Rockchip RK3568 SBC takes up to four AHD cameras, two SATA drives
Boardcon EM3568-AV CAM SBC is powered by a Rockchip RK3568 SoC and comes with four...
Quansheng multiband radios’ firmware can be flashed and customized from a web browser
We’ve recently written about the Quansheng UV-K5 multiband radio which supports experimental firmware to work...
Orbbec Femto Bolt 3D depth and RGB USB-C camera supports Microsoft ToF technology
Orbbec Femto Bolt is a 3D depth and RGB USB-C camera developed in collaboration with...
RTL-SDR Blog V4 dongle launched with Rafeal R828D tuner chip
RTL-SDR has just launched the RTL-SDR Blog V4 dongle for software-defined radio (SDR) enthusiasts based...
M.2/mini PCIe card adds DVB-S2X/S2 tuner to desktop PCs and (some) SBC’s
TBS has designed two small DVB-S2X/S2/S tuner cards with the TBS7230 M.2 module and TBS7901...
Star64 RISC-V SBC can now boot Apache NuttX real-time operating system
Most of the software development efforts on the more powerful RISC-V boards like Pine64 Star64...
SONOFF MINIR4M – A Matter-compatible WiFi Smart Switch
SONOFF MINI Extreme (MINIR4M) is the first Matter-certified home automation device from the company and...
Mecpow X3 Pro – A newly launched 10W laser engraver with air assist kit (Sponsored)
Mecpow X3 Pro is a 10W laser engraver with an air assist kit to improve...
BOXER-6406-ADN Alder Lake-N fanless embedded computer supports 9V-36V DC input
AAEON BOXER-6406-ADN is a compact fanless embedded computer powered by the popular Intel Alder Lake-N...
Ultra-compact 45x43mm CPU module features TI Sitara AM6231, AM6252, or AM6254 Arm SoC
MYiR Tech has just announced the tiny, yet full-featured MYC-YM62X CPU module powered by Texas...
Mini review of GGtag e-paper display programmable through sound or USB serial
GGtag is a 3.52-inch e-paper display based on the Raspberry Pi RP2040 microcontroller and programmable...
Privacy-focused DIY video doorbell leverages ESP32-CAM board, ESPHome firmware, Home Assistant
Seeing the lack of privacy-focused video doorbells on the market, Tristam (aka ThatGuy) decided to...
ALFA Network HaLow-U – An 802.11ah WiFi HaLow USB adapter supporting AP and STA mode
ALFA Network HaLow-U is an 802.11ah WiFi HaLow USB adapter based on the Newracom NRC7292...
ArmSoM-p2 pro is a compact Rockchip RK3308B-S SBC for headless applications
ArmSoM-p2 pro is a compact Rockchip RK3308B-S SBC made by a company called ArmSoM and...
Kontron K3931-N mITX – An industrial mini-ITX motherboard with Intel Alder Lake N-series processor
Kontron K3931-N mITX is a mini-ITX motherboard based on an Intel Core i3 or Processor...
Ugoos AM8 – A true 8K TV box powered by Amlogic S928X-J processor
Ugoos AM8 Plus is a true 8K TV box based on Amlogic S928X-J penta-core Cortex-A76/A55...
TerraMaster F2-212 is a 2-Bay NAS powered by Realtek RTD1619B Arm Cortex-A55 SoC
TerraMaster F2-212 is a 2-bay NAS powered by Realtek RTL1619B quad-core Cortex-A55 processor with support...
Lo-Fi ESP32-S3 board features LoRa module for low-power long-range connectivity (Crowdfunding)
SB Components’ Lo-Fi is an ESP32-S3 board equipped with a LoRa module for low-power long-range...
Chart confirms higher level of Raspberry Pi restocks
Earlier this month, we noted that Raspberry Pi supplies were improving mostly from tweets from...
myCobot Pro 600 Raspberry Pi 4-based robot arm supports 600mm working range, up to 2kg payload
Elephant Robotics has launched its most advanced 6 DoF robot arm so far with the...
