Re: E2 RSP 3.17b TDT 1142
The E2 RSP 3.17b TDT 1142 image is most stable E2 for Kathrein. It is really great work.
The only thing I miss is SUBTITLES. They are on menu but they behave very strange (at least in case of BSkyB channels- like "BBC News" on 28.2E, "BBC World News" have no subs at all).
-DVB subtitles are shown one word at the time, all the rest disappear immediately.
-TXT subtitles have the opposite problem, old lines do not disappear when the new ones come, so in two minutes all the screen is covered with unreadable greenish text.
So far I did not find any setting that could help with this problem.
I hear the new version is coming soon. It would be nice to see it fixed.
Best regards and my respect
salut,
am versiunea asta pe stick si merge foarte bine.
am pus o interfata violet phoenix cu un card tvr si asta-i mesajul ce-l primesc :
This is NewCS 1.65 - the New CardServer by the Butter-team..
Compiled on Jan 19 2009 at 17:58:37
Reading Config file from /var/keys/newcs.xml
TCP-log password is enabled, set to: NewCSpwd
TCP-log set to simple mode
level: none
type: init
output: console,tcp
logger config: level 1 type 3 output 5
Console log options: level 1 type 3
TCP log options: level 1 type 3
[ 20:00:00 ] [ Box detect ] Box type 9 (Kathrein (ST) HD Box)
[ 20:00:00 ] [ Config ] Option <blockc0> for device 0 (Phoenix Interface) not present, defaulting to NO
[ 20:00:00 ] [ Config ] Value in <ipk> for device 0 (Phoenix Interface) is INVALID, skipping...
[ 20:00:00 ] [ Config ] Value in <ucpk> for device 0 (Phoenix Interface) is INVALID, skipping...
[ 20:00:00 ] [ Config ] Pincode for device 0 (Phoenix Interface): 0000
[ 20:00:00 ] [ Config ] /dev/ttyUSB0 ECM priority: round
[ 20:00:00 ] [ EMM Cache ] Initialising dynamic Cache
[ 20:00:00 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 549
[ 20:00:00 ] [ Loader ] Starting Telnet on port 1001
[ 20:00:00 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 20:00:00 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 20:00:00 ] [ Phoenix ] Setting Parity to: EVEN
[ 20:00:00 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 20:00:00 ] [ Phoenix ] Setting Baud to standard 9600
/tmp/camd.socket: No such file or directory
Aborted
[ 20:00:01 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
camd3.902 stopped
[ 20:00:03 ] [ ATR ] T=0 1etu=8.41us Guardtime:12etu WWT:115200etu
[ 20:00:03 ] [ ATR ] Historical bytes: [C2] [14] [00] [C1] h [90] [00]
[ 20:00:03 ] [ Loader ] Init Viaccess card
[ 20:00:03 ] [ Phoenix ] Setting Parity to: ODD
[ 20:00:03 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 20:00:03 ] [ Phoenix ] Setting Baud to standard 9600
[ 20:00:03 ] [ Loader ] Card 0500 on port /dev/ttyUSB0 failed
[ 20:00:03 ] [ Loader ] Starting Newcamd Server on port 12001
[ 20:00:03 ] [ Newcamd ] Newcamd thread Server started on port 12001
newcamd: main loop
[ 20:00:03 ] [ NewCS ] Ready to GO! :)
De ce oare nu se incarca cardul?
Incearca
parity even la Seca, Conax, Cryptworks si odd la NDS, Via
si reset inverse sau normal.
Va merge
ai avut dreptate a mers, nu mai da failed, dar totusi nu se deschide.trebuie sa las mai mult pana-si face update cartela. acum am urmatorul mesaj:
level: high
type: all
output: console,tcp
logger config: level 1 type 255 output 5
Console log options: level 1 type 255
TCP log options: level 1 type 255
[ 22:46:14 ] [ Box detect ] Box type 9 (Kathrein (ST) HD Box)
[ 22:46:14 ] [ Config ] Option <blockc0> for device 0 (Phoenix Interface) not present, defaulting to NO
[ 22:46:14 ] [ Config ] Value in <ipk> for device 0 (Phoenix Interface) is INVALID, skipping...
[ 22:46:14 ] [ Config ] Value in <ucpk> for device 0 (Phoenix Interface) is INVALID, skipping...
