After going through an unboxing and teardown for the GEEKOM Mini Air12, we tested the...
Powered by a Rockchip RK3588 processor, ECS LIVA X3A fanless Android 12 mini PC is...
Leonardo Russo’s ArduinoSimulator is an open-source Arduino Simulator written in JavaScript that runs code directly...
Zigbee Home firmware project aims to provide similar functionality to ESPHome open-source firmware, but for...
The Waveshare PCIe To M.2 adapter is an inexpensive PCIe to M.2 HAT+ module for...
We first checked out the GEEKOM Mini IT12 with an unboxing and teardown of the...
Jetway, an AAEON-affiliated manufacturer, has released a new single-board computer, the JF35-ADN1, targeted at industrial...
DFRobot’s FireBeetle 2 ESP32-C6 is an IoT Development Board with 802.11ax (now called Wi-Fi 6),...
Seeed Studio’s Grove Vision AI V2 module is based on the HiMax WiseEye2 HX6538 dual-core...
The Teflon project is an open-source TensorFlow Lite delegate that currently supports VeriSilicon Vivante NPU...
The Waveshare “ESP32-S3-LCD-1.28” is an ESP32-S3-based display board featuring a 1.28-inch round LCD screen with...
We first checked out the hardware of GEEKOM Mini IT12 with an unboxing and teardown,...
Arduino Education’s Arduino Alvik is an upcoming 3-wheel educational robot that was just unveiled at...
The DA14592 System-on-Chip (Soc) is Renesas’ “lowest power consumption and smallest, multi-core Bluetooth LE device.”...
The Geekworm X1003 is a well-designed PCIe to NVMe expansion board for the Raspberry Pi...
FOSDEM – which stands for Free and Open Source Software Developers’ European Meeting – is...
LILYGO T-Panel is both a 4-inch HMI display and IoT gateway based on ESP32-S3 WiFi...
Cologne Chip’s “Integrated logic analyzer” (ILA) project is an open-source Verilog implementation of a logic...
The LinkStar H28K is a compact travel router equipped with a Rockchip RK3528 processor. It...
SAPPHIRE EDGE IPC-FP6 is a mini-ITX motherboard powered by an AMD Ryzen Embedded V2000 SoC...