Radxa ROCK 5B SBC goes fanless with metal case
The Radxa ROCK 5B was one of the first Rockchip RK3588 SBCs, and when we...
Raspberry Pi CM4-powered outdoor gateway supports GbE, WiFi 5, Bluetooth 5.0, 4G LTE, LoRaWAN, and GPS connectivity
EDATEC ED-GWL2110 is an IP24-rated outdoor gateway based on Raspberry Pi CM4 and supporting Gigabit...
Raspberry Pi Pico to Arduino Uno adapter relies on “FlexyPins” for castellated holes
Solder Party’s “Raspberry Pi Pico to Uno FlexyPin Adapter” transforms the Raspberry Pi Pico into...
Tiny mini PC with four 2.5Gbps Ethernet ports ships with Intel Processor N100/N200 or Core i3-N305 CPU
The “M1 Pocket Mini Soft Router” is a tiny Intel Alder Lake-N OEM mini PC...
DIN-Rail mountable industrial 4G LTE router takes 9V to 36V DC power input
Waveshare WS-431E is an industrial-grade 4G LTE router with three Ethernet ports, WiFi 4, wall...
PicoCNC – A 4-axis CNC controller based on Raspberry Pi Pico
PicoCNC is a 4-axis CNC motion controller that works with Raspberry Pi Pico or Pico...
Banana Pi BPI-CM2 – A Raspberry Pi CM4-compatible Rockchip RK3568 SoM with extra I/Os
Banana Pi BPI-CM2 is another Raspberry Pi CM4-compatible system-on-module, this time based on a Rockchip...
Get Early Access to the World’s Most Powerful Edge AI Accelerator! (Sponsored)
Final Call for Axelera AI’s Early Access Program A few months ago Axelera AI launched...
DietPi News – v8.20 released, NanoPi Neo Air handheld Linux terminal
The latest DietPi v8.20 release of the lightweight Debian-based Linux distribution for SBCs and server...
Unveiling The World’s First Mini PC Powered By The 13th Gen Core i9 CP
GEEKOM, a leading provider of Mini PCs, is thrilled to unveil its newest Mini IT13,...
ESP ZeroCode web application creates custom Matter-certifiable firmware for ESP32 targets
Low-code/no-code platforms keep on coming and Espressif Systems ESP ZeroCode adds to the list. It...
EPIC-ADN9 SBC features up to four 2.5GbE interfaces, two SATA ports
AAEON EPIC-ADN9 SBC is powered by an Intel Processor N50/N97, Core i3-N305, or Atom x7425E...
MediaPipe for Raspberry Pi released – No-code/low-code on-device machine learning solutions
Google has just released MediaPipe Solutions for no-code/low-code on-device machine learning for the Raspberry Pi...
Setting up a private LoRaWAN network with WisGate Connect gateway
In this guide, we’ll explain how to set up a private LoRaWAN network using the...
StarLite Mk V 2-in-1 Linux hybrid laptop features Processor N200 processor
Just last month, Star Labs introduced the Byte Mk II Intel Processor N200-based mini PC...
TRACEPaw sensorized paw helps legged robots “feel the floor” with Ardu
Our four-legged friends don’t walk on tarmac the same way as they do on ice...
EDATEC ED-HMI2020-101C – A 10.1-inch Raspberry Pi CM4-based industrial panel PC
EDATEC has launched yet another Raspberry Pi CM4-based platform for industrial applications with the ED-HMI2020-101C...
Seguro 150 Bluetooth and NFC temperature logger works without mobile app (for the receiver)
Sensified.io Seguro 150 is a 4mm thick waterproof temperature logger designed for cold chain shipping...
Banana Pi BPI-6202 industrial SBC features Allwinner A40i SoC, 24V DC input, RS485 interfaces
Banana Pi BPI-6202 “embedded single board computer” features the industrial-grade Allwinner A40i quad-core Cortex-A7 processor...
gr-lora_sdr – A GNU Radio SDR implementation of a LoRa transceiver
The physical layer of the LoRa (LoRa PHY) is a proprietary standard owned by Semtech...
