Mutant resuscitat. Multumiri pentru laleuaneagra, bonou2, mario02, echipei OpenVIX (5.1).
Imagine buna si pt. Mut@ant hd51 opendroid 6.7.0. Cred ca este cea mai buna imagine .
incearca ATV 6.3 :)
depinde unde te uiti cu imaginea aia..
daca te uiti pa rtl2 ala german.e ok.
daca te uiti a hbo ro vezi o ****..la fel si cu opepli.
sunt imagini care sunt setate mai echilibrat.
openld,opendroid..spa..
ai o mai buna calitate pa sd,,si o idee mai slab pa hd..dar te obisnuesti.
PurE2 6.2 .usb Mutant HD51 Imagine
Openvix Mutant HD51 Imagine
Openpli Mutant HD51 Imagine
Openatv 6.2 Mutant HD51 Imagine
Openhdf 6.3 Mutant HD51 Imagine
Openvhdf 6.2 Mutant HD51 Imagine
Nightly Titan Mutant HD51 Imagine
Opendroid 6.7 Mutant HD51 Imagine
Openspa Mutant HD51 Imagine
Satdreamgr Mutant HD51 Imagine
BPanther's Neutrino Mutant HD51 Imagine
Opennfr 6.2 Mutant HD51 Imagine
Hyperion Mutant HD51 Imagine
OpenESI 8.0 Mutant HD51 Imagine
[Only registered and activated users can see links. Click Here To Register...] @edit mirel: nu e buna
asta e: [Only registered and activated users can see links. Click Here To Register...]
How to flash an image to mutant hd 51 4k uhd
HD51 Flash Manual
Important all information in the emmc memory will be deleted any multiboot images will be lost!
if you do not want to lose your multiboot images please read info update of a multiboot image with online flash util.
Before flashing please remove other USB devices !!!
1) USB stick min 2 GB minimum FAT32 prepare on PC
2) Image download of wich you want/like
3) Zip file unzip and folder "hd51" on the USB stick copy
4) Box disconnect from power
5) Insert USB stick on the front USB port
6) Print and hold the standby button on the front and power the box.
7) Wait until Flashing is on the display and release the Standby button.
8) Box starts after the flash process Automatically the first image.
Tutorial for Multiboot
How to install an Image to Multiboot:
Download your Image for install on multiboot.
IMPORTANT Don´t unzip the .zip File
Then shift it to the USB Drive
Plug the USB Device in the HD51.
Step 1: Press the blue key on the remote, then press the right key and go to Flash Online
Step 2: Now press the yellow button, now below might stand STARTUP_2 (it gives Startup 2,3. 4).
Step 3: Press the blue key and now the yellow key then go to your USB Device
Step 4: Go to the .zip and press the green button on the remote.
Step 5: Now the Ax is flashing the Image
How to use Multiboot:
Step 1: Press MENU on your remote and go to Standby/Restart then go to Multiboot and press OK
Step 2: Now you can select your image with the right/left key and start with the OK key
How to Install A HardDrive on the Mut@nt HD51 4K Enigma2 Receiver
Mutant HD51&Fransat
multumim @antenutze
Am instalat imaginea Open HDF 6.3 pe Mutant HD51, functioneaza perfect cam-ul ci+ Tricolor si cardul Focus (in cititorul de carduri). Schimbarea canalelor se face rapid intre cele doua norme de codare (similar cu schimbarea intre canalele necodate). Imaginea are de la instalare cam tot ce este necesar si usor de utilizat de novicii in E2 (cum sunt eu).
HYPERION 6.3 Mutant HD51 Imagine
tasta verde----donwload plugin-----utilities--- se gaseste pluginul ciplushelper_4.4-r0.(pkt)
---------- Post added at 14:08 ---------- Previous post was at 14:00 ----------
plugin IPTV---@ samsamsam functioneaza ca in vremurile de odlnioara
daca nu ati stiu...PURE2 este a doua imagine ce ofera posibilitatea multiboot ptr mutant...acel multiboot cu care a fost creat mutantu...
pana acum doar pe ATV era posibil..doar ca pure2 ofera doar doua imagine pe langa 4 in multiboot
http://pur-e2.club/OU/images/index.php?dir=6.2/mutant/Mutant51-2partitions/
Postez aici....nu stiu daca stiti sau nu...eu acum am descoperit...merge 4k real pe youtube....cel putin pana nu demult cand mai incercam pe ATV nu mergea...reproducea in rezolutie de full hd...pe PLI...nici atat..la ei nu merg nici 4k de pe hdd...sant in urma cu gstream..
