r5388 | alno | 2011-06-15 20:30:34 +0200 (Wed, 15 Jun 2011) | 2 lines
XMLApi: Add parameter to readerstats 'ecmhistory=1'. If this parameter is set the ecmhistory tag is filled with historical timevalues e.g. <ecmhistory>0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0</ecmhistory>. If the parameter is not set the tag is present but empty.
cleanup and reduce code
r5387 | _network | 2011-06-15 19:22:26 +0200 (Wed, 15 Jun 2011) | 2 lines
reader-nagra: show IRD expiration date. calculation of time may be wrong.
r5390 | Admin | 2011-06-15 21:17:04 +0200 (Wed, 15 Jun 2011) | 1 line
Partly revert r5385. Add locks to smartreader init and close as libusb (and partly our code) is not threadsafe there. Improve locking with fast_rnd (could wait up to 255ms to get a lock which can be quite bad).
r5395 | lareq78 | 2011-06-16 02:02:59 +0200 (Thu, 16 Jun 2011) | 2 lines
missed:another Mutual exclusion over always evaluates to true.
r5394 | lareq78 | 2011-06-16 01:47:36 +0200 (Thu, 16 Jun 2011) | 1 line
reader-nagra : Mutual exclusion over || always evaluates to true. so i changed it to && , (result not tested by me)
r5393 | lareq78 | 2011-06-16 01:37:54 +0200 (Thu, 16 Jun 2011) | 1 line
few correction
r5392 | Admin | 2011-06-16 00:44:09 +0200 (Thu, 16 Jun 2011) | 1 line
Return 0 instead of -9 on POLLHUP
r5391 | lareq78 | 2011-06-16 00:08:46 +0200 (Thu, 16 Jun 2011) | 1 line
Correct include path
r5397 | lareq78 | 2011-06-16 14:32:03 +0200 (Thu, 16 Jun 2011) | 1 line
r5396 | lareq78 | 2011-06-16 13:45:23 +0200 (Thu, 16 Jun 2011) | 2 lines
some cleaning
fix possible Buffer access out-of-bounds
r5398 | Admin | 2011-06-16 20:58:57 +0200 (Thu, 16 Jun 2011) | 1 line
Fix videoguard bufferoverflows introduced in r5396
r5400 | _network | 2011-06-16 21:36:16 +0200 (Thu, 16 Jun 2011) | 2 lines
improve fix from r5399
r5399 | _network | 2011-06-16 21:16:22 +0200 (Thu, 16 Jun 2011) | 2 lines
fix memory corruption when using trim() and strlen is 1
r5401 | lareq78 | 2011-06-17 14:34:16 +0200 (Fri, 17 Jun 2011) | 3 lines
try to fix Cpu problem described which introduced in 5381 (revert read_from_pipe
r5402 | lareq78 | 2011-06-17 15:38:06 +0200 (Fri, 17 Jun 2011) | 1 line
fix broken line in my last commit,
r5404 | _network | 2011-06-17 07:21:32 PM (Fri, 17 Jun 2011) | 2 lines
dynamic-threads: resync with trunk and minor fixes
r5403 | pattex | 2011-06-17 18:55:27 +0200 (Fri, 17 Jun 2011) | 1 line
WebIf: Added a Link under Reader Section that shows Graphs with the ecm times of all Readers and Proxies. SVG-compatible Browser with javascript enabled, required.
r5412 | pattex | 2011-06-17 23:01:42 +0200 (Fri, 17 Jun 2011) | 1 line
WebIF: More Colors for Graphs, mimetype now corrected, longer timeline
r5411 | alno | 2011-06-17 22:47:03 +0200 (Fri, 17 Jun 2011) | 1 line
WebIf: fix compiler warning
r5410 | _network | 2011-06-17 21:55:29 PM (Fri, 17 Jun 2011) | 1 line
dynamic-threads: add a pipe for waking up client_check thread
r5409 | Admin | 2011-06-17 09:49:36 PM (Fri, 17 Jun 2011) | 1 line
Fix output of in-RAM loghistory if the last position points right to the end of the log history.
r5408 | Admin | 2011-06-17 09:08:31 PM (Fri, 17 Jun 2011) | 1 line
Remove cs_lock from coolapi as it's not really needed there (there should not be threads that get killed) and could perhaps
create problems.
r5407 | pattex | 2011-06-17 20:56:09 +0200 (Fri, 17 Jun 2011) | 1 line
WebIf: smaller datatransfer while viewing Graph.
r5406 | Admin | 2011-06-17 20:37:49 +0200 (Fri, 17 Jun 2011) | 3 lines
Revert WinSCard.h from r5396 as it seems to break cygwin compilation (see #1944).
Revert r5401 as the cpu issue has been fixed in before and this change could break other things (detected full pipes when they are not because pipecnt is not updated anymore).
Add check for ecm timeout before adding it to ecmcache.
r5405 | alno | 2011-06-17 20:16:03 +0200 (Fri, 17 Jun 2011) | 1 line
XMLApi: make ringbuffer more threadsave and avoid buffor overflow by normalize values to 4 digits
r5413 | pattex | 2011-06-18 01:06:13 +0200 (Sat, 18 Jun 2011) | 1 line
WebIf: Hide Readers that are hidden, configuration via stylesheets. Look into site.css. Smaller Font-size for Labels.
r5419 | Admin | 2011-06-18 03:31:03 +0200 (Sat, 18 Jun 2011) | 1 line
Fix missing reinitialization of card_count in share_updater leading to "fast refresh mode" (for low amount of cards) only being used for a short time.
r5418 | Admin | 2011-06-18 03:20:06 +0200 (Sat, 18 Jun 2011) | 1 line
Small improvement for r5417
r5417 | Admin | 2011-06-18 03:11:21 +0200 (Sat, 18 Jun 2011) | 1 line
Fix a reported segfault in cccshare which happens when the global cardlist is rebuilt (and thus the old one cleaned) while sending initial carddata to a client (only happens on very slow/blocking ones because cleanup is delayed by garbage collector to 5s which is normally enough)
r5416 | Admin | 2011-06-18 02:41:08 +0200 (Sat, 18 Jun 2011) | 1 line
Add checks for cleaned clients to fix some reported leaks/segfaults which happen when the client which requested an ecm has exited before receiving the result.
r5415 | pattex | 2011-06-18 01:49:25 +0200 (Sat, 18 Jun 2011) | 1 line
WebIf:Show only valid ECM-Times
r5414 | pattex | 2011-06-18 01:28:38 +0200 (Sat, 18 Jun 2011) | 1 line
WebIf: more colors for graph
r5420 | jerdvb | 2011-06-18 16:35:31 +0200 (Sat, 18 Jun 2011) | 4 lines
!!! Warning this may break compatibility
Change ECM size to 512
Update camd35 to handle ECM size > 255 (tested with UDP and a patched version of VDR-SC)
r5422 | jerdvb | 2011-06-18 18:32:08 +0200 (Sat, 18 Jun 2011) | 3 lines
Update camd35 to handle ECM size > 255 (for client part)
r5421 | alno | 2011-06-18 17:54:55 +0200 (Sat, 18 Jun 2011) | 1 line
Config: check for duplicate accounts and rename while startup. Move some generic functions to more central point
r5423 | alno | 2011-06-18 22:44:10 +0200 (Sat, 18 Jun 2011) | 1 line
XMLApi: add some atributes in userlist
