(PR) Incase Announces New Compact Ergonomic Keyboard Featuring Microso
Incase, a leading carry and protection brand, today announced the all-new Compact Ergonomic Keyboard. Designed by Microsoft and grounded in more than 25 years of ergonomics research, the Incase Compact Ergonomic Keyboard is optimized for comfort and delivers a premium, natural typing experience. The keyboard also features a dedicated Copilot key to activate Microsoft's AI-powered assistant, and multi-device connectivity for increased productivity and efficiency.
"The Compact Ergonomic Keyboard was designed to take up the smallest possible amount of space while maintaining typing accuracy, comfort and a high-level of performance," said Marshall Clark, Onward General Manager. "We are extremely proud to debut the most innovative and comfortable keyboard for work, play and learning."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
MSI GeForce RTX 5080 Gaming Trio "Blackwell" Box Leaked
Here are some of the first pictures of the MSI GeForce RTX 5080 Gaming Trio "Blackwell" graphics card. The box art provides the first look at what the actual product will look like. It remains over 2 slots thick, and is fairly long; with a trio of what look like 100 mm fans. As with all past generation Gaming X series graphics cards from MSI, this product will feature extensive RGB LED lighting, and a fairly generous factory overclock among its base and premium tiers (Gaming and Gaming X); although historically, MSI's Suprim series has had the company's highest factory tuning.
The back-side of the box lists out MSI-specific and NVIDIA "Blackwell" specific features. The RTX 50-series will see MSI debut the new StormForce fan, which appears to have greater impeller depth than the previous-generation TorX 3.0 fan. The impellers are webbed for axial airflow, the fan blades have ridges. The box also says that the cooler features a nickel-plated copper base-plate, which makes contact with the GPU, which probably has mirror finish. This baseplate will be backed by Core Pipes, which are the cooler's copper heatpipes made square near the baseplate for better contact with it. Lastly, the card comes with a metal backplate—no surprises there. NVIDIA is looking to debut the GeForce RTX 5080 [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) G.Skill Releases Low Latency DDR5-6000 CL26 & CL28 Memory Kits
G.SKILL International Enterprise Co., Ltd, the world's leading brand of performance overclock memory and PC components, is thrilled to release new low CAS latency memory kits featuring AMD EXPO overclock profile for the new AMD Ryzen 9000 series processors and performance X870 chipset motherboards. These new specifications include DDR5-6000 CL26 2x16GB/2x32GB kits and 2x 24 GB/2x 48 GB memory kits under the Trident Z5 Royal Neo, Trident Z5 Neo RGB, and Ripjaws M5 RGB Neo series.
Aiming to provide high-performance overclock DDR5 memory for PC enthusiasts, G.SKILL is releasing a new low CAS Latency memory kit at DDR5-6000 CL26-36-36-96 with kit capacity configuration of 32 GB (2x16GB), as well as the world's first 64 GB (2x32GB) kit capacity for this low latency specification. Featuring the AMD EXPO memory overclocking profile, these new specifications are built for selected X870 series motherboards and AMD Ryzen 9000 series processors. The screenshot below demonstrates DDR5-6000 CL26 2x32GB kit's stability under the Memtest memory stress test on the ASUS ROG Crosshair X870E Hero motherboard and AMD Ryzen 9 9900X desktop processor.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MSI Unveils World's First 27" 4K 240Hz and 27" QHD 500Hz QD-OLED
MSI, the world's leading manufacturer of true gaming hardware, is proudly expanding the hardware possibilities for all gamers. While OLED panels have become the preferred choice for high-end gaming, the OLED burn-in issue has consistently been a major concern for all users. MSI is proud to introduce an exceptional solution that effectively addresses the dreaded OLED problem.
The world's first DisplayPort 2.1a (UHBR20) 27" 4K 240 Hz QD-OLED monitor, the MPG 272URX QD-OLED, is equipped with a 5-layer tandem OLED panel featuring the EL Gen 3 technology. This new material composition improves efficiency up to 30%. This monitor offers stunning clarity with 166 PPI, which enhances text sharpness and significantly reduces color fringing, setting a new standard for daily visuals. Recognized for its design and innovation, it has earned the CES 2025 Innovation Award. ith G-SYNC Compatible support, the monitor delivers smoother, tear-free gaming with reduced lag and fully compatibility with future hardware. This monitor is also perfect for all AAA game titles, ensuring an exceptional gaming experience with flawless performance and visuals.[Only registered and activated users can see links. Click Here To Register...]
