translator englez-roman
> Covers Complete 42 themes released so far including 6 vista themes
> Multiple Archievers support i,e, UHARC, CabPack, MsCab, ExePackers
> Includes 7-zip SFX-Splitter and WinRAR 3.51 StandAlone Archiever
> 3 Powerful Resource Editors i,e, Resource Hacker, ResEdit, MsResEditor
> Additional tools i,e, RegSeeker, RecoverEXE, Unstoppable Copier etc.
> Create full blown customized Corporate Edition or Gold Edition of WinRAR with Powerful WinRAR 3.51 StandAlone Archiever
INCLUDE
-- 7-zip Splitter
-- CabPack 1.4
-- DirLister
-- ExeInfoPE
-- FreeExtractor
-- GUI4UPX 3.01
-- IExpress 2.0
-- ********* ResEditor
-- Process Viewer
-- RecoverEXE
-- RegSeeker
-- Resource Edit
-- Resource Hacker
-- Setup Packager 3
-- System Information
-- Trial Reset 3.0
-- UHARC 4.0
-- UHARC 6.0a
-- UHARC 6.0b
-- UnstoppableCopier
-- WinRAR
-- WinRAR 3.51
-- 48 Extra theme
-- And more . . .
ptr decriptarea HD DVD si BLUERAY
[Only registered and activated users can see links. Click Here To Register...]LimeWire - The Fastest P2P File Sharing Program on the Planet, running on the Gnutella Network. It is open standard software running on an open protocol, free for the public to use. LimeWire allows you to share any file such as.mp3s, .avis, jpgs, tiffs, etc., allows you to search for multiple files at the same time, available in several different languages, and is most famous for its ease-of-use and cross-platform compatibility. Limewire is written in Java, and will run on Windows, Macintosh, Linux, Solaris, and other computing platforms.
Backup4all is an award-winning, powerful data backup software for Windows. It protects your valuable data from partial or total loss by automating tasks, password protecting and compressing it to save storage space. Using Backup4all you can easily back up to any local or network drive, backup to FTP, backup to DVD, or other removable media (such as USB drives). Backup4all is the perfect backup solution for desktop and laptop computers, for your business or personal use.
homepage
DVDSanta is an All-in-One software that lets you copy, create, convert and burn your DVD movies. It can copy 9GB double layer DVD movies into a 4.7GB DVD-R disc, can turn your photos into DVD movies with Hollywood style motion effects, can convert other video formats(avi,wmv,vob,asf…[Only registered and activated users can see links. Click Here To Register...] into DVD video, can transfer miniDV camcorder tapes directly to DVD video. dvdSanta is extremely easy to use, fast and powerful.
- Easy to use interface: Intuitive user interface that requires no technical knowledge whatsoever.
- Converts and burns video files directly into DVD movies so that you can watch them on TV.
- Can mix multiple video files into one DVD disc.
- Converts photo files into DVD movies, with 35 transition effects, pan and zoom motions, background musics and narrations.
- Can automatically sync the background music with photo slide shows.
- Real-time captures and transforms miniDV camcorder tapes directly to DVD video format
- Can fit 9GB double layer DVD movies into 4.7GB single layer DVD disc.
- Burns DVD ISO Image or DVD VIDEO_TS folders to DVD
- Auto-Rate-Controller technology maximizes disc space by squeezing the highest quality video onto a disc.
- Supports major video formats such as AVI, WMV, ASF, MPG, VOB…
- Supports major photo formats such as JPG, PNG, BMP…
- Supports major audio formats such as WAV, MP3, WMA…
- Supports DVD+R/RW, DVD-R/RW format discs and burners.
- Supports 4:3 and 16:9 video aspect ratio
- Supports both NTSC and PAL video standard
- Supports Interlaced and Progressive Sources
- Supports output to hard drive
- Intergrated High Speed DVD MPEG-2 Encoder
DAEMON Tools Pro Advanced is CD & DVD emulation software which allows usersto make CD/DVD disc images, create a virtual CD / DVD drives and play CDs &DVDs without the need for the physical disc and supports virtual IDE adapters. What are the differences between (DAEMON Tools Pro - Advanced) with other versions of DAEMON Tools Lite,DAEMON Tools Pro Basic and Pro Standard?
