La mine nu citeste cardul TVR :(
oscam-1.20uEB_RSP_SVN7937-sh4-linux
Code:+-------------------------------------------------------------------------------
| OSCam ver: 1.20uEB_RSP_SVN rev: 7937 target: sh4-linux
| Tools:
| CROSS = /duck211/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-
| CC = /duck211/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-gcc
| STRIP = /duck211/tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-strip
| Settings:
| CONF_DIR = /var/keys
| CC_OPTS = -O2 -ggdb -ffunction-sections -fdata-sections
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
| CFLAGS =
| LDFLAGS = -Wl,--gc-sections
| LIBS = -lpthread -ldl
| Config:
| Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_LB
| Protocols: NEWCAMD CCCAM CCCSHARE CONSTCW
| Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD
| CardRdrs : INTERNAL STAPI
| Compiler : sh4-linux-gcc (GCC) 4.5.2 20110124 (STMicroelectronics/Linux Base 4.5.2-78)
| Linker : GNU ld (GNU Binutils - STMicroelectronics/Linux Base) 2.19.1
| Binary : Distribution/oscam-1.20uEB_RSP_SVN7937-sh4-linux
oscam-1.20uEB_RSP_SVN7943-sh4-linux
| OSCam ver: 1.20-unstable_svn rev: 7946 target: sh4-linux
| Tools:
| CROSS = sh4-linux-
| CC = sh4-linux-gcc
| STRIP = sh4-linux-strip
| Settings:
| CFLAGS = -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
| LDFLAGS = -Wl,--gc-sections -L/oscam-svn/external_LIBS/SH4-DVBAPI/lib -I/oscam-svn/external_LIBS/SH4-DVBAPI/include
| LIBS = -lcrypto -lpthread -ldl
| Config:
| Protocols: CAMD33 NEWCAMD CCCAM CCCSHARE GBOX CONSTCW
| CardRdrs : PHOENIX INTERNAL SMARGO
| Binary : Distribution/oscam-1.20-unstable_svn7946-sh4-linux
| OSCam ver: 1.20-RSP__svn rev: 7966 target: sh4-linux
| Tools:
| Settings:
| CFLAGS =
| Config:
| Addons : WEBIF TOUCH HAVE_DVBAPI CS_ANTICASC WITH_LB CS_CACHEEX
| Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD BULCRYPT
| CardRdrs : PHOENIX INTERNAL SC8IN1 MP35 SMARGO DB2COM STAPI
| Binary : Distribution/oscam-1.20-RSP__svn7966-sh4-linux
Code:Tools:
| OSCam ver: oscam-1_20-RSP_svn rev: 7983 target: sh4-linux
| Tools:
| CROSS = sh4-linux-
| CC = sh4-linux-gcc
| AR = sh4-linux-ar
| RANLIB = sh4-linux-ranlib
| Settings:
| CC_OPTS = -O2 -ffunction-sections -fdata-sections
| Config:
| Setup : WEBIF HAVE_DVBAPI WITH_LIBCRYPTO_SO CS_ANTICASC WITH_LB CS_CACHEEX
| Protocols : NEWCAMD CCCAM CCCSHARE GBOX CONSTCW
| CardReaders : PHOENIX INTERNAL SMARGO
| FritzBoxSetup: FB7270
| ShowBuilds : SHOW_DREAMBOX_BUILD SHOW_SH4_DVBAPI_BUILD SHOW_COOLSTREAM_BUILD SHOW_FRITZBOX_BUILD SHOW_DDWRT_BUILD SHOW_PC_BUILD SHOW_NSLU2UNSLUNG_BUILD SHOW_PPC_DREAMBOX_BUILD SHOW_PPC_DREAMBOX_OLD_BUILD SHOW_FONERA_BUILD SHOW_DOCKSTAR_BUILD SHOW_TPLINK_BUILD SHOW_ASUSWL_BUILD SHOW_WDTV_BUILD
| Binary : Distribution/oscam-1_20-RSP_svn7983-sh4-linux
La mine ultima vers de oscam care citeste corect cardul tvr este 7672 ... s-a mai lovit cineva de aceasta problema sau sa fie la mine un caz izolat :(
eu am doua carduri diferite in local, nu am idee de se antampla, cu 8024 si mult annapoi nu mai deschide nici un card.
Am pus 1.10 stable innapoi, asa merge.
Daca opresc 8024 din emmumanager si pornesc 1.10 merge. Opresc 1.10 si pornesc 8024 merge. Mut pe un alt canal si nu mai decodeaza. Nici ceeace mai anainte decoda.
La mine orice cu versiune mai noua de svn7819 oscam deschide corect din cardul local Focus doar pentru cateva secunde iar apoi pierde entitlements (pur si simplu dispar din info) si incepe sa-mi deschida de la peers. Cred ca si la voi se intampla acelasi lucru.
Uneori si versiunea svn7819 pierde entitlements, insa foarte rar si se remediaza oprind reader-ul pt local si pornindu-l din nou, fara sa opresc oscam.
Momentan am versiunea 7971 si nu am problema asta cu Focus.
Daca ai VU+, compari mere cu pere (SH4 vs MIPS). Spune-mi ca iti merge pe acelasi tip de box ca al meu si atunci are un sens.
Intradevar nu am SH4, tin serverul pe altceva.
e exact cum zici, cu loadbalancer off parca merge mai mult timp. Dar pana la urma e aceasi sfarsit. Nu stiu cu ce poate fi in legatura, poate gaseste cineva problema.Quote:
Originally Posted by neutrin [Only registered and activated users can see links. Click Here To Register...]
Fara balncer pornit la oscam .... va dau partenerii liniile afara :).
| OSCam ver: 1.20-unstable_by_EasyBuild_svn rev: 8119 target: sh4-linux
| Tools:
| CROSS = sh4-linux-
| CC = sh4-linux-gcc
| Settings:
| Config:
| Setup : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_LB
| CardRdrs : PHOENIX INTERNAL SMARGO STAPI
| Compiler : sh4-linux-gcc (GCC) 4.5.2 20110124 (STMicroelectronics/Linux Base4.5.2-78)
| Binary : Distribution/oscam-1.20-unstable_by_EasyBuild_svn8119-sh4-linux
