTX 4060 Ti, with the 16 GB variant launching late-March, and the 8 GB variant in April. A Wccftech report sheds light on a few interesting specs of the RTX 5060 Ti. Apparently, the card comes with a total graphics power (TGP) of 180 W, which should make it possible for partners to sell cards with single 8-pin PCIe power connectors. NVIDIA is looking to target the $400 to $500 price segment with the RTX 5060 Ti series, but a lot will depend on how AMD addresses this space with its lean new "Navi 48" silicon that could probably be cut down to create SKUs that square off against the RTX 5060 Ti.
The GeForce RTX 5060 Ti, much like the RTX 4060 Ti, will come with a 128-bit wide memory bus, however, NVIDIA will give the GPU a massive upgrade in bandwidth with 28 Gbps GDDR7, giving it 448 GB/s of memory bandwidth, which is a 55% increase over the 288 GB/s that the RTX 4060 Ti has. The GB205 (or GB206?) GPU that the RTX 5060 Ti is based on could implement PCI-Express 5.0, which means that should NVIDIA opt for an 8-lane PCIe host interface to save board costs, the GPU could still enjoy bandwidth comparable to PCI-Express 4.0 x16 on systems with Gen 5 PCIe.[Only registered and activated users can see links. Click Here To Register...]
Samsung Aims for 1,000-Layer NAND by 2030, Begins Wafer Bonding at 400
Samsung aims to create 1,000-layer NAND by 2030 relying on its new "multi-BV" NAND design. [Only registered and activated users can see links. Click Here To Register...] reports that this plan involves stacking four wafers to overcome structural limits. Wafer bonding technology plays a crucial role in this progress and Samsung intends to use it to break the 1,000-layer barrier. Samsung Electronics DS division CTO, Song Jae-hyuk, pointed out that wafer bonding allows separate production of peripheral and cell wafers before joining them into one semiconductor. The Bell says this technology will likely appear first in Samsung's 10th-gen NAND (V10), while industry experts think a single wafer can hold about 500 NAND layers when implementing only cell structures. In the past, Samsung has used the COP (Cell on Peripheral) technique, a method that places the peripheral circuit on one wafer, with NAND cells stacked on top. However, as NAND layers grow, the lower peripheral parts face more pressure potentially affecting reliability.
Samsung's plan involves working with China's [Only registered and activated users can see links. Click Here To Register...], which should offer a hybrid bonding patent for V10 NAND. [Only registered and activated users can see links. Click Here To Register...] reports that the South Korean tech company will start making its V10 NAND in large quantities in the second half of 2025, with about 420-430 layers. Besides wafer bonding, Samsung adds other technologies to its NAND plan. The Bell points out that cold etching using molybdenum, and other new ideas will start with 400-layer NAND and play a key part in growing to 1,000 layers. Samsung isn't alone in trying to create ultra-high-layer NAND products. Japan's Kioxia also wants to reach this goal through its "multi-stack CBA" (CMOS Bonded to Array) technology. The company's plan is even bolder hoping to sell [Only registered and activated users can see links. Click Here To Register...] 3D NAND by 2027.[Only registered and activated users can see links. Click Here To Register...]
(PR) Shuttle Unveils New XPC nano Barebone NA10H7 PC With AMD Ryzen 7-
In today's fast-paced office environment, efficiency and productivity are key. Shuttle's latest innovation, the XPC nano Barebone NA10H7, is a compact yet powerful AI-PC that enhances everyday office operations with intelligent computing and seamless multitasking.
Smart Performance in a Compact Form
Measuring just 1 liter in volume, the NA10H7 is powered by the AMD Ryzen 7-8845HS APU with Zen 4 microarchitecture. With 8 cores, 16 threads, and integrated AMD Radeon 780M graphics, this AI-enhanced system accelerates workloads and optimizes daily office tasks. Additionally, it features an integrated Neural Processing Unit (NPU) that delivers 16 TOPS AI performance, contributing to a total AI acceleration of 39 TOPS (NPU+CPU+GPU combined). This makes the NA10H7 particularly adept at handling AI-driven workloads such as intelligent automation and predictive analytics.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Western Digital Completes Planned Company Separation
Western Digital (Nasdaq: WDC) announced the successful completion of the planned separation of the company's Flash business. Earlier this month, Western Digital held its Investor Day event where the company shared its vision, strategy and plan to enable its customers to unleash the power and value of data. Looking ahead, Western Digital Chief Executive Officer Irving Tan shares how the future of HDDs begins now [Only registered and activated users can see links. Click Here To Register...] in his latest blog post.[Only registered and activated users can see links. Click Here To Register...]
