@sebby - se refera la teletext...un soi de teletext interactiv! Asta e de fapt marea noutate si provocare din partea companiei Fulan...
Hybrid Broadcast Broadband Television (HbbTV) is a pan-European specification for interactive television delivered over both broadcast and broadband Internet connections, delivering information and entertainment services to HbbTV-enabled set-top boxes and iDTVs. The specification is based on a number of existing standards including OIPF (Open IPTV Forum), DVB, W3C and CE-HTML. The current version of the specification (ETSI TS 102 796) can be downloaded from the ETSI web site.
Services such as digital teletext, catch-up TV, electronic programme guides, interactive advertising, games and voting are all possible with HbbTV and many services are already being provided by broadcasters in France and Germany.
S&T is an active member of the HbbTV Consortium and supplies core HbbTV technologies including TSBroadcaster2 for delivery of HbbTV applications via a DSM-CC object carousel. It also generates complete HbbTV signalling via AIT with support for application lifecycle management, application visibility, digital teletext and priority settings.
RedKey™3 is S&T’s HbbTV software engine, providing a complete HbbTV receiver implementation integrating the NetFront™ browser from ACCESS with S&T’s successful RedKey™ product.
Intra pe ARD sau ZDF (Astra sau Hotbird) si apasa tasta rosie dupa ce ai activat! O sa vezi ce se intampla...
Nu au toate televiziunile acest sistem. Mai are de asemenea NED 1 din Olanda,etc. Ai acces la emisiuni inregistrate si multe alte chestii extrem de interesante! Functioneaza doar daca ai conexiune de net!
Apasand tasta rosie apare in dreapta jos acel buton.Mai apesi o data si gata...
Mersi @meridian, se pare ca hbbtv poate fi mai mult decat teletext interactiv !
Se observa la noul soft o imbunatatire considerabila a browserului Opera, chiar ruleaza bine acum, as vrea sa intreb daca se pot modifica legaturile(si imaginile) spre paginile din portal astfel incat sa fie un portal dupa preferintele fiecaruia.
YouTube videos from VEVO in HD 1280x720 still don't work. For example [Only registered and activated users can see links. Click Here To Register...] we can play only in SD quality.
@seby - Poti face tu un site al tau sau blog unde sa pui imagine logo + link. Modifici decat pagina de start, te conectezi si apesi pe link-urile gen logo realizate de tine. Am explicat in posturile anterioare - vezi postul 1032 - unde se pune pagina de start modificata in Spark. Navigare placuta!
O alta hida...nerezolvata inca in browser-ul opera. Nu se poate deschide Radio Dolce Sport pe site-ul oficial:
lipsa plugin flash media player!
Dupa o functionare relativ buna primul bug isi face aparitia din senin, repet, din senin. Imaginea a inghetat si ca solutie a fost binecuvantatul: restart de la butonul din spatele receiverului...dar nu ma pot plange. Pana imi da barba alba softul nativ se va transforma dintr-un blestem intr-un moment de revelatie tarzie...
Mesaj catre Fulan: :2guns::chinese:
Raspunsul lor : :banned:
Sentimentul meu e ca nu se testeaza imaginea. E lansata cum o fi...sa para ca lucrurile sunt in plina actiune. Circ pe paine din soia chinezeasca...
Vorba romanului " Las-o ba ca merge asa ne-am obisnuit cu ea " ... iar am luat-o pe aratura .
Pluginul "e2upgrade" nu mai functioneaza pe ultimul soft, am reinstalat versiunea precedenta si ruleaza fara probleme, am revenit la ultimul soft si este clar, nu functioneaza.
ftp
PHP Code:
HTTP/1.1 404 Not Found Server: Mini Embedded Web Server Date: Fri, 28 Oct 2011 11:52:12 GMT Expires: 0 Pragma: no-cache Cache-Control: no-cache Connection: close Content-Type: text/html
ajutor va rog !
Update database from Fulan!
Menu - Spark - Update Software - Database - Upgrade
New plugin - Mcas
07.11.2011
New all plugin for Amiko SHD-8900 Alien
help
vreau sa stiu de ce nu mai pot da jos de pe imaginea spack alte versiune de imagine ..!!!
acum am img din setarile din fabricatie care nu merge mai nimik decit citeste cardu dar nu pot sa vad sky.it //e.t.c va rog are cineva salvat o veruines mai veche de sparck ?:clap:
Nu merge sa faci downgrade la soft daca difera mult varianta de soft ... adica sa pui peste varianta actuala 1.2.09 o varianta 1.1.42 , difera structura imagini .
Salut
Cine mă poate ajuta să mă conectez la Alien cu un adaptor Edimax 7711 ,poate trebuie setat ceva la Alien sau la adaptor.Vă multumesc
Slot 0 Not Inserted
Salut,
E primul meu post si poate pun o intrebare idioata (din punctul vostru de vedere), am citit aproape tot thread-ul si tot nu am reusit sa activez un plugin (mcas)
Am facut urmatorii pasi:
Am instalat pluginul mcas si altele
Am apasat OK (din meniul Plugin) si s-a activat (adica s-a facut verde iconita)
Acum am doua optiuni pe ecran, tasta rosie start OSD si tasta verde DELETE
Apas tasta rosie si intru in meniu OSD unde pe primul rand scrie Slot 0-Not Insered
Pe al doilea rand Key Editor, aici pot intra nu e problema
Pe ultimul rand este Options unde daca intru am optiunea sa dezactivez SSSP-ul
Apas si tasta verde si PA PA plugin
Instalez din nou pluginul si tot asa..................
Intrebarea mea este de ce nu se activeaza emulatorul, sau daca e activat de ce nu merge?
Ca idee orice plugin as porni tot Slot 0 arata.
Va rog ajutor, sunt praf.
Mi-am luat recieverul asta pt ca are cica media player, dar merge din ce in ce mai prost (din puctul asta de vedere).
Ma uit la un avi rezolutie non hd si din cand in cand se blocheaza cam 10s (ecran negru nici un sunet) apoi isi revine.
Cu versiunile anterioare nu aveam problema asta pe acelasi gen de filme.
Farst forward nu mai merge.
Nu mai imi merge nici TVR HD, dar merg TVR1 si 2.
Mai are cineva problemele astea ?
