The Forlinx FET3562J-C is a Rockchip RK3562/RK3562J powered System-on-Module (SoM) built with a 22nm process...
Today, we will review another new sensor from SONOFF, the SNZN-05P Zigbee water leak sensor....
Meenhong JX5 is another Intel N100 mini PC with an integrated touchscreen display, but the...
SunFounder PiPower 3 kit is a UPS solution designed to work with the Raspberry Pi...
N-Fuse has designed a PoE HAT for the Raspberry Pi 5 SBC that also serves...
NORVI Controllers’ AI Optic – also written as AIOptic – is an ESP32-S3 camera solution...
GL.iNet GL-B3000 “Marble” is a typical WiFi 6 AX6000 router that ships with a photo...
MSI MS-C918 industrial palm-sized pocket PC is powered by an Intel Processor N100 CPU with...
Orange Pi CM5 is a system-on-module mostly compatible with the Raspberry Pi CM4 (and upcoming...
PCBWay, one of the most popular PCB manufacturers around the world, is now almost 10...
NXP has recently launched the SAF9xxx Automotive Audio DSP family, which currently includes SAF9000 and...
Sipeed NanoKVM is a tiny KVM over IP solution based on the Lichee RVNano RISC-V...
GEEKOM is offering a $60 discount coupon code as part of a Prime Day promotion...
Renesas SLG7EVBFORGE FPGA dev board, built around SLG47910V is Renesas’ first low-density FPGA in the...
In part one of the Cincoze DS-1402 review, I checked out the hardware of the...
The SkyByte Mini is a simple, miniature drone powered by the ESP32-WROOM-32 WiFi and Bluetooth...
GEEKOM GT13 Pro is a Windows 11 mini PC powered by a 13th Gen Intel...
The Zeal 8-bit Computer Complete Edition is a system that aims to bring retrocomputing to...
High Torque Robotics’ Mini π is a 54cm high bipedal robot that can walk and...
LILYGO T3S3 E-Paper is an ESP32-S3 WiFi and Bluetooth LE development board with a 2.13-inch...
