merge la cineva tunerul asta pe dreambox?
Pentru ca nu au trecut decat 3 ani de la aceasta postare, poate iti mai amintesti daca ai facut ceva special pentru configurarea tuner-ului.Quote:
Originally Posted by ag.laur [Only registered and activated users can see links. Click Here To Register...]
Am comandat si eu acum tuner xbox si incerc sa-l configurez pe VU+zero, dar nu-mi vede tunerul in Settings.
Am instalat driverul din PLugins, am restartat receiverul... Mai trebuie sa-i fac ceva?
Sub OpenATV 7.3 este suficient sa instalezi driverul USB DVB DIB0700 ,
sa dai reboot ... dupa care ar trebui sa vezi tunerul si sa poti scana !
Incearca asta.Instalezi prin telnet.
opkg install firmware-mn8847x
opkg install kernel-module-mn88472
opkg install firmware-dvb-demod-mn88472-02
opkg install kernel-module-tda18250
opkg install firmware-dvb-usb-dib0700-1.20
opkg install kernel-module-dvb-usb-dib0700
Am pus 7.3 (anterior pusesem Pure2 6.5, OpenPli 8.3, BlackHole 3.1.0, OpenVIX6.4, OpenATV 7.2).
La OpenATV 7.3 luata de aici: [Only registered and activated users can see links. Click Here To Register...]
nu se descarca plugin-urile.
Am incescat imaginile:
openatv-7.3-vuzero-20231004_usb.zip
openatv-7.3-vuzero-20231011_usb.zip
root@vuzero:~# opkg update
Downloading [Only registered and activated users can see links. Click Here To Register...].
* opkg_download_backend: Failed to download [Only registered and activated users can see links. Click Here To Register...], wget returned 4.
root@vuzero:~#
paretea mea din cate observ verifica sa ai internet pe rec primadata
Am internet.
root@vuzero:~# ping feeds2.mynonpublic.com
PING feeds2.mynonpublic.com (136.243.69.212): 56 data bytes
64 bytes from 136.243.69.212: seq=0 ttl=56 time=29.852 ms
64 bytes from 136.243.69.212: seq=1 ttl=56 time=29.737 ms
64 bytes from 136.243.69.212: seq=2 ttl=56 time=29.655 ms
64 bytes from 136.243.69.212: seq=3 ttl=56 time=29.319 ms
64 bytes from 136.243.69.212: seq=4 ttl=56 time=29.421 ms
64 bytes from 136.243.69.212: seq=5 ttl=56 time=29.496 ms
^C
--- feeds2.mynonpublic.com ping statistics ---
6 packets transmitted, 6 packets received, 0% packet loss
round-trip min/avg/max = 29.319/29.580/29.852 ms
root@vuzero:~#
root@vuzero:~#
root@vuzero:~#
root@vuzero:~# wget [Only registered and activated users can see links. Click Here To Register...]
--2023-10-13 08:09:38-- [Only registered and activated users can see links. Click Here To Register...]
Resolving feeds2.mynonpublic.com... 2a01:4f8:212:23d2::2, 2a01:4f8:150:61f4::2, 176.9.45.237, ...
Connecting to feeds2.mynonpublic.com|2a01:4f8:212:23d2::2|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 11862 (12K) [application/x-gzip]
Saving to: ‘Packages.gz.1’
Packages.gz.1 100%[==============================================================================================>] 11.58K --.-KB/s in 0.005s
2023-10-13 08:09:44 (2.11 MB/s) - ‘Packages.gz.1’ saved [11862/11862]
root@vuzero:~#
Nu inteleg de ce nu merge opkg update, dar wget [Only registered and activated users can see links. Click Here To Register...] functioneaza...
Cred ca au o problema temporara cu serverul !
Cu siguranta , pe VU+ va functiona !
Pe Dreambox este cu cantec ! acolo unde Kernelul
este 4.9 de provenienta DreamOS ... nu va merge !
Am gasit solutia pentru eroarea de update: [Only registered and activated users can see links. Click Here To Register...]
Am instalat driverul, dar tot nu apare in Tuner configuration.
Uita-te la Information ce versiune de Kernel foloseste OpenATV
---------- Post added at 10:00 ---------- Previous post was at 09:51 ----------
Comentariile gasite de mine pe acest subiect spun :
- la versiunea de Kernel 4.1.16 erau probleme pe unele modele
- la versiunea de Kernel 4.1.20 ( OpenPli) mergea
- la Black Hole merge fara sa trebuiesca instalate drivere !!!
---------- Post added at 10:02 ---------- Previous post was at 10:00 ----------
O sa-i scriu lui @Captain sa vedem ce spune despre OpenATV 7.3 !
Totusi ... ce versiune de Kernel are OpenATV 7.3 pentru VU+Zero 4k ?
---------- Post added at 10:12 ---------- Previous post was at 10:02 ----------
Este chiar vechiul VU+Zero ? deci nu VU+Zero 4K ?
s-ar putea ca acolo Kerneul sa nu aiba suport !!!
ibiza poti testa si imaginea noua egami-10.4-r9 vuzero nu stiu exact ce versiune Kernel are
La OpenATV se pare ca ultima revizie de Kernel pentru VU+Zero este din 2015.
Imaginea OpenATV 7.3 are kernel 3.13.5 / 20190715
Este VU+Zero simplu (nu 4K).
Ce versiune de OpenPLI are kernelul 4x?
Blackhole nu mi-a mers.
Incerc acum egami-10.4-r9 vuzero
---------- Post added at 14:03 ---------- Previous post was at 13:18 ----------
Nici Egami nu merge
System OE: OE-Alliance 5.3
Firmware version: egami 10.4.20230912 (2023-09-12)
Kernel / Drivers: 3.13.5 / 20190715
---------- Post added at 14:18 ---------- Previous post was at 14:03 ----------
Nu gasesc versiuni mai recente de kernel pentru vu+zero. Si totusi se pare ca unora le merge in combinatia VU+zero + XBOX Tuner
Referintele gasite de mine , erau toate la Vu+Zero 4K , cu chipset
ARM si Kernel 4.1.x !!! Cred ca incercarea ta este o cauza pierduta !
suportul Kernel USB-DVB apare numai la Kernel 4.x !
eu zic sa renunti la ideia de tuner usb pe modelul vu+zero simplu hd nu are suport kernel 3.13.5 e ultimul pt acest model