SenseCAP T1000 – A credit card-sized LoRaWAN GPS tracker based on Semtech LR1110 (Crowdfunding)
SenseCAP T1000 is an ultra-thin credit-card-sized GPS tracker with Semtech LR1110 wireless chip with LoRaWAN,...
Silicon Labs SG23 and SG28 SoCs are optimized for Amazon Sidewalk
Silicon Labs has launched two new Cortex-M33 SoCs optimized for Amazon Sidewalk with the EFR32SG23...
Getting started with VOIPAC IMX8M Industrial development kit (Yocto Linux SDK)
Last month I went through an unboxing of the VOIPAC iMX8M Industrial Development Kit with...
Tiny solder-down NXP i.MX 93 System-on-Module powers credit card-sized evaluation board
Ka-Ro Electronics’ QS93 is a tiny solder-down NXP i.MX 93 System-on-Module (SoM) running Linux and...
Cool Pi Arm Linux Laptop with Rockchip RK3588 SoM sells for $455
Cool Pi has put its CM5 Rockchip RK3588 system-on-module to good use by integrating it...
Khadas Mind Premium review – Part 3: Ubuntu 22.04 tested on an Intel Core i7-1360P mini PC
Khadas Mind Premium is an ultra-thin mini PC powered by an Intel Core i7-1360P Raptor...
Raspberry Shake HAT brings earthquake monitoring to the Raspberry Pi SBC
Raspberry Shake is a family of Raspberry Pi HATs and full seismograph and infrasound monitors...
Modular Mojo claims to be over 36,000 times faster than Python for AI workloads
Modular Mojo is a new programming language designed for AI developers that is said to...
Youyeetoo YY3568 devkit review – Part 1: Unboxing, specifications, and Android 11 testing
Youyeetoo has sent us a review sample of their YY3568 “Bundle 5” devkit with the...
Ugoos AM8 is a true 8K TV box based on Amlogic S928X-J penta-core Cortex-A76/A55 processor...
LuckFox Pico Rockchip RV1103 Cortex-A7/RISC-V camera board comes with an optional Ethernet port
LuckFox Pico is a small Linux camera board based on the Rockchip RV1103 Cortex-A7 and...
SiFive unveils P870 high-performance core, discusses future of RISC-V
Comparing ISA Business Models – x86 vs Arm vs RISC-C – Source: 果壳 (Guokr) SiFive...
Blackview MP80 review – Part 2: An Intel Processor N95 mini PC tested with Windows 11
In the first part of our Blackview MP80 Mini PC review we’ve looked at the...
LoRaWAN IoT Button ships with open-source firmware, bootloader, and Android app
LoRaWAN is often used for asset tracking or environmental monitoring, for example, to track cattle...
ASRock launches Intel Processor N100 motherboards with 24-pin ATX connector or DC-in jack
ASRock has launched two new similar low-cost Alder Lake-N motherboards powered by a 3.4 GHz...
Orange Pi Compute Module 4 – A low-cost Rockchip RK3566-powered alternative to Raspberry Pi CM4
Orange Pi Compute Module 4 is a system-on-module mechanically and electrically compatible with the Raspberry...
SemiDrive D9-Pro (D9360) Arm Cortex-A55/R5 processor powers industrial CPU module for motor control
MYiR MYC-JD9360 is a CPU Module powered by SemiDrive D9-Pro (D9360) processor with six Arm...
Sipeed unveils RISC-V tablet, portable Linux console, and cluster
Sipeed has unveiled three new hardware platforms based on the LM4A RISC-V system-on-module found in...
Linux 6.5 release – Notable changes, Arm, RISC-V and MIPS architectures
Linus Torvalds has just announced the release of Linux 6.5 on the Linux Kernel Mailing...