[ 22:46:14 ] [ Config ] Pincode for device 0 (Phoenix Interface): 0000
[ 22:46:14 ] [ Config ] /dev/ttyUSB0 ECM priority: round
[ 22:46:15 ] [ Newcamd ] Server name : newcs
[ 22:46:15 ] [ Newcamd ] Des key : 0102030405060708091011121314
[ 22:46:15 ] [ Newcamd ] User 2: kathy, Pass: kathy, Host localhost, Port: 12000, Au: On, Spider allowed: No, Sidoverride: No, level: 0
[ 22:46:15 ] [ EMM Cache ] Initialising dynamic Cache
[ 22:46:15 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 9640
[ 22:46:15 ] [ Loader ] Starting Telnet on port 1001
[ 22:46:15 ] [ Loader ] Reader type 2 on node /dev/ttyUSB0
[ 22:46:15 ] [ Phoenix ] Opening device /dev/ttyUSB0
[ 22:46:15 ] [ Phoenix ] Setting Parity to: ODD
[ 22:46:15 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 22:46:15 ] [ Phoenix ] Setting Baud to standard 9600
[ 22:46:15 ] [ Phoenix ] Normal RESET on node /dev/ttyUSB0
[ 22:46:17 ] [ ATR ] T=0 1etu=8.41us Guardtime:12etu WWT:115200etu
[ 22:46:17 ] [ ATR ] Historical bytes: [C2] [14] [00] [C1] h [90] [00]
[ 22:46:17 ] [ Loader ] Init Viaccess card
[ 22:46:17 ] [ Phoenix ] Setting Parity to: ODD
[ 22:46:17 ] [ Phoenix ] Setting 2 Stop bits on node /dev/ttyUSB0
[ 22:46:17 ] [ Phoenix ] Setting Baud to standard 9600
[ 22:46:17 ] [ KeymaN ] Adding key 000000bf645995 type 0 on Provider 000000 for caid 0500 ID=0
[ 22:46:17 ] [ KeymaN ] Adding key 000000bf645995 type 1 on Provider FFF720 for caid 0500 ID=0
[ 22:46:18 ] [ KeymaN ] Adding key 000000bf645995 type 1 on Provider 025900 for caid 0500 ID=1
[ 22:46:18 ] [ KeymaN ] Adding key 000000bf645995 type 1 on Provider 025910 for caid 0500 ID=2
[ 22:46:18 ] [ Loader ] Card 0500 on port /dev/ttyUSB0 ready
[ 22:46:18 ] [ Loader ] Starting Newcamd Server on port 12001
[ 22:46:18 ] [ Newcamd ] Newcamd thread Server started on port 12001
[ 22:46:18 ] [ NewCS ] Ready to GO! :)
Kathy_RSP:~# newcamd: main loop
[ 22:46:18 ] [ Newcamd ] recv: error! 111: Connection refused
[ 22:46:18 ] [ Newcamd:12001 ] User kathy logout
Mgcamd 1.33 face update instantaneu la orice card.
A fost un mare castig acest emulator pentru EMM la Sh40 e2.
ok, pun mgcamd
are nevoie de ceva setari? trebuie sa ruleze cu newcs sau poate si singur?
am pus. acum am urmatorul mesaj:
[ 00:17:41 ] [ Loader ] Card 0500 on port /dev/ttyUSB0 ready
[ 00:17:41 ] [ Loader ] Starting Newcamd Server on port 12001
[ 00:17:41 ] [ Newcamd ] Newcamd thread Server started on port 12001
newcamd: main loop
[ 00:17:41 ] [ NewCS ] Ready to GO! :)
Kathy_RSP:~# [ 00:17:41 ] [ Newcamd:12001 ] Connection from 127.0.0.1
des_decrypt: bad len ?
[ 00:17:41 ] [ Newcamd:12001 ] Can't decrypt client msg, rejecting!
[ 00:17:41 ] [ Newcamd:12001 ] User kathy logout
iar la mgcam:
tuxbox mgcamd v1.33 by mixvt (compiled May 31 2009 19:41:08)
[mg] Net:1:7:0:2s Show ecm:1, emm:0 Up:1 Au:2 Dir:0 Osd:enigma:8080:3 Cache:7 Log
:2:127.0.0.1:28007 Reread:0
[mg] Ecm cache time: 15
Box type: dbox2
Conax.Key error 2: No such file or directory
Keys readed
Kathy_RSP:~# Conax.Key error 2: No such file or directory
newcamd keep alive: 0, incoming port: 0
[mgcam] emm thread started
[mgcamd] tps update started.
/var/keys/tps.bin error 2: No such file or directory
got 80 cmd 9F
[mg0] namespace A0ACCF t-id 65 on-id 1
[mg0] descramble on 1, source 0
CA_SET_PID error 22: Invalid argument
[mg0] service 1 index 0 pmt pid 1389 (1), pids: video 0x01FE, audio 0x01F4 0x020
6
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x0032 ProvID: 000000
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x0033 ProvID: 000000
[mg0] ECM: CaID: 0x0500 -> CaPID: 0x0034 ProvID: 000000
[mg0] No viaccess key(s) found for id 22F00 keynr 08
[mg0] network can't decode
gata am reusit
trebuia sa umblu si prin newcamd.list sa adaug setarile facute in newcs.
