r5273 | landlord | 2011-05-21 00:32:13 +0200 (Sat, 21 May 2011) | 1 line
Update for 'keepalive' paramter in documentation.
r5272 | landlord | 2011-05-21 00:17:21 +0200 (Sat, 21 May 2011) | 1 line
Small updates in txt documentation, too
Oscam-1.00-svn5273
r5277 | landlord | 2011-05-21 22:26:23 +0200 (Sat, 21 May 2011) | 1 line
Update for 'keepalive' parameter in 'oscam.user' documentation.
r5276 | landlord | 2011-05-21 22:22:21 +0200 (Sat, 21 May 2011) | 1 line
Update for 'updateinterval' paramter in documentation.
r5275 | _network | 2011-05-21 19:49:41 +0200 (Sat, 21 May 2011) | 2 lines
fix for quickfix r5260 (should fix #1874)
r5278 | landlord | 2011-05-23 08:09:41 +0200 (Mon, 23 May 2011) | 1 line
Fixed some typo errrors.
r5279 | schlocke | 2011-05-23 13:47:58 +0200 (Mon, 23 May 2011) | 3 lines
small changes on logging
small changes updating old code
r5280 | Admin | 2011-05-23 22:35:32 +0200 (Mon, 23 May 2011) | 1 line
Fix #1880, Add emmlogdir parameter as requested in #1517 to define the location of emms saved through savenano parameter in readers section. If it is not set, old behaviour (configuration directory) is used.
r5281 | landlord | 2011-05-24 08:51:12 +0200 (Tue, 24 May 2011) | 1 line
Added new parameter 'emmlogdir' to documentation.
Oscam-1.00-svn5283
r5283 | alno | 2011-05-24 21:28:43 +0200 (Tue, 24 May 2011) | 1 line
r5282 | alno | 2011-05-24 21:27:52 +0200 (Tue, 24 May 2011) | 1 line
Adding LCD support. Read [Only registered and activated users can see links. Click Here To Register...] for details
r5284 | _network | 2011-05-24 22:12:45 +0200 (Tue, 24 May 2011) | 2 lines
dvbapi: fix for prioritizing irdeto chids
r5287 | hapeba | 2011-05-25 07:33:03 +0200 (Wed, 25 May 2011) | 1 line
LCD support default disabled
r5286 | hapeba | 2011-05-25 07:30:11 +0200 (Wed, 25 May 2011) | 1 line
LCD support --> config.sh, oscam -h and oscam.version
r5285 | alno | 2011-05-25 00:03:11 +0200 (Wed, 25 May 2011) | 1 line
LCD: datatypes and resolve channelname
Oscam-1.00-svn5288
r5288 | hapeba | 2011-05-25 07:48:42 +0200 (Wed, 25 May 2011) | 1 line
fix config.sh
r5289 | _network | 2011-05-25 16:34:17 +0200 (Wed, 25 May 2011) | 2 lines
viaccess: allow shared emm with provider as serial (#1838)
fix config.sh
r5290 | alno | 2011-05-25 20:15:12 +0200 (Wed, 25 May 2011) | 1 line
LCD: some corrections and removing windows linebreaks
Oscam-1.00-svn5294
r5294 | alno | 2011-05-25 22:34:29 +0200 (Wed, 25 May 2011) | 1 line
LCD: add status on reader/proxy
r5293 | alno | 2011-05-25 21:40:45 +0200 (Wed, 25 May 2011) | 1 line
LCD: filter idle clients
r5292 | schlocke | 2011-05-25 21:24:45 +0200 (Wed, 25 May 2011) | 2 lines
cccam: fixed stealth remote node id
r5291 | alno | 2011-05-25 21:15:54 +0200 (Wed, 25 May 2011) | 1 line
LCD: add EMM displaying
r5297 | alno | 2011-05-25 23:28:57 +0200 (Wed, 25 May 2011) | 1 line
LCD: corrected statusmessages
r5296 | alno | 2011-05-25 23:10:11 +0200 (Wed, 25 May 2011) | 1 line
LCD: re-implement filter for idle clients >10 sec idle
r5295 | alno | 2011-05-25 22:51:40 +0200 (Wed, 25 May 2011) | 1 line
LCD: remove idle filtering for clients - test if further crashes with lcd