Review of CrowView 14-inch portable monitor with laptops and mini PCs
I received an early sample of the CrowView 14-inch laptop monitor for review a few...
ZimaBlade – A $64+ low-profile Intel Celeron board for server applications and more (Crowdfunding)
ZimaBlade is an inexpensive low-profile board based on an Intel Celeron dual-core or quad-core processor...
Chuwi HeroBox 2023 low-cost mini PC features Processor N100, supports M.2 NVMe SSD and 2.5-inch SATA storage
Chuwi HeroBox 2023 is yet another Intel Processor N100 mini PC equipped with 8GB LPDDR5...
ESP32-S3-BOX-3 devkit comes with 2.4-inch display, dual microphone, PCIe expansion connector
Espressif Systems has launched an update to their ESP32-S3-Box development kit for online and offline...
Cincoze DS-1400 series embedded computers feature 12th Gen Alder Lake-S processors, PCIe expansion slots
Cincoze DS-1400 series rugged embedded computer comes with a choice of 12th Gen Alder Lake-S...
Fairphone 5 smartphone comes with 8 years of software updates thanks to Qualcomm QCM6490 industrial IoT processor
The Fairphone 5 is the latest version of the ethical, repairable, and sustainable smartphone with...
Using SenseCAP T1000 LoRaWAN GPS Tracker for cattle tracking
SenseCAP T1000 is a credit-size GPS tracker using LoRaWAN low-power long-range connectivity. Smart Agriculture is...
Raspberry Pi CM4 compatible RISC-V SoM features StarFive JH7110 SoC
We’ve seen many Arm-based system-on-modules following the Raspberry Pi CM4 form factor, but we’ve now...
STARLIGHT – A Raspberry Pi RP2040 board for rockets
Circuit Wizardry’s STARLIGHT is a rocket control board based on Raspberry Pi RP2040 microcontroller and...
Allwinner 2023-2024 roadmap reveals A736/A737 Arm Cortex-A78/A76 processors
Allwinner should launch new Cortex-A76/A55 and Cortex-A78/A55 processors in 2024 according to the company’s roadmap...
SparkFun launches ESP32-based “Arduino IoT Weather Station” with Arduino IoT Cloud integration
SparkFun’s Arduino IoT Weather Station is a complete weather station kit leveraging the company’s MicroMod...
Orange Pi Zero 2W – A Raspberry Pi Zero 2W alternative with up to 4GB
As its name implies the Orange Pi Zero 2W is an alternative to the Raspberry...
Libre Computer AML-S905X-CC-V2 SBC directly installs Linux images from the Internet
Libre Computer AML-S905X-CC-V2 “Sweet Potato” is a “new” Amlogic S905X SBC following the Raspberry Pi...
Arylic BP50 – An $80 Bluetooth 5.2 preamplifier with ESS ES9023P DAC (Sponsored)
Arylic BP50 is a low-cost Bluetooth 5.2 preamplifier based on ESS ES9023P 192kHz/24-bit DAC (see...
Gateworks GW7400 networking SBC features 6 Gigabit Ethernet ports, M.2 & mini PCIe sockets for wireless connectivity
Gateworks Venice GW7400 is a rugged industrial single board computer for networking and gateway applications...
Haxophone – A Raspberry Pi-based electronic saxophone with mechanical keys (Crowdfunding)
The Haxophone is an unusual Raspberry Pi expansion board that transforms the popular SBC into...
Sony energy harvesting module generates power from electromagnetic wav
Sony Semiconductor Solutions Corporation (SSS) has developed an energy harvesting module that uses electromagnetic wave...
Rockchip RK3562-powered Android 13 tablets are starting to show up
Back in March, Rockchip showcased some tablets powered by the new 2.0 GHz Rockchip RK3562...
SMLIGHT SLZB-06M Zigbee 3.0 PoE adapter gets Silabs EFR32MG21 microcontroller
SMLIGHT SLZB-06M is a Zigbee 3.0 to Ethernet, PoE, USB, or WiFi adapter designed to...
