New update [official] : [Only registered and activated users can see links. Click Here To Register...] 57.77 MB
Marele update! Imi vine sa zambesc! Ia sa vedem cum explicam imaginea de mai jos...
Astazi 24/05/2012 ora 16PM a aparut noul soft spark _1.2.48 pentru amiko alien
Bun. Dupa cateva zeci de minute de cautari nu i-am dat de cap acelui 'font settings'. Apoi m-am gandit sa apelez la un prieten, si anume, la mihaip (candva era pe acest forum foarte activ) si pur si simplu problema a fost rezolvata. Asa ca daca-mi multumiti mie...de fapt...ii dati lui un multumesc! Se poate schimba 'marimea literelor' ce apar in receptor. Mai nou cu ultimele versiuni literele par tot mai mici. Cum procedam. Luam un stick si punem pe el un fisier *.ttf...apoi intram in : menu- system - font setting, apasam butonul rosu...se incarca si face reboot. La deschiderea receptorului veti avea un alt detaliu la litere!
V-am pus un exemplu de fisier *.ttf
Download: [Only registered and activated users can see links. Click Here To Register...]
---------- Post added at 17:59 ---------- Previous post was at 17:13 ----------
Iata ce contine acest update :
Release Notes for v1.2.48:
New Features:
- Updated 3G Modem Drivers (Huawei E1752, E173, E367, Sierra AirCard 250U)
- Provider List selection for 3G Modems,
- User Font support for the On-Screen Display (*.TTF, *.TTC formats) (Loadable from external USB storages)
- Russian Keyboard Support in Opera Web-Browser
- Easy Keyboard language switching (ALT+Shift) in Opera Web-Browser
Improvements:
- Improved SmartCard handling
- Improved Plug-In API for stability improvements
- Added Transponder informations in the Channel Manager / Favorites Manager menus
- Improved Audio/Video quality on analogue outputs
- Improved RCU response time
- Improved DiSEqC 1.2 / USALS functions (The receiver does not send GoTo-X command after every channel change. Only when changing between satellites)
- Improved EPG & DVB-Subtitle handling
Fixes:
- Conax descrambling problem after 30 minutes of usage
- Fixed the language issue causing YouTube to start in Russian inside Spark Portal
- Fixed an issue which caused the receiver to reset the database to default after software upgrades
Known Issues:
- In case of more than one line in DVB subtitle, the position of the subtitles are too low, which causes certain TV sets to cut off the bottom of the subtitle. (This issue is going to be fixed in the next upcoming release. Thank You for your patience.
---------- Post added at 18:50 ---------- Previous post was at 17:59 ----------
Va mai propun 3 exemple de *.ttf pentru a schimba caracterele din Spark:
Download: [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
are cineva probleme cu sunetul dupa upgrade?
Sunetul nu are nimic tre sa dai din telecomanda lui,dar subtitrarea pe canalele HD nu se vede in totalitate si atunci cand dai restart tre sa il configurezi de la inceput
eu am trecut inapoi la ..45
Subtitrarea...........of,pe cand ceva calumea????
A aparut din senin ceva pe Amiko Alien!!! Astazi am descoperit noutatea...pana acum nu era asa ceva!
Remarca cineva ceva in plus acolo?
---------- Post added at 18:55 ---------- Previous post was at 17:47 ----------
P.S: Un anunt. Stiu ca mereu intrebati ce se mai intampla cu sat suport. Ei bine diseara se redeschide forumul. Intrati cu incredere [Only registered and activated users can see links. Click Here To Register...]
:clap:
Cel mai bun .ttf utillizat pe spark la versiunile anterioare. Caracterele se vad ca si la versiunea 1.2.32! Va atasez acest .ttf mai jos!
