Im downlod this is file. Not problem.(win7)
Only need password!
Only need password!
you will remain without data to a vicious virus !!
Now to delete it is very dangerous !
I have a password But inside is a virus...
Enigma2 OpenSource SH4 Duckbox Project GIT-2301 PKT SVN-977 HAARP Image
Image is designed for installation in flash
Support receiver: Golden Media 990 CR HD
Added by PKT:
- add new WebInterface v 1.6.7
- new function "live ecm" in infobar
- update e2 to 2011-05-09-experimental
- 10% faster switching channels
- fix run mgcamd
- Install Manager v1.0.3: fix exit from Disk Manager
- show Channel Number on Front Pannel + ON/OFF in setup menu
- upgrade CrossEPG svn 268
- fix qwerty VirtualKeyboard
- fix Backup/Autorestore function | LABEL=RECOVERY required
- fix channel number showing on VFD if long channel name
- set home directory to /root
- EPG description on channel list -> ON
- change reading of ecm.info
- new converters and skins modifications
- fix dimmer action when channel switch
- fix parsing PROV, CAID, PID
- Enable autofs support
- moving EPG support to KeyMapper
- ReferencePKT optimization
- set PKTGoldHD as default skin
- fix CIFS mount if passwd is empty
- add clock in standby mode
new plugins available from PKT feed :
- AutoTimer_1.0
- B00K_0.9
- Client-Torrent_1.0
- CoolTVGuide_3.10
- DrWatson_1.0
- DynDNS_1.0
- EPGSearch_0.9
- Merlin_PG_2.86
- Permanent_1.0
- PlanerFS_3.05
- ProjectValerie_0.9.0_svn809
- SportPortal_1.4
Known issue:
- cardreader not work yet but we working on it
- DVB-T USB adapter don't work yet
FTP login: user:root, passwd: pkteam
Tnks !
testat noua imagine pkt ... primele impresii
cele bune:
1. imaginea arata bine , bine structurata si cu skinuri destul de frumoase
2. are cam tot ce trebuie in domeniul pluginurilor utile
3. nu are emulatoare preinstalate dar se pot instala usor
4. server download ( emu , pluginuri , etc )
cele rele :
1. isi da reboot cam din orice ( dupa ce face reboot la accesarea unei functii dupa reboot nu mai face reboot la reaccesarea acelei functii ) ... avantajul ca boot dureaza putin in comparatie cu AR-P unde ai impresia ca s-a blocat la incarcarea modulelor
2. nu au rezolvat problema 1080i
merita testata
back to RSP Enigma ... simpla dar extrem de rapida si eficienta
PS. testul de mai sus s-a facut pe un aparat Amiko Alien si este posibil ca pe Golden Media 990 CR HD pentru care a fost lansata aceasta imagine sa se miste foarte bine
IMG do not work Amiko Alien reboot every 6 minutes
Thus says the team PKT
This Image is working fine only for GM990
Other tuners is a lottery
oh no EOS syndrome !!
"Hmm gerade mit meinen GM990 und meinen Pingulux mal angetestet und bei beiden
hab ich jeweils nach ca.4-6 min einen Automatischen reboot ohne Fehler oder GS.
Ist auch kein Zusammenhang wo ich im Menu bin oder was ich gerade mache.
GM Reboots:
1. im Addonmenu vom PKTPanel
2. beim TV schauen
Pingulux Reboot:
1. Systeminformationen im PKTPanel
2. Einstellungmenu ohne was einzustellen
3. EPG"
Citat de pe HD Freaks Forum
Daca pricep eu bine ... acest mesaj ne spune ca omul nostru a testat atat pe Edision Pingulux
cat si pe GM990 si ... fenomenul apare pe ambele fara vreo legatura cu actiunile curente.
Este in mod evident o eroare a celor de la PKT pe care cred ca o vor corecta curand !
Din pacate nu am timp acuma sa testz dar cum fac teste o sa va spun cum merge pe pingulux la mine
Acolo a inceput acum o echipa PKT şi EOS.
Acum, ei incuiate E2 lor.
Nu lucra la ALIEN!
Deci, numai bani, nu mai distractiv.
Şi atunci cand ei spun că o fac pentru a te distra ... mint.
Am facut ieri un test complet pe Imaginea PKT_HAARP ! nu pe Alien ci pe Kathrein UFS912
( receptor echipat cu aceaasi placa de baza ) ... imaginea este praxtic aceeasi dar cu o
alta alocare a memoriei Flash ! Imaginea de pe ufs912 merge perfect ! si dupa cum chiar
PKT declara este ufs912 - gm990 !!! deci fara dubii ...imaginea pentru gm990 este "protejata"
spre a a nu lucra pe altceva decat gm990 ! mi se pare o prostie dar probabil ca isi are
explicatia in faptul ca fiecare constructor de imagine ( RSP, EOS si PKT) isi tine cate un
"as" in maneca ... vezi doamne sa nu faca altii bani de pe urma lor ! o lume deschisa ...
perfect inchisa ! mi se face un pic greata !
Eu inteleg asa ... cine vrea sa faca bani ...sa-ai asume responsbilitati, sa scrie softul de baza ...
drivere si module sistem , sa echipeze nativ un receptor cu Enigma2 , asumindu-si performante
obiective si termene ...si atunci isi poate proteja munca ! chiar trebuie s-o faca ! Daca tot sistemul
este pus la punct de altii ( asa cum se intampla pe GIT ) asumarea meritelor si "protejarea" lor
mi se pare o magarie ! constructia unei imagini este 10% din munca ! deci 10% din merite !
restul ...gandirea si transpiratia unor anonimi ... fie ei si celebrii TDT.
Deci, este incă blocată că E2 lor, in timp ce insistă asupra faptului că prima versiune nije.Jer a avut nici o problemă de lucru pe Alien, in timp ce trist, acest lucru nu funcţionează.
Acest lucru nu este bun, eu nu inţeleg de ce o fac??
Este de bani, şi eu sunt convins că, pentru că nimic altceva nu poate fi.
Totul se invarte in jurul banilor, asa ca a facut echipa EOS, aşa au făcut, şi iată că aceste produse de la PKT, EOS este langă COMANDA?
Toţi susţin că acesta este hobby-ul lor, acum se dovedeşte altfel.
Money is their hobby and EOS and PKT "money money and only money"
Im sale amiko alien.
Amiko alien enigma2 dead project!
Don't ! just keep the faith ... on my oppinion AR-P Image is a promissing one ...
they are opened ... still enthousiast ... they are deserving our trust !
fiecare importator trage pentru el si de aici imagini care merg doar pe anumite variante ale receptorului fulan ... din pacate importatorul alien a ales sa astepte pomana si ceilalti le-a blocat accesul la munca lor , personal nu mai am incredere in marca amiko deoarece promit muuuuult dar nu fac nici 10% ( asta cu ingaduinta ) din ce promit . singura speranta a lor este sa lucreze rusii la enigma2 dar si sa nu blocheze si ei accesul la imaginea lor .
RUSINE AMIKO !!!!!