Note:
1. vIDE is currently supported on all 32 bit platforms (x86) and on Windows
Vista x64; Windows XP x64 and Windows 2003 x64 are not supported;
2. Shell extensions do not appear on x64 platforms;
System requirements:
Windows 2000 SP4, Windows XP x86/x64, Windows 2003 x86/x64, Windows Vista x86/x64
ptr cei interesati
Software Description:
Many CAD programs are designed for architects and engineers. These
can be expensive, as well as hard to learn, and difficult to use.
Home Plan Pro is designed to quickly and easily draw good-quality,
straightforward designs.
--Integrated on-line help
--Multiple drawing layers
--Built-in fax driver faxes your plans anywhere in the world
--Metric or USA Measurements
--Dozens of Fill Patterns
--Draw with Mouse and Keyboard
--Hundreds of Resizeable, Rotatable Figures
--Print on any paper your Windows printer driver supports
--Choose drawing colors, line styles, fill patterns, etc.
--Draw objects from a few inches to thousands of feet in size
--Resolutions down to 1/16 of an Inch when zoomed in
--Save Drawing in bitmap or vector format
--Optional, Adjustable Snap Grid
--keep an Activity Log to track your time on each plan
--Fill any Wall with framing, patterns or solid colors
--Calculate Square Feet or Meters
--Clip and Save Sections for Use in Other Drawings
--Delete Drawing Objects or User-defined Sections
--Measure Cursor Movement with On-screen "Odometers"
--Multiple Line Styles
--Multiple Text Sizes
--Repeat or Clone the Last Action
--Resize All or Part of Drawings
--Undo/Redo the Last Action
--View & Delete Individual Elements from Drawing
--Zoom In or Out
Auto Power-on & Shut-down is able to allow users to do this all of the following: Control your computer resume from power-off state
- Wake up your computer from sleep mode (standby)
- Run programs, close programs, open files and open URL at any specified time
- Play mp3, wma , wav and flash at any specified time
- Logs on system automatically (win2000/nt/xp/vista)
- Shutdown or reboot , make computer enter sleep mode (standby/hibernate) at any time
- Synchronize your PC's time to atomic clock servers
- New: Added "Create Logfile" menu, removed "enable logging" from settings
- New: Autoplay is no longer triggered, if settings are changed or AnyDVD is disabled / enabled.
Note: This feature might not work correctly with X-Protect or other heavily corrupted discs. This feature is currently only supported for 32-bit applications.
- New (DVD): Added hooking of the IDvdInfo2::GetDiscID interface. All 32-bit applications which use DiscIDs will retrieve the correct DiscID, even if AnyDVD is running (e.g., Windows MCE 2005, Windows Media Player, Invelos DVD Profiler, MyMovies, etc.)
- New (DVD): AI Scanner has now different settings, "Disabled", Automatic" or "Enabled"
- New (DVD): Added support for new protection, e.g., "Saw IV", R1, US
- New (DVD): Added support for new protection, e.g., "Mr. Woodcock", R1, US
- New (DVD): Added support for new copy protection, e.g. "Paheli", R2, Germany
- New (DVD): Added support for new copy protection, e.g. "Whisper", R2, Germany
- New (DVD): Added support for new copy protection found on some adult titles to the AnyDVD ripper
- New (DVD): Improved performance of the AI scanner.
- Fix (DVD): Problems with "Shoot 'Em Up", R1, US
- Fix (DVD): AnyDVD ripper removed parts of the Audio Test of "Ratatouille", R1, US.
- Fix (DVD): AI Scanner missed one chapter of the full frame version on "Fun with Dick and Jane (2005)", R1, US
- Fix (DVD): IFOTitles 2 error with some Macrovision RipGuard protected titles, e.g. "Funny Factory with Mickey - Volume 1", R1, US
- Some minor fixes and improvements
- Updated languages
[Only registered and activated users can see links. Click Here To Register...]&
new
- Added support for a new copy protection as found on "SAW IV", (US).
