Pentru no-ip cum trebuie linia asta?
Code:#option update_url "http://[USERNAME]:[PASSWORD]@members.dyndns.org/nic/update?hostname=[DOMAIN]&myip=[IP]"
la ce e cu # nu e neaparat important,fiindca in cazul de fata nu e folosit, tu pt no-ip trebuie sa modifici la
inQuote:
option service_name "dyndns.org"
nu am testatQuote:
option service_name "no-ip.com"
Merge si pe dd-wrt:
Am facut in modul urmator:Quote:
Multiple DDNS host names
If you have multiple host names registered at your DDNS service, you can enter them in the "Host Name" field using the "-a" option.
Example: You want to update the IP address for myhostname1.example.org, myhostname2.example.org and myhostname3.example.org; in this case, you have to enter in the "Host Name" field the following string: "myhostname1.example.org -a myhostname2.example.org -a myhostname3.example.org". (Note: no "-a" for the first host name.)
NO-IP
No-IP a leading DNS provider including free DDNS and fully managed DNS service they also offer ICANN accredited domain registration and email services.
In some cases, Inadyn fails resolving the remote no-ip hosts. The solution is replacing the named hosts with the direct No-IP server numbers. Replace dynupdate.no-ip.com with the IP 204.16.252.79 and ip1.dynupdate.no-ip.com with 204.16.252.106. (Please do ping before to the servers to verify if no-ip has changed the IP's)
am pus '-a' intre cele doua hosturi!
e bine ca nu ai mai multi useri ca atunci era o problema la ce ai facut tu :), bine ca ai rezolvat.
este cam offtopic si imi cer iertare ...
a pus cineva oscam pe topex cu imagine openwrt ? multumesc :drinks:
pune oscamul asta
scriptu de start il faci similar ca la restu doar adaptat oscam.
fisierele de configurare se pun tot in /opt/var/etc/ ?
/opt/var/bin/CCcam.mipsel -C /opt/var/etc/CCcam.cfg aceasta linie este extrasa din start_CCcam ... pentru oscam cum ar trebui sa fie linia avand in considerare ca sunt mai multe fisiere de configurare
multumesc
@stargate ai reusit sa pornesti oscamu pe router?
la mine cu comanda asta in putty.../opt/var/bin/./start_oscam...imi zice:
Bus error
scriptu de pornire l-am facut asa:
#!/bin/sh
if [ -n "`pidof oscam.mipsel`" ] ; then
killall oscam.mipsel
fi
#sleep 1
#export LD_PRELOAD=/opt/var/lib/ld.so.1:/opt/var/lib/libcrypt.so.1:/opt/var/lib/libstdc++.so.6:/opt/var/lib/libm.so.6:/opt/var/lib/libc.so.6:/opt/var/lib/libgcc_s.so.1:/opt/var/lib/libpthread.so.0:/opt/var/lib/libnss_dns.so.2:/opt/var/lib/libresolv.so.2
#export LD_LIBRARY_PATH=/mmc/lib
export LD_LIBRARY_PATH=/opt/var/lib
#sleep 1
#killall logger syslogd klogd
sleep 1
#/mmc/var/bin/mpcs -c /mmc/var/etc
/opt/var/bin/oscam.mipsel -C /opt/var/etc/oscam.conf:oscam.server:oscam.user
unde sa fie gresala????
cred ca totusi sunt probleme de librarii , fisierele de configurare oscam se pun in
/opt/etc/oscam
AM avut timp, sa testez si eu oscam pe router ( wl500gd ), dar este la fel si pt Linksys WRT54GL
1.) cititorul serial ramane acelasi conectat pe portul serial 1 si un GPIOX (x la care GPIO e conectat reset-ul de card la mine in exemplu este 7 )
2. ultimul kamikaze: KAMIKAZE 8.09.2 ( este important doar pentru librarii care sunt sau NU nevoie ) aici nu sunt nevoie de librarii diferite fata de sistem, deci nu trebuie script special de pornire cu LD_LIBRARY_PATH ca si in cazul NewCS, foarte importan NU este nevoie nici de newcsgpio!!