Andes launches AX45MPV RISC-V CPU core with Vector Extension 1.0
Andes Technology has recently announced the general availability of the AndesCore AX45MPV RISC-V CPU which...
Cadence Neo NPU IP scales from 8 GOPS to 8 TOPS
Cadence Neo NPU (Neural Processing Unit) IP delivers 8 GOPS to 80 GOPS in single...
Rockchip RK3588 AIoT gateway supports WiFi 6, 5G, RS232, RS485, LoRaWAN, BLE, and Ethernet
Dusun DSGW-380, also called Dusun Pi 5, is an industrial AIoT gateway powered by the...
Pico QwiicReset board adds Reset button and Qwiic connector to Raspberry Pi Pico
Pico QwiicReset is a tiny add-on board for the Raspberry Pi Pico that adds a...
$999 Librem 11 Linux tablet features Celeron N5100 processor, 1TB NVMe SSD, 2.5K AMOLED display
Purism Librem 11 is an 11.5-inch Linux tablet running the secure PureBoot bootloader and PureOS...
Thunderbolt 5 to deliver up to 120 Gbps bandwidth, support multiple 8K monitors
Intel has just announced Thunderbolt 5 and demonstrated it with a prototype laptop and dock...
SwiftIO Circuit Playground relies on Apple Swift programming for IoT projects (Crowdfunding)
A few years ago, Mad Machine introduced the SwiftIO board powered by an NXP i.MX...
Realtek RTL8852BE based WiFi 6 and Bluetooth 5.2 module targets Smart
Telit Cinterion WE310K6-P is a dual-band Wi-Fi 6 and Bluetooth 5.2 based on the Realtek...
Review of CM4 XGO Lite – A Raspberry Pi CM4 based smart robot dog with a robotic arm
The CM4 XGO Lite is a smart robot dog based on Raspberry Pi CM4 system-on-module...
Sparkfun launches cheaper no-code “DataLogger IoT” board compatible with Qwiic modules
Last May, SparkFun introduced the “Datalogger IoT – 9DoF” no-code platform with support for over...
Intel N100 mini PC offers eight USB ports, NVMe and SATA storage
We’ve already written about many mini PCs powered by the Intel Processor N100 SoC and...
AI in a box offline LLM solution leverages Rockchip RK3588S’ NPU (Crow
Useful Sensors “AI in a box” LLM (large language model) solution works offline with complete...
PICO-EHL4-SEMI fanless mini PC is made for PoS and kiosk applications
AAEON PICO-EHL4-SEMI is a fanless Elkhart Lake mini PC designed for digital signage, smart retail...
Home Assistant Green – A $99 Home Assistant gateway with a Rockchip RK3566 processor
The developers of the popular Home Assistant open-source automation framework have introduced the Home Assistant...
Lichee Cluster 4A mini-ITX RISC-V cluster board launched for $929 and up
As expected, Sipeed has now launched their Lichee Cluster 4A mini-ITX cluster board and box...
Review of ALLPCB PCB manufacturing services with an ESP32 board (Sponsored)
ALLPCB, a PCB manufacturer based in China, has offered us to review their PCB manufacturing...
Amlogic S905X5 Armv9 TV Box SoC supports AV1, H.266, Ai-SR
The Amlogic S905X5 may be first the Armv9 processor designed for set-top boxes (STB) and...
EDATEC ED-IPC2100 industrial computer offers 4x RS485/RS232 ports
EDATEC has launched four more Raspberry Pi CM4-powered industrial computers with the ED-IPC2100 Series that...
Qualcomm 10G Fiber Gateway Platform supports Wi-Fi 7 and “Service Defined Wi-Fi technology”
Qualcomm 10G Fiber Gateway Platform combines 10G Passive Optical Network (PON) technology with Wi-Fi 7...