- Improved support for CORE X2 protection as found on some Czech DVDs.
- Improved PathPlayer performance in certain cases.
- Updated language files.
fixed
Failed to get DVD Information" when opening DVD in certain cases.
- When choosing "Jump to first menu when disc inserted", backup jumps to "Parental Control menu" in certain cases.
- Error 400(20 9) when copying DVD in certain cases.
- Several minor problems.
Pentru ce-i ce vor sa-si mai curete pc-ul, acest program poate sa ajute ....mai ales atunci cand windows-ul e instalat mai demult si s-au strans o gramada de balarii in el.Quote:
Eu l-am folosit de multe ori(mai ales pe sisteme care au peste un an de la instalare) si nu face prostioare cu windows-ul .
Ciao Ragazzi
Asta chiar e tare :lol: Toti fug de ea si tu o pui pe forum :D E binevenita oricum :dance:Quote:
Originally Posted by Turku [Only registered and activated users can see links. Click Here To Register...]
La ce foloseste asta???Quote:
La mine nu face nimic ...
Ciao Ragazzi
Ciao RagazziQuote:
Originally Posted by XVanish [Only registered and activated users can see links. Click Here To Register...]
Ciao Ragazzi
Portable Express Burn 4.05
Burn CDs or DVDs with Express Burn Plus Express Burn Plus is a program for Windows
that lets you create and record audio CDs, data CDs or data DVDs with any Windows
PC with an installed CD or DVD recorder.
With Express Burn Plus you can record an audio CD, data CD or data DVD quickly and
easily by dragging the files you want onto the Express Burn Plus icon and clicking
Burn. You can also use Express Burns easy to use interface to navigate to your files
and add files or folders as you please. The software does the rest, including
converting the files if required.
Express Burn Plus includes many advanced features such as the ability to burn Data
DVDs (supports DVD-R, DVD-RW, DVD+R, DVD+RW), the ability to create and record ISO
images and, for audio CD and DVD, support for many more file formats (the basic
version only supports wav and mp3). It is the fastest CD/DVD writing program in
the world using proprietary optimizing systems.
The CrossDresser is a one-click clothing conversion utility
for Poser and Daz Studio. This process is completely automatic,
and when complete, the converted clothing is placed directly
in your Poser runtime libraries, ready to use. Most clothing
will convert nearly perfectly. The CrossDresser also provides
easy-to-use features to fix any minor poke-through that may occur.
CrossDresser v2.4
Supported Figures
Below is a list of the figures that are currently supported.
Please check back occasionally, new figures are added all the time.
Currently Available
AFDiana
Aiko 3
Alexa 2
Anime/Maya Doll
Apollo Maximus
Ball Joint Doll
David 3
F202 Dollie
G2 Jessi
G2 Males(G2 James, G2 Kelvin, G2 Koji)
Gumdrops
Hiro 3
Ichiro
Ichiro 2
Kiki
Kit
Koshini
Koshini 2
Krystal
Kyle 1.5
Laura 3
Luke 3
Maddie 3
Matt 3
Michael 1 (identical to Michael 2)
Michael 2
Michael 3
Miki 1
Miki 2
Millennium Baby 3
Near_Me
P4 Boy
P4 Female
P4 Girl
P4 Infant
P4 Male
P5 Don
P5 Judy
P5 Penny
P5 Will
P6 Ben
P6 James
P6 Jessi
P6 Kate
PaperDoll Female
PaperDoll Male
Preschool Boy
Preschool Girl
Preteen Boy
Preteen Girl
Stephanie Petite 3
Sydney(same body as G2 Jessi)
Terai Yuki 2
The Freak
The Girl
Ugly Boy
Victoria 1 (identical to Victoria 2)
Victoria 2
Victoria 3
Victoria 4
Wapi Pu