ASUS Upcoming ROG Swift OLED PG27UDCM is a 27-inch 4K 240 Hz Gaming Mo
ASUS has published the product page for its upcoming ROG Swift OLED PG27UDCM gaming monitor, which will go head to head with the [Only registered and activated users can see links. Click Here To Register...] on which will hit retail as the first 27-inch 4K 240 Hz display. The PG27UDCM sports a 26.5-inch panel using what ASUS refers to as 4th gen QD-OLED technology, which the company claims offer longer lifespan compared to previous generations of OLED panels. The panel sports typical OLED features such as a 0.03 ms response time, a peak brightness of 1,000 cd/m², 99 percent DCI-P3 colour space coverage and VESA DisplayHDR 400 True Black. The display also supports AMD FreeSync Premium Pro and NVIDIA G-Sync compatible, as well as a host of ASUS specific gaming features such as ELMB, GameFast Input Technology, Shadow Bost and a DisplayWidget.
Inputs consist of a DisplayPort 2.1 port with UHBR20 (80 Gbps) support, a USB Type-C with DP-Alt mode and USB PD up to 90 W and a pair of HDMI 2.1 ports. There's also a three port USB 3.2 Gen 1 (5 Gbps) USB hub with what we presume is a USB Type-B input and a headphone jack. The reason for the presumed USB Type-B input, is that the specs claim KVM support and this would only be possible if there was a USB input of some kind, but this isn't mentioned in the tech specs. The stand is your typical higher-end model with tilt, swivel, pivot and height adjustment, as well as ASUS' Aura Sync lighting and a tripod mount at the top. ASUS claims a power consumption of around 80 Watts, although this doesn't include USB PD. A big plus is that ASUS will bundle a DisplayPort 2.1 DP80 cable in the box, something for example Sony decided not to include with their [Only registered and activated users can see links. Click Here To Register...] which launched in September last year. There's no word on pricing for the ROG Swift OLED PG27UDCM, but expect it to be on the expensive side of US$1,000.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 7 9800X3D CPU Sales Surpass Entire Ryzen 9000 Series at Germ
Recent sales data (nicely complied by VideoCardz) from one of the largest German retailers, Mindfactory, has revealed that the AMD Ryzen 7 9800X3D processor has achieved higher unit sales than all Ryzen 9000 processors combined. Despite its later market entry, the eight-core 9800X3D CPU has reached 8,650 units sold, surpassing the combined sales of the earlier-released standard Ryzen 9000 processors. For comparison, the entire non-X3D Ryzen 9000 lineup, including the Ryzen 9 9950X, 9900X, Ryzen 7 9700X, and Ryzen 5 9600X, has accumulated fewer total sales through the same retailer. The flagship Ryzen 9 9950X alone accounts for just 780 units, while the Ryzen 9 9900X and Ryzen 5 9600X have moved 810 and 890 units, respectively, while the second-best selling 9000 series SKU was Ryzen 7 9700X with 2,510 units sold. However, the 9800X3D's market performance still falls significantly short of its predecessor. The previous generation Ryzen 7 7800X3D maintains a massive lead with 78,420 units sold through the same retailer.
AMD is preparing to expand its X3D lineup with several new models. The six-core Ryzen 5 9600X3D is scheduled for release, along with 12-core Ryzen 9 9900X3D and [Only registered and activated users can see links. Click Here To Register...] expected later this month. Based on previous generation sales patterns, where higher-core models saw lower adoption rates, these upcoming high-end processors may face similar market dynamics. Of course, these sales figures are only a part of the story as Mindfactory is only a single retailer across a diverse set of sellers, so the complete market picture is unknown to anyone but AMD. PC upgrade cycles are a common bottleneck in new CPU sales, especially as consumers don't tend to upgrade their PCs every year with new CPUs and platforms. We have to wait and see how the market adapts to new X3D SKUs, and if the Zen 5 X3D CPUs can reach the previous generation fame among consumers.[Only registered and activated users can see links. Click Here To Register...]
