Cine ma cunoaste, stie ca m-am ocupat ceva timp cu downloadul offline.M-am lasat cauza principala fiind lipsa unei desktop acum folosest doar leptop...
Doresc sa ajut pe cei interesati evident de d.o. si in aceeasi timp sa ii si rog sa testeze amanuntit descarcarile de pe 7E.
Spun 7E deoarece acolo isi fac veacul mai multe grupuri care urca in mod constant materiale multimedia si software.
Transmisiile se fac atit DVB-S cat si DVB-S2:D
Pt DVB-S avem:
Grupul Mac5 MB
Sat: Eutelsat w3
Fer: 11354
fec:8571
Pol : V
Time : 00:00 ~ 08:00
MAC : 00:0b:a4:03:c1:c7
pid : 4507
Grupul Talar1
EutelSat W3
Mac : 06:06:06:06:06
Frec: 10928
Pol:vertical
S/r:27500
7:30-11:30
Grupul: Lineoffline
EutelSat W3
Mac : 1122334455
Freq: 10928
Pol:vertical
S.r:27500
6-00
Grupul: Takoffline
Sat:Eutelsat W3
Frequency:11351
Symbolrate:8571
Polarization:vertical
MAC:00:0b:a4:03:c1:c7
PID:4507
Pt DVB-S2 avem:
Grupul SHOPDVB
MAC: d0b5b80003
SATELITE:W3
FREQ:10762
SYMBOL RATE: 29500
POLARYZATION: HOR
PiD:1450
TIME: 24 -- 8
Grupul: Warez-DVB
Satellite: W3A
Freq:10762
Pol: H
Sym: 29500
Mac: D0B5B401C9
Pid: 1450
6-24
System.ini recomandat:
________________________________________________________________________________
___________
ip_defrag_buf_size=0K
c_stat_bg=0x101010
c_stat_text=0xffffff
c_cat_text1=0xFFFFFF
c_cat_text2=0xFFFCB4
c_cat_cursor1=0x000000
c_cat_cursor2=0x777777
c_bg = 0x000000
fl_sm=0
hevent_begin_min_size=50M
timeout_havent_begin=3600
show_eXtendet_stat=0
show_signal_info=0
ip_timeout=3000
gl_max_blocks_wait=256
gl_session_timeout=3600000
gl_channel_timeout=300000
tuner_kick_timeout=2000
use_header_bg_bitmap=0
hserver_port=81
reload_htmpl=1
tray=1
#inet_mac_str0=00d000000000
#inet_mac_str1=00d000000001
#out_mpe=stream.mpe
#inet_mac_str0=*
rename_ok_files_if_real_name_known=1
stat_speed_mult=120
signal_quality_log_height=25
#stat_speed_window_width=200
#stat_speed60_window_width=800
#stat_speed_normalyzer=10M
#stat_speed60_normalyzer=10M
user_info_str= @POwered by Doktor of Sat
#use_ts_client=0
#use_ts_server=0
#ts_server_addr=192.168.1.1
#ts_server_port=453
#process_data_when_ts_server_use=1
#log_append=1
#ignore_tcp_cs=0
#min_file_size_for_real_name_store=10M
#ts_cache_len=32M
rar_str_timeout=172800
name_str_timeout=172800
#in=e:\tmp
ftp=1
http=1
nntp=0
use_tcp = 1
use_udp = 1
use_gre = 1
#use_ethernet_drv=1
exit_promt=1
#inet_mac_str0=************
#use_openvpn_tun=1
#tun_ip=192.168.1.1
#inet_mac_str1=00D000000000
tcp_log=0
use_file_log=0
logdir=s:\test\skynet\log
zoom=200mb
autosave_time=600000
discon_to_log=0
no_crc32=0
#no_scan=1
#regex.txt=regex.micro
# window
wx=0
wy=0
ww=750
wh=630
maximize=0
refresh=250
font=Segoe UI
font_size=20
processor=0
xfont=-*-*-*-*-*-*-*-*-*-*-*-*-*-cp1251
# files
timeout_100k = 500
timeout_500k = 1000
timeout_1m = 2000
timeout_5m = 4000
timeout_10m = 8000
timeout_50m = 172800
timeout_100m = 172800
timeout_500m = 172800
p2p_add = 6000
one_percent_timeout=3600
ninety_nine_percent_timeout=3600
timeout_fade_rate=50
timeout_line=0
incomplete_min_size=10M
incomplete_%=97
ftp=1
http=1
nntp=0
# tcp/ip
mss=1500
tcp_timeout=300000
tcp_window=8M
tcp_buffer=32K
tcp_fin_timeout=30000
# disk
name_format=E/*/p_m_s_c__R.E
# P - pid hex
# p - pid dec
# M - mac
# m - lower case mac
# D - destination addr hex
# d - destination addr dec
# S - source addr hex
# s - source addr dec
# C - counter hex
# c - counter dec
# R - real name (if known)
# E - extension
# N - size
# i - incapsulation
incomplete=INC
temp=TMP
ok=OK
cache_max_block=128k
cache_scan=10000
cache_flush=15000
#ss1=1
#ss1_mac_filter=00D0
#dream_ip=127.0.0.1
#dream_port=31339
# tuner
lnb=9750000,10600000,11700000
#diseqc=POSITION_B
#diseqc=HIGH_BAND,HORIZONTAL,POSITION_B,OPTION_B
# LOW_BAND HIGH_BAND
# VERTICAL HORIZONTAL
# POSITION_A POSITION_B
# OPTION_A OPTION_B
# BWBP
tuner=11385000 h 30000000 A *aici treci frecv urmata de 3 zerouri, polaritatea, s/r urmat de 3 zerouri
pids=5170 ** treci pidurile indiferent de ordine evitand folosirea pidului 8192
Astept orice rezultat de la voi evident sustinut si cu poze!
Obs:
Atentie la fisierul system.ini din skynet!
Poti scate de la mai multe macuri date , macurile trebuie sa apara scris in rules.txt iar pidurile aferente lor in system.ini
Atentie !Nu poti scoate deodata de pe 2 frecvente diferite
Pt a evita discontinuitatile nuscoate de la mai mult de 3 macuri si verifica care pid are discontinuitati mai multe si sa-l scoti din schema !
Va doresc fir intins