Se procedeaza in felul urmator:
1. Se pune fisierul .ttf pe stick si apoi se conecteaza in usb-ul receiverului
2. Te duci la menu - system - basic settings - font settings, dupa care apesi tasta rosie de pe telecomanda si faci update cu fisierul .ttf de pe stick
:tv1:
Se pot extrage fonturi chiar din PC; ex: Win7- Windows\Fonts\... ; sunt foarte multe, unele cu variante de italic, bold, etc. Se poate vizualiza fiecare (cu dublu click), selecta, apoi copia in clipboard şi lipi pe flashdrive (acolo se verifică şi extensia .ttf). De incărcat cum a zis meridian anterior.
PS: unele fonturi nu au diacritice romaneşti, asta se vede la vizualizare unde "ş" de la "roşie" e inlocuit cu un ş de la alt font (nu seamănă cu restul).
RAHAT!!! Atata timp cat nu avem subtitrarea calumea(de la versiunea 1.2.32 in sus),ce naiba mai scoate versiuni noi. Pentru `fonturi`??? Nu multumesc.
@alexzsky :Curat-murdar...parol! Rahat cu apa! Ca in Turcia! Font setting nu era in program! :baby: Dar bobul de orez chinezesc a adus in menu o noua setare! Cum pentru ce? Lliterele nu se mai puteau vedea nici cu telescopul Hubble de pe acolo dupa versiunea 1.2.32! Doamne ce distractiv poate fi cu alien! Puneti mana si invatati 20 de limbi straine si nu mai stati la cersit subtirari colorate....:drinks:
Traiasca Fulan! Oleeeeeeeeeeeeee.....
:cool:
P.S: Ca fapt divers. Back to Spark 1.2.32! Nu uitati ca aveti un receptor dual! Cand simtiti ca va plictisiti va dau un sfat: [Only registered and activated users can see links. Click Here To Register...]! Cand vrei ceva relaxare boot to [Only registered and activated users can see links. Click Here To Register...]! Absolut minunat!
@stargate : Cum nu are Fulan acest sopcast care sa deschida acele adrese in Spark? Deja au aflat sugestia! Tineti-va bine! Vine pluginul sopcast in linux...
Mi-am dat si eu cu parerea :) este binevenit pluginul , din pacate din lipsa de timp nu am mai avut timp de teste iar receptorul daca il mai pornesc la 2-3 zile .
Eu am insatalat ...48 si de atunci cand il opresc sau dau restart tre sa i fac din nou setarile
Sa i setez limba sa l configurez la router etc si nu stiu ce masa sa i mai fac
Reset de fabrica,se trece pe 1.2.32 sii gata.
nu merge nu i dat un atribut gresit?
enigma 2
Buna ziua imi poate spune cineva ce enigma 2 functioneaza bine pe alien 8900, adika sa fie stabila si rapida in acelasi timp, ca eu am incercat vreo 3 si la una nu ii merge bine telecomanda adika nu corepund butoanele alta creapa remane blocata,si tot asa.
Eu acuma merg cu sparku 1.2.48 care e ok exceptand subtitrarea la hd care nu se vede toata se poate face ceva cu ea?
Multumesc.
Pană acum iţi pot recomanda HRnigma ultima, dar o sa fie alţii care iţi vor recomanda altceva....
Oricum asta e prima (şi singura) care nu face stuttering pe canalele cu SR mare ( adică se vede imaginea tremurata).
Incearcă şi vezi.
Sent from my HTC Desire S using Tapatalk
HRnigma3,e ultima sii cea mai stabila dintre toate. Bafta.
Deoarece nu am folosit Enigma pana acum (doar Spark), v-as ruga sa ma indrumati spre un tutorial sau sa-mi explicati cum introduc lista de sateliti si canale in Amiko Alien. In Spark merge si e ok, dar in Enigma sunt "pierdut". Mentionez ca am o montura HH cu ajutorul careia vad tot de la 45E la 12.5W. Multumesc.
Ai nevoie de lista pe care o poti lua de aici ([Only registered and activated users can see links. Click Here To Register...]) lista se pune cu programul dreamboxEDIT pe care il poti lua de pe acest syte ([Only registered and activated users can see links. Click Here To Register...]) ,bafta!