Nintendo Switch 2 PCB Leak Reveals an NVIDIA Tegra T239 Chip Optically
Nintendo Switch 2 promises to be this year's big (well small) gaming platform launch. It goes up against a growing ecosystem of handhelds based on x86-64 mobile processors running Windows, its main play would have to be offering a similar or better gameplay experience, but with better battery life, given that all of its hardware is purpose-built for a handheld console, and runs a highly optimized software stack; and the SoC forms a big part of this. Nintendo turned to NVIDIA for the job, given its graphics IP leadership, and its ability to integrate it with Arm CPU IP in a semi-custom chip. Someone with access to a Switch 2 prototype, likely an ISV, took the device apart, revealing the chip, a die-shrunk version of the Tegra T239 from 2023.
It's important to note that prototype consoles physically appear nothing like the final product, they're just designed so ISVs and game developers can validate them, and together with PC-based "official" emulation, set up the ability to develop or port games to the new platform. The Switch 2 looks very similar to the original Switch, it is a large tablet-like device, with detachable controllers. The largest chip on the mainboard is the NVIDIA Tegra T239. Nintendo Prime shared more details about the chip.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
NVIDIA Plans GeForce RTX 5080 "Blackwell" Availability on January 21,
Hong Kong tech media HKEPC report indicates that NVIDIA's GeForce RTX 5080 graphics card will launch on January 21, 2025. The release follows a planned announcement event on January 6, where CEO Jensen Huang will present the new "Blackwell" architecture. Anticipated specifications based on prior rumors point to RTX 5080 using GB203-400-A1 chip, containing 10,752 CUDA cores across 84 SM. The card maintains 16 GB of memory but upgrades to GDDR7 technology running at [Only registered and activated users can see links. Click Here To Register...], while other cards in the series are expected to use 28 Gbps memory. The graphics card is manufactured using TSMC's 4NP 4 nm node. This improvement in manufacturing technology, combined with architectural changes, accounts for most of the expected performance gains, as the raw CUDA core count only increased by 10% over the RTX 4080. NVIDIA is also introducing [Only registered and activated users can see links. Click Here To Register...] between its Blackwell SKUs, as the RTX 5090 has nearly double CUDA cores and double GDDR7 memory capacity.
NVIDIA is organizing a [Only registered and activated users can see links. Click Here To Register...] two days before the announcement, marking the return of this gathering after 13 years, so the timing is interesting. NVIDIA wants to capture gamer's hearts with 50 hours of non-stop gameplay. Meanwhile, AMD currently has no competing products announced in the high-end graphics segment, leaving NVIDIA without direct competition in this performance tier. This market situation could affect the final pricing of the RTX 5080, which will be revealed during the January keynote. While the January 21 date appears set for the RTX 5080, launch dates for other cards in the Blackwell family, including the RTX 5090 and RTX 5070 series, remain unconfirmed. NVIDIA typically releases different models in their GPU families on separate dates to manage production and distribution effectively.[Only registered and activated users can see links. Click Here To Register...]
AMD to Launch Mid-range SKUs of the Radeon RX 9000 Series in March
AMD is expected to have a rather lean lineup of next-generation gaming GPUs powered by the RDNA 4 graphics architecture. The series is expected to debut at AMD's 2025 International CES keynote address, with product launches of the series-leading Radeon RX 9070 XT and RX 9070 performance-segment GPUs later this month. The RX 9070 should be available by late-January, although add-in board partners from China expect availability to ramp in February 2025. The series will see expansion with more announcements in March.
The RDNA 4 generation is driven mainly by two chips—the larger "Navi 48," and the smaller "Navi 44." The "Navi 48" will power the RX 9070 series, which are performance-segment and designed to compete with the NVIDIA GeForce RTX 5070 series; but cut-down variants of the chip are also expected to power certain upper mid-range SKUs that go up against the RTX 5060 series. The "Navi 44" chip is expected to power certain high performance/price SKUs in the mid-range, which AMD will use to target price-points well under the $300-mark. This segment is expected to heat up as NVIDIA has current-generation RTX 4060 series, Intel just made a stab with the Arc B580, and is expected to launch a faster Arc B700-series SKU based on a maxed-out "BMG-G21" silicon.[Only registered and activated users can see links. Click Here To Register...]
TSMC Is Getting Ready to Launch Its First 2nm Production Line
TSMC is making progress with its most advanced 2 nm (N2) node, a recent report from MoneyDJ quoting industry sources indicates that the company is setting up a test production line at the Hsinchu Baoshan fab (Fab 20) in Taiwan. In the early stages, TSMC aims for small monthly outputs with about 3,000-3,500 wafers. However, the company has big plans to combine production from two factories in Hsinchu and Kaohsiung, TSMC expects to deliver more than 50,000 wafers monthly by the end of 2025 and by the end of 2026 projecting a production of around 125,000 wafers per month. Breaking it down by location, the Hsinchu factory should reach 20,000-25,000 wafers monthly by late 2025, growing to about 60,000-65,000 by early 2027. Meanwhile, the Kaohsiung factory is expected to produce 25,000-30,000 wafers monthly by late 2025, also increasing to 60,000-65,000 by early 2027.
