oscam-svn11712-amiko_a3-a4-a5
oscam-svn11713
Changeset:
EMM Support for Suisse V7 Card
ICAM ECM Optimized
enigma2-plugin-softcams-oscam_11713-emu-r798_all.ipk-deb
oscam-svn11713-amikoA3-A4-A5-emu-r798
oscam-svn11713-sh4-emu-r798
OSCam-11713 (Ubuntu x86-x64)
OSCam 11.714-emu-r798
Changeset:
- Fix for Viaccess EMM Update < V7 broken
ipk
dep
oscam-svn11714-AmikoA3-A4-A5
---------- Post added at 23:49 ---------- Previous post was at 23:42 ----------
Oscam_icam 11.714
ipk
deb
Oscam 11714 EMU with icam dvbapi ver4
- added Support for V13 (09C4) & V14 (098C) Cards
arm
mipsel
virus
Procesor ARM. Nu porneste oscam.
V5oscam-1.20_svn11714-798-arm-linux-gnueabihf-ssl
---------- Post added at 16:48 ---------- Previous post was at 14:57 ----------
Oscam 11714 EMU with icam dvbapi & Redegast ver5
- New version v5 supporting Radegast and DVBAPI
Depending on the Oscam configuration, you can use DVBAPI or Radegast. This means that if you disable Radegast or insert no ECM data into the stream (E2 setting), the DVBAPI will be used. If you don't decrypt the stream, insert ECM (E2 setting) and activate Radegast, then Radegast will be used
arm
mipsel
e2-plugin-oscam-icam-v5-mipsel-aio_1_mipsel-IPK
IT ONLY WORKS IF YOU ALSO HAVE A PROVIDER WHO DELIVERS ICAM!
OSCam Icam V5 r11714-798
Auto install bouquet ICAM-SKY IT ( 1 bouquet )
Restart BOX after installing (not just restart GUI)
enigma2-plugin-softcams-oscam_11714-emu-r798_all.ipk
mit Icam V5 Patch
OSCam Update V6
Changes:
- Minor optimizations
- NEON is now used for ARM CPUs. These are special parts of the CPU that can execute certain code faster. This helps with decryption. From my point of view, the load on my sf8008 drops a bit. If you want to compare it, then always with the same station and preferably the same show. The load varies greatly from transmitter to transmitter. This means that 128 packets are decrypted at the same time and not 32 as before.
As far as I've read, Mipsel Broadcom boxes don't have this type of processing. With Mipsel I wouldn't use Radegast (if possible) and I wouldn't even compile it at all.
I hope the neon thing doesn't cause problems with other compilers. I had a few problems with my compiler.[Only registered and activated users can see links. Click Here To Register...]
arm-linux oscam-svn-rasb_hard-webif-dvbapi-libusb-emu798-upx 11714
With
Adds-n-option-to-fetch-the-stream-from-address-who-is.patch
-->Question - Raspberry with iCam as server.
and
oscam_emu_icam_dvbapi_radegast_v6.patch
-->ICAM Patch oscam-emu
| Settings:
| CONF_DIR = /usr/local/etc
| CC_OPTS = -O1 -ggdb -pipe -ffunction-sections -fdata-sections -o nodeadcode
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
| CFLAGS = -fexpensive-optimizations -mfpu=neon -DWITH_LIBCRYPTO=1 -DWITH_LIBUSB=1 -DWITH_UTF8=1 -DWITH_UTF8
| LDFLAGS = -Wl,--gc-sections -DWITH_LIBCRYPTO=1 -DWITH_LIBUSB=1 -DWITH_UTF8=1 -DWITH_UTF8
| LIBS = -lcrypto -lusb-1.0 -lrt -lm -lpthread -ldl
| UseFlags = USE_LIBCRYPTO=1 USE_LIBUSB=1 USE_UTF8=1
| Config:
| Addons : WEBIF WEBIF_LIVELOG WEBIF_JQUERY HAVE_DVBAPI READ_SDT_CHARSETS IRDETO_GUESSING WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CS_CACHEEX_AIO CW_CYCLE_CHECK WITH_EMU WITH_SOFTCAM
| Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE GBOX RADEGAST SCAM CONSTCW
| Readers : NAGRA NAGRA_MERLIN IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD DRE TONGFANG BULCRYPT GRIFFIN DGCRYPT
| CardRdrs : PHOENIX INTERNAL SMARGO STINGER SMART
| Compiler : arm-bcm2708hardfp-linux-gnueabi-gcc (crosstool-NG 1.15.2) 4.7.1 20120402 (prerelease)
| Config : build/arm-bcm2708hardfp-linux-gnueabi-libusb/config.mak
arm-linux oscam-1.20_svn11714-798-arm-linux-gnueabihf-ssl_V5_ICAM_ARMFH
For Raspberry PI 2
oscam-1.20_svn 11714-798-arm-linux-gnueabihf-ssl + ICAM +Youtube18 +OSCAM_EMU
OSCam V117.14
-iCam V6
ipk
deb
oscam-icam-patch-v7-svn11714-emu
oscam-svn11714-arm_dream-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-dream_arm-webif-dvbapi-ssl-emu798 = PY3 (9) Openpli based images
oscam-svn11714-dreambox_fpu-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-dream_one-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-hd51-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-Linux-x86_64-webif-dvbapi-ssl-1.1.1f-libusb-emu798
oscam-svn11714-Linux-x86_64-webif-dvbapi-ssl-1.0.1f-libusb-emu798
oscam-svn11714-mipsoe20-webif-dvbapi-ssl-emu798 = PY3 (10)
oscam-svn11714-openpli40-webif-dvbapi-ssl-emu798 Openpli based images
oscam-svn11714-osmio4k-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-rasb_hard-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-samsungtv-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-sh4-webif-dvbapi-ssl-emu798
oscam-svn11714-sh_4-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-solo4k-webif-dvbapi-ssl-libusb-emu798
oscam-svn11714-vuplus4k_arm-webif-dvbapi-ssl-emu798 = PY3 (10)
OsCam r11715 For NewNigma2
- (arm) = dm900/920
- (fpu) = restlichen dreams
- (ONE) = dreambox ONE / TWO
- WebIf Style by gorgone (OsCam Modern)
- mit / ohne emu
- mit / ohne emu ipv6
- CacheEX-AiO Patch
- doublecheck Patch
- Cak7 Patch (Nov21)
- iCam Patch v6
Damit die hier angehängten Versionen laufen, muss libusb-1.0-0 installiert sein.
OE2.0: opkg update && opkg install libusb-1.0-0
OE2.5/2.6: apt-get update && apt-get install libusb-1.0-0
oscam-svn11715-arm_dream-webif-dvbapi-ssl-libusb-emu798-ipv6-upx.tar.gz
oscam-svn11715-arm_dream-webif-dvbapi-ssl-libusb-emu798-upx.tar.gz
oscam-svn11715-dream_one-webif-dvbapi-ssl-libusb-emu798-ipv6-upx.tar.gz
oscam-svn11715-dream_one-webif-dvbapi-ssl-libusb-emu798-upx.tar.gz
oscam-svn11715-dreambox_fpu-webif-dvbapi-ssl-libusb-emu798-ipv6-upx.tar.gz
oscam-svn11715-dreambox_fpu-webif-dvbapi-ssl-libusb-emu798-upx.tar.gz
---------- Post added at 21:08 ---------- Previous post was at 19:53 ----------
OSCam 11715 ICam V 7
Added new ATR
Refresh some Prov. Info
ipk
softcams-oscam_11.715 emu
softcams-oscamicam_11.715
deb
sh4