Amazon Fire TV Stick 4K Max (2023) features a 2 GHz MediaTek MT8696T CPU, support WiFi 6E
Amazon has recently introduced its second-generation Fire TV Stick 4K and Fire TV Stick 4K...
AMD Kria K24 Zynq Ultrascale+ system-on-module targets motor control and DSP applications
The AMD Kria K24 System-on-Module (SOM) with a custom-built Zynq UltraScale+ MPSoC and the KD240...
Review of Youyeetoo Rockchip RK3568 SBC with Lubuntu 20.04 and the RKNPU2 AI SDK
We’ve already reviewed the Rockchip RK3568-power Youyeetoo YY3568 SBC with Android 11 – and listed...
Review of ALLPCB PCB manufacturing services with an ESP8266 board (Sponsored)
LILYGO T-ETH-Lite – An ESP32-S3 board with Ethernet, optional PoE supp
LILYGO T-ETH-Lite ESP32-S3 is a new ESP32-S3 WiFi and Bluetooth development board with a low-profile...
ACEMAGIC S1 – A Processor N95 mini PC with a built-in LCD information display
ACEMAGIC S1 is a mini PC powered by an Intel Processor N95 Alder Lake-N processor...
Review of Arylic BP50 Bluetooth 5.2 preamplifier with TIDAL Music
Arylic has sent us a sample of their low-cost BP50 Bluetooth 5.2 preamplifier for review....
Bluetooth NLC (Networked Lighting Control) fully standardizes Bluetooth light bulbs
Bluetooth NLC (Networked Lighting Control) is a full-stack standard for wireless lighting control from the...
GEEKNUC’s Intel NUC 12 and NUC 13 promotion for back to school season (Sponsored)
GEEKNUC, a reseller of genuine Intel NUC mini PCs, has now launched a “back to...
PALMSHELL NeXT H2 SBC and micro server offers 10GbE for $199 and up
PALMSHELL NeXT H2 is an affordable AMD Ryzen Embedded R1505G-powered micro server, also available as...
Arduino GIGA R1 WiFi board gets touchscreen display shield
The Arduino GIGA Display Shield is a 3.97-inch RGB touchscreen display designed for the Arduino...
Samsung LPCAMM integrates LPDDR RAM on removable modules
Samsung has unveiled a new type of removable memory module called the LPCAMM (Low Power...
BIGME B251 – An All-in-One color E-Ink computer and standalone monitor (crowdfunding)
The BIGME B251 is a 25.3-inch color E-Ink monitor that is also sold as an...
Raspberry Pi 5 SBC launched with 2.4 GHz Broadcom BCM2712 quad-core Cortex-A76 SoC
The long-awaited Raspberry Pi 5 SBC is finally here with a powerful Broadcom BCM2712 quad-core...
Microchip PIC18-Q20 low-pin count MCU comes with up to two I3C interfaces
Microchip PIC18-Q20 is a new family of microcontrollers (MCUs) with a low-pin count (14 and...
Renesas RZ/G2L and RZ/V2L SMARC 2.1 system-on-modules target HMI and E
ARIES Embedded has recently launched two SMARC-compliant MRZG2LS and MRZV2LS system-on-modules (SoM) powered by respectively...
Ollie v2 USB to UART/CAN/RS485/RS232 converter gets USB-C port, plastic enclosure, and more (Crowdfunding)
Ollie v2 is an improved version of the Ollie USB to isolated UART, CAN Bus,...
ZX05 mini PC with Processor N100 CPU, 12GB RAM goes for $133 and up
ZX05 is another Intel Processor N100 Alder Lake-N mini PC whose main selling points are...
Sipeed Tang Mega 138K Pro Dock features GOWIN GW5AST FPGA + RISC-V SoC
Sipeed has launched another FPGA board part of their Tang family with the Tang Mega...
Android 14 released, source code hits AOSP
Google has just released Android 14 for supported devices such as Google Pixel phones and...