oscam.server pentru serial reader arata asa :
ATENTIE! protocol = mouse si detect = gpio7 , trebuie sa editati doar gpio7 in functie de configuratia voastra a cititorului serial.Code:[reader]
label = DigiTV
protocol = mouse
detect = gpio7
device = /dev/tts/1
mhz = 368
cardmhz = 368
emmcache = 1,3,2
n3_boxkey = XXXXXXX
n3_rsakey = XXXXXX
ReconnectTimeout = 20
DisableServerFilter = 1
Group = 1
Fallback = 0
Oscam se pune in /var/bin , fisierele de configurare in /var/etc ( sau dupa preferinte :) )
Pornirea se face : /var/bin/oscam -c /var/etc -b .
Are si WEBIF - adica deschide port http unde puteti avea acces la oscam. ( trebuie configurat in oscam.server, deci a se studia aceasta sectiune [webif]
httpport = .... )
Sper ca am fost destul de explicit :)
a mai incercat cineva sa porneasca cccam 2.1.4 pe dd-wrt?
deci pana la urma tot trebuie cu script.daca nu macar puse in /lib fisierele,asta e la cel ce vi l-am trimis mai sus.Quote:
root@OpenWrt:/mnt/sda2/var/bin# ldd ./oscam
libpthread.so.0 => /lib/libpthread.so.0 (0x2aaee000)
libc.so.0 => /lib/libc.so.0 (0x2ab43000)
libc.so.6 => not found
ld.so.1 => /lib/ld.so.1 (0x2abe9000)
ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x2aaa8000)
Acesta merge fara nici o alta librarie suplimentara:
asta e varianta de care spune @prodigy
Daca vrei cccam 2.1.4 treci pe kernel 2.6Quote:
root@OpenWrt:/mnt/sda2/var/bin# ldd ./oscam-router
libcrypt.so.0 => /lib/libcrypt.so.0 (0x2aaee000)
libm.so.0 => /lib/libm.so.0 (0x2ab43000)
libc.so.0 => /lib/libc.so.0 (0x2ab91000)
@resofty, nu stiu ce invarti tu pe routerul acela :) dar la mine nu cere nimic in plus fata de ce vine cu kamikaze, tot ce am scris este testat si functional de ieri pe router, si pot sa spun ca is super multumit de oscam + card N2 fata de NewCS....
...varianta ta necesita ld.so.1 care trebuie pus in /lib ( care pe dd-wrt nu poti copia ), sau editat in hexa iar binaru de oscam,...anyway in concluzie =>
OSCAM bate la cur NewCS!!! :cheers:
Eu doar am spus ca versiunea de sus necesita librariile ce le-am indicat in postul anterior(primul quote), versiunea care merge cu librariile deja existente in openwrt/ddwrt am atasat-o in postul anterior(probabil aceeasi care o folosesti si tu :) ).
la @c0co10 am rezolvat sa mearga ca si la mine...
problema e ca se copiaza in /lib tot feluri de librarii din cine stie ce locuri, si se face o varza intre librarii si normal ca numai merge nimic. ( erori Bus error si kikaturi ).
- folositi opkg pentru a instala librarii care se pot instala din openwrt!!!
- la el a fost problema de la libc.so.6 si libpthread.so.0 pe care le-a copiat din alte distributii.
bafta la toti!
Flash mai mare se poate pune? de 4G?pe asus wl-500 ?
Eu de 4Gb am si merge f bine.
Este partitionat asa:
partitia 1 e swap 128 Mb
partitia 2 e ext3 de 512 Mb
partitia 3 e ext3 restul stickului de 3Gb si ceva
Flash memory? sau stick? eu vb de flash memory
cine ma poate ajuta sa pornesc oscam pe router topex open-wrt , am pus fisierul oscam recomandat de @prodigy am pus librariile necesare in /lib , mi-au fost cerute cand am dat comanda /opt/var/bin/oscam -C /opt/var/etc -b , dupa ce am pus librariile la comanda de pornire imi da : Segmentation fault si nu porneste .
va multumesc
vezi ca @prodigy a pus pe linksys nu pe asus (topex) acolo sut librarile corecte in lib la topex nu stiu ca am aceeasi erroare :D