TSMC's chairman C.C. Wei says there's more demand for these 2 nm chips than there was for the 3 nm. This increased "appetite" for 2 nm chips is likely due to the significant improvements this technology brings: it uses 24-35% less power, can run 15% faster at the same power level, and can fit 15% more transistors in the same space compared to the 3 nm chips. Apple will be the first company to use these chips, followed by other major tech companies like MediaTek, Qualcomm, Intel, NVIDIA, AMD, and Broadcom.[Only registered and activated users can see links. Click Here To Register...]
(PR) Sansui to Showcase AI Gaming Monitor at CES 2025
Sansui is thrilled to announce its presence at CES 2025, where it will showcase the award winning AI Gaming Monitor, recently named a CES Innovation Awards 2025 Honoree. This cutting-edge gaming monitor highlights Sansui's dedication to redefining the gaming experience with advanced AI technology and user-focused innovation.
"CES is the ultimate stage for innovation, and we're excited to showcase a product that represents the future of gaming," said Victor, Senior Vice President of Marketing at Sansui. "Our AI Gaming Monitor combines top-tier performance with features that enhance health and energy efficiency, delivering a truly next-level experience for gamers." Attendees can experience this innovation firsthand at Booth 19840, Central Hall, LVCC, in Las Vegas from January 7-10, 2025.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) JSAUX Debuts the New FlipGo Portable Monitor and More at CES 2025
Tech manufacturer JSAUX announces it will attend CES Las Vegas for the very first time during January 7-10. JSAUX's booth will be located at the LVCC - South Hall 1, booth no. 32344 and it will showcase a line up of new and exciting products from different categories: the FlipGo Horizon, a new entry in its family of portable monitors, and its accessories for iPhone.
Founded in 2016, JSAUX has established itself as a leading name in the gaming accessory market, with products recognized across 100+ countries. The brand's success stems from four key factors:[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
New Year, but Same Great Prices on Software from GoDeal24
GoDeal24 is an international merchant of genuine, globally-valid software, wishing you a great year ahead. It might be a new year, but our prices haven't changed! Get Genuine Office 2021 Professional Plus at just $35.11. Save more with multi-PC packs going up to 5-PCs. Save even more when you pair this with your preferred edition of Windows, with the Windows 11 Pro + Office 2021 Professional Plus combo going for $47.59. Start saving!
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
Please use the coupon code TCP62 on the following items to avail the prices you see here.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
(PR) Belkin Boosts CES 2025 Lineup With New Audio Concepts, Content Cr
Belkin, a leading consumer electronics brand for 40 years, today introduced several new products across its Mobile Power, Audio and Future Ventures portfolios, underscoring Belkin design excellence, dedication to quality, and commitment to building products more responsibly. Belkin is showcasing its newly announced products at CES Unveiled Las Vegas - the official media event of CES 2025.
Built more responsibly with up to 90% recycled materials
Two years since introducing its transition to using 72-75% post-consumer recycled (PCR) materials in its products, Belkin has transitioned over 359 products and has replaced 432 metric tons of virgin plastics with PCR materials.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
GMKTec K11 Mini PC Unveiled With up to 96 GB of Memory, Ryzen 9, and O
GMKTec is a relatively well-known brand of mini PCs that ships internationally from its official online store. The brand's latest offering, the K11, is an RGB-fied mini PC that sports adequately powerful internals for almost any task. At its core, the K11 is powered by the Ryzen 9 8945HS "Hawk Point" APU with eight Zen 4 cores and 16 threads. The system comes pre-installed with up to 32 GB of memory and a 2 TB SSD, both of which can be upgraded down the line.
