Gata si cu piratul still fm. Raman amintirile si arhivele.
[Only registered and activated users can see links. Click Here To Register...] partea 1
[Only registered and activated users can see links. Click Here To Register...] partea 2
[Only registered and activated users can see links. Click Here To Register...] part 3
[Only registered and activated users can see links. Click Here To Register...] partea 4
[Only registered and activated users can see links. Click Here To Register...] part 5
[Only registered and activated users can see links. Click Here To Register...] part 6
[Only registered and activated users can see links. Click Here To Register...] part 7
[Only registered and activated users can see links. Click Here To Register...] part 8
[Only registered and activated users can see links. Click Here To Register...] part 9
[Only registered and activated users can see links. Click Here To Register...] part 10
Cronologia still fm
[Only registered and activated users can see links. Click Here To Register...] part 2
imputernicirea urmasului still fm
casarea pieselor componente de pe emitator
Ce a insemnat still fm , emisiune de la megahits fm
Interviu in emisiunea megahits fm
IT'S over!
NEXT IS - GOODBYE DXFMROMANIA
[Only registered and activated users can see links. Click Here To Register...] filmul cerut de lume .. cioburile componentelor.
Cica .. am dat pe langa .... am ratat componentele.
piratii au copiat pana si coorul rds aev
domn cristi de la the voice se cam joaca cu sanatatea si legea
In vara am proiectat antena J-pole conform siteurilor din afara. Va spun ca pe wattmertu imi indica puterea de 12w pe un kt922B. lumina in becul de 24v la 10w era perfect alba sau albastra daca tineam becul de sticla, iar la antena pe varful mic lumina indica galben, si pe elementul cel mare rosiatic. Distanta maxima in care se auzea fimiu era de 8km. Nu mi sa parut cinestie ce antena. Ah ca pe local face impresia de cinectie ce putere, treaca de la mine.
Am incercat sa fac si gamma match, am scurtcircuitat-o si am obtinut aprox 16w pe wattmetru in loc de 12 cat avea j-pole. Cu becul pe ea, bingo, aveam lumina galben abicioasa. Distanta maxima era dupa iesirea de la afumati, undeva la 11.5km.
Separat am facut o adaptare cu bucla pe dipol inchis si am orientat-o spre afumati, lumina din bec pe curbele dipolului indica alb, iar la distanta l-am auzit pe la intrarea in com Sindrilita, cam 13km.
Daca dipolul deschis fara bucla nu este bun, eu va spun ca becul pe capatul tevii este gabui alb, rezulta ca este cam cat o gamma.
Ce am observat ca trebuie ca iesirea sa aiba minim 3 bobine si 4 trimeri ca sa pot acorda corect puterea pe wattmetru, schema clasica cu 2 bobine nu imi indica puterea corecta, ci undeva pana in 9w.
Pentru pasionati, iata lista cu ce sa mai auzit prin eter:
89.9 xpert
93.1 fanul
107.7 fm plus
93.1 pro-mix
De pe la tara
93.1 manele
89.9 manele
Sa diminuat acest hobby, plus ca nici audienta nu mai este stralucita.
De asteazi emitatoarele pirat vor deveni Bibelouri.
incepand cu data de 1 februarie 2014 (data intrării in vigoare a Legii nr. 286/2009 privind Codul penal), articolul 96 va avea următorul cuprins:
“ART. 96 (1) Constituie infracţiune şi se pedepseşte cu inchisoare de la o lună la un an sau cu amendă transmisia serviciilor de programe de radiodifuziune ori de televiziune fără licenţă de emisie sau licenţă de utilizare a frecvenţelor radio.
Sinteza FM
Dar sa ne mai distram un pic :) , ce am mai lucrat in timpul liber
Sinteza FM + amplificator 30w
Iata si finalizarea
salut la toata lumea sant nou pe aici si putin incepator in RF...as dori care poate is vrea si are o schema de emitator de 2,5 mhz 3.4.5 w care sa transporte si date si mai exact
Am datele pe Arduino si vreau sa pun un emitator de 2.5 mhz la 3.4.5w si sa le emit ....
SE POATE SAU E CINEVA CAR EMA POATE AJUTA ????
Va multumesc de ajutor oricare a fi acela
Nu poti transmite pachete de date folosind modulatia in frecventa (FM) si mai ales pe 2,5 Mhz unde viteza de transfer este extrem de mica.
Sfaul meu cel mai bun este sa folosesti un router (emisie) conectat la arduino si un AP (acces point, receptor) faci o conexiune punct la punct legatura se poate face si la 2-3 Km sau mai mult.
Routerul foloseste frecventa de 2,4 Ghz sau 5 Ghz ideal pentru a transmite pachete de date. succes.
Banuiesc ca este o tema de licenta ? sau nu ? :)
Mersi mult CIPRY de raspuns si timpul acordat pntru ami raspunde la ce am eu nevoi....nu am nevoie de frecventa asta si anume de 2 giga si cv ci de 2,5 mhz ...
Nu e tema de licenta e un proiect ce vreau sa il fac eu dar nu gasesc o schema electronica de genu care sa transporte date din arduino ....si na apelez si eu la lume poate ma ajuta cineva ..
Oricum multumesc mult poate cine stie s-o gasi cineva s ama ajute
Degeaba incerci sa flosesti frecventa de 2,5 Mhz pentru ca iti trebuie si latime de banda. Alege eventual o frecventa mai mare de la 400 Mhz si modulatie FSK , QAM ,etc. emitator-receptor digital obligatoriu iar realizarea unui astfel de kit este foarte complicat.
In topicul asta este vorba de emitatoare analogice.
cipry mersi mult de mesaj si ajutor ...eu am nevoie la frecventa asta pentru ca si datele transportate is de dimensiune mica etc si tralala ...in fine si plus ca imi trebuie cv digital....oricum mersi de mesaj si mult succes incontinuare tie si la toata lumea de pe aici
Are cineva schema de la acesta antena? cum secalculeaza dimensiunile. cum se numeste exact?
Antena dipol deschis.
Da asa este se calculeaza ca un dipol deschis dar nu stiu cat de corecte sunt acele formule.