UP Squared i12 Edge is a compact, yet feature-rich, fanless Alder Lake-P mini PC
UP Squared i12 Edge is a compact fanless mini PC powered by 12th Generation Intel...
GL.iNet Flint2 AX6000 router supports up to 900 Mbps WireGuard VPN with MediaTek MT7986 SoC
GL.iNet Flint2 (also known as GL-MT6000) is a new AX6000 router based on MediaTek MT7986...
Azulle’s Byte4 – Customization at Its Finest With 3 Stellar Add-on Modules (Sponsored)
In the ever-evolving world of technology, we often find ourselves at a crossroads between power...
Inkplate 4 TEMPERA ePaper display supports ESPHome, Arduino, and MicroPython (Crowdfunding)
Years after years, Soldered Electronics keeps on churning out new ESP32-powered ePaper displays and the...
Review of the first Matter device by SONOFF – MINI Extreme Wi-Fi Smart Switch (MINIR4M)
We have just received the first Matter product from SONOFF for review, which is the...
GigaDevice GD-xD-W515-EVAL board features GD32W515 Cortex-M33 MCU, a f
GigaDevice GD-xD-W515-EVAL is a new “all-in-one” Cortex-M33 evaluation kit comprised of a GD32W515 mainboard, a...
M5Dial – An ESP32-S3 smart rotary knob with a touchscreen display
M5Stack M5Dial is a WiFi and Bluetooth-connected smart rotary knob with a round 1.28-inch touchscreen...
Raspberry Pi releases RP1 peripheral controller datasheet and block diagram
The Raspberry Pi 5 was recently introduced with the Broadcom BCM2712 CPU and the RP1...
Barebone M4 fanless mini PC features Intel Processor N100 for $106 and up
I thought it would be hard to beat the price of the Processor N100 ZX05...
Raspberry Pi OS upgraded to Debian 12 “Bookworm”
Raspberry Pi has announced a new release of Raspberry Pi OS based on Debian 12...
Microchip PIC32CZ CA 300 MHz Arm Cortex-M7 MCU features a Hardware Security Module (HSM)
Microchip PIC32CZ CA is a new family of Arm Cortex-M7 microcontrollers with the PIC32CZ CA90...
COM-HPC 1.2 specification released with COM-HPC Mini 95x70mm form factor
PICMG has announced the release of the COM-HPC 1.2 specification adding the COM-HPC Mini form...
SMLIGHT SLZB-07 – A low-cost, compact Zigbee 3.0 USB adapter
SMLIGHT SLZB-07 is a low-cost, compact Zigbee 3.0 USB adapter based on Silicon Labs EFR32...
SECO Modular Vision HMI displays support Arm and x86 SMARC 2.1 modules
SECO has unveiled a new HMI family of smart displays called the “Modular Vision” with...
49 cents “Black Pill” board clone features AT32 Cortex-M4F microcontroller
The “Black Pill” board with an STM32F4 Cortex-M4F MCU is already cheap, but I’ve just...
Waveshare RP2040-PiZero – A Raspberry Pi RP2040 board with Raspberry Pi Zero form factor
Waveshare RP2040-PiZero board is a Raspberry Pi Zero lookalike that features a Raspberry Pi RP2040...
OpenWrt 23.05 released with MbedTLS by default, Rust packages, over 1,
OpenWrt 23.05 open-source Linux operating system for routers and resource-constrained headless embedded systems has just...
M5Stack Cardputer – A $30 card-sized ESP32-S3 computer with display and keyboard
M5Stack Cardputer is a card-sized portable computer based on the ESP32-S3-powered M5Stamp S3 wireless module...
SZBOX S100 pocket-sized Mini PC offers 2.5GbE & WiFi 6 networking, dual HDMI
SZBOX S100 is a pocket-sized mini PC powered by an Intel Processor N100 CPU, with...
Orange Pi 5, 5B, and 5 Plus SBCs are now offered with 32GB RAM
Rockchip RK3588 SoC has long been advertised as supporting up to 32GB RAM, but the...