EE..alaltaieri am pus PURE2...e o imagine care imi place mult dar nu o folosesc din cauza calitati imagini pe enigma...e o diferenta majora intre ei si PLI..dar am pus sa vad ce mai e..etc si azi zic ia sa vad pe youtube...surpriza ptr mine...merge 4k real.....codec ON2VP9...dar dezamagire....merge sacadat...procesoarele sant la full...
fac si un screenshot imediat...
daca ati stiut.....eu nu am vazut scris pe niciunde
---------- Post added at 21:02 ---------- Previous post was at 20:58 ----------
---------- Post added at 21:33 ---------- Previous post was at 21:02 ----------
acelasi clip pus pe hdd intern...merge fara nici o problema...deci mai e de lucru la enigma
Eu nu cred ca e din Enigma ...mai degraba parametri mincinosi despre procesor nu e ceea ce scrie in specificatii ...4k de pe youtoube nu se compara cu 4k satelit la procesare.!!! Eu am Amiko A5,4k ,si Dm 920,pe Amiko A5 unele programe le deschide f.greu iar pe dm 920 merg instantaneu.
eeeeeee
am specificat mai sus...acelasi clip pe hddd..merge....si merg de 2 ani….pe youtube acum am descoperit EU...
plus ca alte imagini nici nu vor sa implementeze 4l altfel decat e specificat in datele tehnice…
sant destule comenzi si chestii care citesc parametrii reali a uni receptor
apropos ma simt jignit comparand amiko 5 cu mutant :)
---------- Post added at 22:39 ---------- Previous post was at 22:33 ----------
te invit pe 920 al tau...acest ferari al enigma...sa pui pure si sa incerci....
sa fie oare tot parametrii mincinosi? :)
e pur si simplu prob de enigma...youtube plugin..dar ma indoiesc....iar pe pli se vb de multa vreme asta
Sincer pt mine YT-ul pe receptor/E2 e nesemnificativ ca folosinta , fiindca aproape toate tv-urile 4K cu android sau fara il au ca aplicatie implicita
Sincer mi-se pare peste mana sa comut tv-ul pe intrarea receptorului ca apoi sa deschid/vizualizez cu YT-ul nu stiu ce.....cand pot foarte bine sa deschid YT-ul de pe tv si sa fac acelas lucru
naaa..pai eu ce sa zic acuma.....deci sa inteleg ca ai aruncat banii degeaba pe ferari...daca iti este greu sa comuti tv pe receptor....deci sa inteleg ca nici enigma nu ruleaza....stai mai mult pe tv...
vad ca si testele mai mult cu pc le faci pe satelit...deci bani aruncati...:) si destui..:)
Laleaua , nu confunda folosirea unei aplicatii ( YT ) pe un receptor 4k din cand in cand ( stiu sigur ca nu stai 24/24 si 7/7 pe YT , ci cand si cand ) si care exista implicit pe aproape orice tv 4K din prezent
Cu folosirea a 2 x cam-uri CI+ , tu poti sa folosesti 2 cam-uri CI+ pe mutantul tau ......sigur NU
Eu fiind ab la portocala si rcs pot oricand sa vizualizez orice prg tv doresc de la acesti doi operatori
De acea am cumparat un Ferrari si nu 3 Loganuri , stiu ca o sa incepi cu vechiul tau disc - Ca Loganul tau face ce face si Ferrari-ul meu , dar in situatia descrisa mai sus , sigur NU POATE
---------- Post added at 16:28 ---------- Previous post was at 16:17 ----------
Legat de testele pe pc , am vrut sa vad ce poate partea grafica integrata a unui i7-7700 in domeniul 4K
Am pl de baza mini-itx cu iesire video HDMI2.0 si mi-am facut un HTPC si avand si cele doua tv tunere instalate , am zis ca de ce sa nu testez ce poate i7-7700 , fara vreo pl video dedicata
Ca il folosesc mai mult HTPC-ul decat Ferrari-ul asta e alta poveste
Chiar nu a testat nimeni Neutrino pe Mutant HD51?
Detalii in curand.
nu am incercat :)
cu comanda :
aflii versiunea de bootloaderCode:cat /sys/firmware/devicetree/base/bolt/tag
de [Only registered and activated users can see links. Click Here To Register...] iei versiunea multipart sau unica.
am sa o pun in multiboot...dar trebuie sa schimb si imaginea ca am pli si nu suporta multi...dar acum sant de noapte si nu prea am spor :) vad ca e destul de misto imaginea..sa emancipat enorm
tu umbli prea mult cu neutrino si putty....loader se afla si la informatii...despre...frontprocessor version..si daca nu ma insel toate din gama HD51 zgemma au acelasi bootloader 1.07 r19
Confirm cele spuse de Dr. Black Tulip despre bootloader.
Nu trebuie sa tragi prea tare de el. Multi tin open pli pe el si se multumesc cu atat. Eu unul folosesc openatv la zi, nu am nevoie de mai mult.
E stabiol , e rapid, stie ci+ stie s2x(multistream) are stalker plugin si plex e compatibil, afn merge, restul sunt vechi de cand lumea.
Un produs reusit, pret super ok. Recomand.
---------- Post added at 11:15 ---------- Previous post was at 11:07 ----------
i7700 (K) au integrat intel 620 deci nu ca nu au , ci chiar au integrat deci asta e "placa video dedicata" dupa cum ii spui tu.Quote:
Nu de mult au implementat quicksynk compatibil cu kaby lake ( din care face parte si procesorul tau) si apolo lake.
Asa ca te poti juca si cu vaapi/qsv folosind capacitatile sale. Quick synk e mult mai stabil si lucraza cu un alt set de instructiuni catre procesorul video. Dca folosesti partial mode pentru transcoding pr qsv cred ca poti avea cam 4 daca mergi pe full hardware accel posibil da ai 1 sau 2 bune.