The memory can be upgraded to a whopping 96 GB, whereas the storage can be upgraded to 8 TB via the dual M.2 slots. The integrated Radeon 780M GPU is decently powerful for most non-intensive workloads, but pushing it any further might be futile. For such cases, the OCuLink port will definitely come in handy, offering speedy eGPU connections that far outshine USB-based solutions. The cooling solution appears to be sufficient on paper, allowing the system to draw up to 70 watts.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Xiaomi Unveils 14" and 16" RedmiBook (2025) with 12-core Intel Core 20
Xiaomi has officially introduced the 2025-lineup for its RedmiBook laptop, which comes in 14-inch and 16-inch flavors. Although the launch is limited to China as of now, its highly probable that the laptop will visit the international market as well. At its heart, both the variants are powered by the Core 5 220H CPU based on Raptor Lake-H Refresh. The chip sports 12 cores and 16 threads, with clock speeds of 2 to 4.9 GHz. There is no dedicated graphics support, and the system relies on the Iris Xe iGPU that is substantially slower than the newer Arc iGPUs found in Arrow Lake and Lunar Lake lineups.
The laptops are relatively thin and light, at 15.9 mm thin, and tip the scales at 1.36 and 1.65 kg respectively. Xiaomi advertises 19.05 hours of battery life courtesy of a 72 Wh battery, but the real world performance will almost certainly be slightly worse. The 14-inch model sports a 2.8K LCD, whereas the 16-inch version, intriguingly, sports a 2.5K display. Both the displays feature a refresh rate of 120 Hz - a welcome addition for sure. The product starts at around $640 for the 14-inch variant with a 16 GB + 512 GB configuration, and the 16-inch version costs around $30 more.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
This Week in Gaming (Week 2)
Welcome to the first full week of the new year and the month of January. This week's major release involves building pointy buildings in the desert, just south of the Mediterranean. The rest of this week's new releases involves getting imprisoned by aliens, making steampunk chocolate, work as a robot assassin, purging the land and doing hard time in a futuristic version of Japan.
[Only registered and activated users can see links. Click Here To Register...] / This week's major release / Wednesday 8 January
In Builders of Egypt, you can explore the land of the pharaohs through the ages, from the Nile Delta to Nubia. Build cities, manage trade, economy, and resources, make strategic decisions, control armies and engage in battles, foster religious development, and ensure the well-being of your citizens. Play through a complete campaign or unleash your creativity in Sandbox mode. [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
BOOX Note Max with 13.3-inch E-Ink Display Launches Worldwide
E-Ink aficionados have been on the rise in recent years, and for good reason. E-Ink displays, despite their undeniable downsides, are excellent for note-taking and reading without having to worry about eye-strain. The 13.3-inch BOOX Note Max is an excellent option for its targeted demographic, and is now available for purchase worldwide for a relatively affordable price of $649.
The Note Max sports Android support, specifically Android 13. Needless to say, this means that a plethora of apps and functionality can be installed separately. The 13.3-inch capacitive touch display with 4,096 levels of pressure sensitivity sports a resolution for 3200 x 2400, amounting to a commendable PPI value of 300. An octa-core 2.8 GHz CPU takes care of all the computing needs, paired with 6 GB of memory. Of course, the Note Max is not meant to be a powerhouse, but decent performance is always welcome.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) 'Horizon Zero Dawn' Meets 'Clash of Clans' in City of Springs
Indie developers Alterego Games and The Naked Dev, have today announced the release of City of Springs - Craft & modify your robot drones to fight off a cruel regime in this steampunk adventure game.
City of Springs
You play as Val, a brilliant mechanic from the big slum district of the last city on earth. A cruel and strict regime controls every aspect of life in the city, and any transgression is taken out of your rations. The city is like a broken clock. Someone has to stand up to the ministries and fix it.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ZOWIE Introduces XL2586X+ eSports Monitor With 600Hz Refresh Rate
ZOWIE proudly announces XL2586X+, a new eSports gaming monitor featuring the latest Fast-TN panels for superior refresh speed and DyAc 2 technology for quick response times with minimal motion blur. Upgraded from 540 Hz to 600 Hz, XL2586X+ is now the fastest gaming monitor available, consistently ensuring smooth visuals during fast-motion and dramatic transitions without overclocking. It also includes auto game mode via XL Setting to Share software and industrial-grade bearings for precise height adjustment, solidifying XL-X+ series' position as the mainstream standard for eSports competitions and exemplifying ZOWIE's mission is to lead the FPS field by providing competitive players with top-tier equipment and the most seamless in-game experiences.
Our Mission
By continually developing professional eSports products specifically designed for FPS players, ZOWIE has come to deeply understand their needs. Going the extra mile and paying attention to the smallest details is how we give players the best gaming experience and help them achieve their very best.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
