bine ai revenit prietene drag :) ......sa faci ALTDVB cum sti t mai bine....deh a fost si ramane prima iubire :)
LA MULTI ANI!!!!!!!!!!!!!!!!!
O veste buna pentru inceputul de an. Multumesc.
AltDVB version v2.3
v2.3 (2020-01-04)
Application:
– added support for HEVC
– added support for AAC,AAC-LATM and EAC3
– added support for EVR – Enhanced Video Renderer
– experimental built-in support for PLS and MIS.Currently only for TBS devices using my Dev_BdaDriver.int.
– simplified directshow config
– portable: doesn’t use registry to store settings, run as standard user (without admin rights)
– new version of DvbAvSrc.ax, used directly, does NOT need to be registered in the system using regsvr32.exe
– added support for “internal†directshow decoders (only LAV filters, for now)
– some optimization in TS packets demuxer & A/V stream path
– removed some unused/obsolete features (SDX files & coverage images,…)
– new directory structure.(files from dir. [SatFiles] moved to \Channels, \Configs, \Transponders)
– new file format for channel list.
– new file format for transponders with saving informations about signal
– channel search by name moved above list
– new options for better filtering channel list
– introduced kHz precision for frequencies
– external config file for CA names
– added more MODCODE’s and Roll-off values
– fixed a lot of bugs, added new ones 🙂
Old Non-BDA interfaces:
* New: Dev_TTBudget.dll
– need drv. 2.19h (28.11.2006)
– you have to copy “ttlcdacc.dll†(ver. >= 2.19.8.1) into ..\AltDvb\Devices\
– tested with S2-3200
* Dev_SkyStar2:
– fixed DiSEqC command when using driver >= 4.4.0
– built without VCL
In sfarsit, anuntat de 4 ani a aparut . Multumim.
Testat pe cablu, merge foarte bine.
Nu am gasit cum sa activez subtitrarea dvb, daca se poate.
@[Only registered and activated users can see links. Click Here To Register...] - Nu cred sa aiba subtitrare in aplicatia originala. Versiunile anterioare nu aveau, eu nu am gasit nici in 2.3.
Nu reusesc sa gasesc tutorialul colegiului Staric referitor la subtitrarile dvb pe AltDVB + VLC.
Aceasta?
Din păcate nu, tin minte ca vizionarea se făcea prin VLC.
Cum ai testat pe cablu?Quote:
Originally Posted by marcghi [Only registered and activated users can see links. Click Here To Register...]
Cu un DVB-T2/DVB-C/FM/DAB ([Only registered and activated users can see links. Click Here To Register...]) + vplug + softcam + cablu gigi.
Pe programele care au subtitrare dvb -ex. FilmAcum
La asta te refereai ? nu prea e clar ce vrei sa afli.
Nu stiam ce tuner ai!
Deci sa inteleg ca merge cu Astrometa !
Multumesc de raspuns!
Alt-Dvb 2.3
PowerVuEmu este cu Softcam-ul cu key-le actualizate, AltDvb 2.3 le vede dar nu face lumina!
Pe softuri alternative, cum ar fi fi SmartDvb acelasi softcam este luminat, am folosit aceeasi aceasi versiune PowrVuEmu si acelasi softcam pe ambele.
Pe Smart Dvb se deschide, pe altdvb este citit si vazut dar nu deschide
Unde ar fi problema?
Salut !Quote:
Originally Posted by dingo31 [Only registered and activated users can see links. Click Here To Register...]
Problema este la AltDVB: plugin-ul decripteaza streamul dar pachetele decriptate nu sunt folosite de engine-ul intern. Cand l-am optimizat pentru FFDeCSA nu credeam ca o sa se inventeze plugin-uri care fac singure decriptarea :)
O sa incerc sa rezolv problema in urmatoarea versiune !
Plecand de la sugestia ca ar fi posibil subtitrare ALTDVB+VLC, am gasit urmatoarea modalitate:Quote:
1)Se deschide functia record
2)Se selecteaza modul AV0
3)Se bifeaza subtitrarile dorite si pistele audio dorite.
Obligatoriu se activeaza PAT iar PMT ramane activat
4)Se apasa record, apoi se merge in folderul definit: AltDvb/Records.
5)Se deschide cu VLC fisierul respectiv, apoi se selecteaza subtitrarea si pista audio dorita.
Pe timpul vizionarii nu se opreste AltDvb si functia Record.
Va fi un mic delay, mai mare sau mai mic in functia de intarzierea cu care se deschide VLC de la inceperea opertiei.
Sunetul pe AltDvb va fi dat la minim pentru a nu se acoperi cu sunetul VLC
Se poate incerca si cu alte playere, nu doar VLC
Va salut,
Am cateva probleme cu ultima versiune. De ce dupa scanare ( satelit), nu-mi pastreaza lista de canale ? Faptul ca nu am imagine video dupa scanare tine probabil de configurarea codec-urilor ?
Multumesc
---------- Post added at 16:52 ---------- Previous post was at 16:41 ----------
Prima parte am rezolvat-o. Scuze, eu nu am fost atent, lipsa de exercitiu.
Salutare,
Daca mai sunt pe aici utilizatori ai aplicatiei mele, am pus pe site o versiune noua:
Va doresc numai bine & sa ramaneti sanatosi !
Salutari AltxRo.
Multumim pentru munca depusa :)
Stay safe.
Buna treaba, multumim pentru munca depusa.
Din pacate nu s-a gasit solutia pentru subtitrarea DVB, ramane varianta mai complicata cu VLC.
Cu placere ! Sper sa fie de folos celor putini ramasi cu acest hobby.
Subtitrarea DVB e in lucru dar nu am avut timp sa o finalizez pentru v2.4. Sigur o sa fie disponibila in urmatoarea versiune.
Dacă ai timp studiază SAT-IP, sunt de 10 ori mai multe tunere disponibile.
Ne-am bucura mai mult și mai mulți de aceasta minunata aplicatie pentru care îți mulțumim.
